Question about Hotpoint HSS25GFP Side by Side Refrigerator
CLICKING NOISE MY FREEZER IS MAKING A CLICKING NOISE, AND THE ICE DISPENSER IS NOT WORKING. EVERYTIME IT CLICKS THE INSIDE LIGHT FLICKERS.
    Problem Solver:
It is probably *********** board or your main control board samething if your refrigerator is less than 36 months old they are replacing these for free 1-800-386-1215 for a free replacement
Posted on Nov 02, 2008
Just bought a used westinghouse RJ275M fridge. It seems to work fine except for the noise - it has a low hum and rattling noise.
It can be compressor fan noise,may be motor getting overheated and causing noise.It has to be inspected.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
We have a 25.4 cubic Whirlpool side-by-side fridge/freezer stainless steel look. Since the last 2 weeks....the display lights showing temperatures in fridge and freezer the front water/ice dispenser unit...
the clicking is from the lamp relay which makes the lights flicker and its located on the units rear area in the back,without a model number i cant tell what this boards model number is but you need to replace this whole board as they are non repairable(this is usually caused by a power surge or outage,which can destroy these boards,also even if a lamp in the unit burns out this can destroy this board too)
Mar 23, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
HI I hope I have reached Sea Breeze because I see someone had the same or similar problem as we are having from our GE GSS25... side by side refrigerator. this person wrote: "Water now comes out but only...
You have a bad main control board . Located behind the refrig , behind an 8 X 10 " panel . Easily replaceable . Sorry , not Seabreeze . You can reach him at seabreeze appliance parts . com , I think .
Sep 08, 2010 | Refrigerators
I have a Hot Point HSM25GFRF SA refrigerator, first the ice maker / water stopped working then the the refrigerator started making a clicking noise and every time it clicks the fsn does one rotation then...
I have the exact same problem.
It stopped dispensing water and ice, then it started to make a clicking noise and now the freezer and the refrigerator don't work.
It's interesting that this failure occurred 3 months after the 5 year warranty expiration.
Apr 13, 2010 | Hotpoint Refrigerators
Door mounted ice dispenser does not work, lights dim when pushed cyclic "clicking" noise coming from back of unit which causes the lights inside as well as those plugged into same circuit to dim when it...
the clicking noise is your water valve operating, or not
if its causing the light to dim, your loosing ground
somewhere in the circuit.
juding by your diagnososis i would have to think your selector board on the freezer door is bad..
probaly a your shorted somewhere in the logic board
and thats why your loosing gorund
Oct 12, 2009 | Hotpoint HSS25GFP Side by Side...
GSS201EPJWW side by side refrigerator
I HAVE TRIED A BLOW DRYER ON THE INSIDE OF THE FREEZER DOOR WHERE THE ICE GOES INTO FOR 5 - 10 MIN.AND IT STARTED WORKING AGAIN  :-)
Aug 18, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice and water dispenser not working but light on constantly
We had the same problem. When we removed the ice receptical the mechanism that turned the ice make was broken and it stopped the ice from being dispensed. I hope it is that simple for you!
Aug 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
280 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
