Question about Panasonic PV-GS500 Camcorder
Video cam flip-out screen problem
Hi. I have a Panasonice PV-G50D video camera. When I flip out the screen it will initally come on but as I open the screen all the way it goes off. If I open it
really, really slow, it will stay on but that takes minutes. How do I fix the problem quickly and cheaply, maybe myself? Do I need to replace the ribbon connector between the screen and the camera? Thanx!
  • jcr5 Dec 03, 2008
    Mine works only when inverted and reversed ( i.e flip screen and lens point the same way)
    Problem Solver:
  • 6 Answers
You're on the right track. Ribbon cables rarely fail from flexing. That's what their made to do, thousands or tens of thousands of times. But maybe one end has slipped part way out of the blade clamp from twisting the display more than 180 degrees. Or there could be some corrosion causing high resistance. I would at least take the case apart enough to inspect the cable and reseat the connections. But write down or video tape the disassembly steps and where each screw goes so you can get it all back together properly. Some brands use identical screws (thanks Sony) and some use a maddening array of different length and different thread pitches (metal vs. plastic threads). If you don't have a service manual, you'll have to experiment to find the proper disassembly steps. Sometimes it's straightforward, sometimes it's like a Rubic's Cube with hidden latches or interlocking pieces.
Posted on Nov 01, 2008
Drivers installation digital camera pv-gs29
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support
May 02, 2011 | Panasonic PV-GS29 Mini DV Digital...
Please, I have a kind of digital Kamra PANASONICE NV-GS15 I want a program to read on your computer
To get the videos on your PC you will need a firewire cable to connect (USB is not working for videos on this model). plug it in, Open up windows movie maker, click 'capture from video device' Choose your cam, Click next, Choose best quality, Make sure ur cam is set too playback mode, Click play on your cam and start capture then click stop capture when finished. No other software is required.
Oct 09, 2010 | Panasonic NV-GS15 Mini DV Digital...
Need and and all USB Drivers for my Panasonic PV-GS180 Video Cam.. I want to use the USB to transfer my media from Camera to Computer. Thankyou.
You can use the disc that is provided with the cam install the software from the disc then connect the cam with the PC and wait a while until the driver get installed.
Aug 18, 2010 | Panasonic PV-GS180 Mini DV Digital...
When i flip open the side view finder, i get a blank screen. it works only when the screen is half way open.
It sounds like the ribbon cable has worked itself loose either on the flip or the main body of the camera itself.
If you are confident that you can can take the camera apart and check the cables then all you will need is a set of precision screwdrivers, patience and steady hands as you will be working with delicate parts.
If your not confident with repairing yourself then i recommend that you take the camera to a specialist.
Nov 09, 2009 | Panasonic Palmcorder PV-GS120 Mini DV...
Panasonic pv gs 180 can't import into imovie
Hi, I managed to down load mine by connecting with a firewire and setting the camera to playback mode (not PC), opening imovie, turning the camcorder on and selecting file -' import from camera". a screen came up then I started playback on the camcorder and was able to select import from the screen on the imac.
Sep 28, 2009 | Panasonic PV-GS180 Mini DV Digital...
Can my panasonic pv gs35 work with Vista need software
To see videos,
you need to use firewire cable.
Its a 4 pin firewire which look like this:
After connecting,
Switch on the Cam.
Open Windows Movie Maker and import video from device.
Sep 26, 2008 | Panasonic PV-GS35 Mini DV Digital...
Panasonic nv gs5 digi video cam flip screen not working
Yes. It probably shorts in the wiring in the hinged area.
Jul 20, 2008 | Panasonic NV-GS5B Mini DV Digital...
How to fix my sidekick two camera
flip open your sidekick 2 screen then launch the camera. it will re-init the camera and it will function again
May 04, 2008 | T-Mobile Sidekick II
My Panasonic Palmcorder PV-L353 VHS Shuts off after about 10 mins.
oh, just found out this is actually normal, it switches to stand-by mode automatically, but my cam only stays on for 18 seconds wen a tape is in, and it wont record or playback...
Oct 27, 2007 | Panasonic Palmcorder PV-L353 Camcorder
LCD screen goes black when opened
the flex wire of the lcd monitor is already cut ...go the service center for replacement of the flex wire...or to the other service center for fixing the flex is to difficult to fix the wire if you are not a technician cause that wire is like a strand of hair...
Sep 07, 2007 | Panasonic PV-GS19 Mini DV Digital...
Panasonic PV-GS500 Camcorder Logo
123 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
