Is there any way to adjust the lowest flame in the small burners in our 30" Bosch cooktop? The owner's manual shows no such adjustment. There is no way to simmer anything on even the smaller two burners.
SOURCE: constant clicking when turned on
I am not familiar with your particular model, but if you just had it installed, I'd say that the outlet you are using to plug it in is on a GFI circuit (ground fault interrupt) You cannot use a cooktop with automatic re-ignition on a GFI circuit, as it will do exactly what you are describing. Easiest way to check this is to go to home depot and buy a little outlet tester that will tell you if your polarity is reversed in the outlet (another possible cause) or if it is a gfi or non gfi. The other thing you could try is unplugging the unit and plug it into an extension cord. Then take the cord and run it to a non gfi outlet in a hallway or anywhere but the kitchen or bathroom areas and see if it behaves itself then. Hope this helps!
SOURCE: Clicking noise on cooktop even when all burners ignite
Jsut a guess - see this solution: http://www.fixya.com/support/t119696-constant_clicking_when_turned
SOURCE: NOT WORKING BURNER ON MY VIKING 6 BURNER COOKTOP VGSU 36IN
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
SOURCE: Broken glass for 5 burners electric Bosch cooktop
If you can give me the model number I can give you 3 places and there prices. The model number should be located on the bottom of the unit.
Same issue on 30" Miele. Was your cooktop installed without a pressure regulator? I suspect mine was and that is likely going to be the solution.
