Question about Star Logic 17" LCD Monitor
Out of range
When i boot up comp windows icons show then on screen comesup out of range
  • freshisalive Nov 16, 2008
    my screen will come up until it comes up out of range
  • 558 Answers
You will lhave to start the machine in safe mode and return the refresh and resolution to min to get the video back up
after that you may raise the resolution and refresh until it fails again and do nothing it will return to the last seting and you can leave the setting there, hope this helps
Posted on Dec 03, 2008
  • Scott Hill
    Scott Hill Mar 21, 2009
    some monitors can not support the output range of the video cards in the computer. that is just the way it is for instance, a 15 inch LCD monitor will not go above 1024x768 resolution most times, but a 17 inch monitor will go up to 1280x1024, if the video card goes higher it will force the monitor "out of range" also the cycles on the monitor display tab can be changed to 50hz up to 75 or even 85hz but if the monitor can not handle this cycle rate then it will display "out of range". hope this helps someone.
Startup screen
select the first boot option and press enter
Dec 02, 2013 | Gateway Computers & Internet
My wireless network adapter is causing blue=screens i do not know how to uninstall a driver that i cant see without the adapter in. My comp does not boot windows to be able to manage devices before crash...
Alright, here's a potential solution for you:
1) Take the wireless adapter out of your computer.
2) Open the Control Panel, then click System, then access the Device Manager.
3) Click View, and then Show Hidden Devices.
4) The wireless card should be visible under the Network Adapters heading, and it probably has some icon on it to tell you there's a problem (the problem is you took the card out).
5) Right-click on the device and select Properties.
6) Uninstall the driver.
Also, some drivers show up in the Programs and Features (formerly Add/Remove Programs) menu in the Control Panel, so that's another possible way to remove the driver. Good luck!
Mar 14, 2011 | TP-LINK TL-WN350G, 54Mbps Wireless PCI...
The laptop loads up, lets me sign in, then goes blank, no icons
Try booting to the safe mode (F8 at boot) and see if you can log in via the safe mode. If you can't, try booting to your Windows CD, go to recovery console and run CHKDSK /R
If you still can't log in, try running diags see if the hard drive lists a failure.
if no hardware failure found, there and none of those solutions work, then re-installing windows will likely be the final resolution
Oct 06, 2009 | Dell Vostro 1500 Notebook
I have windows xp a lot of times when I restart my computer a white screen comes up it wont re-boot at times it boots up with a white screen
sounds like its a software problem , however its wise to rule out if its a hardware problem, best thing to do is try to start it up in safemode , this is easily done by retarting comp and pressing F8. now if safe mode shows your desktop it is most likely software, save any file you dont want to loose and try remastering if your comp came with installation disc restart with disc inside . if not it probably has a partition you need to look in manual for the remastering solution to this , could be retart f11 or retart f8 , every comp is different , best advice is to google your model for remastering my computer. good luck
Aug 31, 2009 | HP Pavilion A720N PC Desktop
Change xp bootscreen resolution
You can not change the bootscreen resolution. The bootscreen has to be 640x480 px and 16 colors. Nothing else will work.
There is a great video about how to change your boot and logon screen in Windows XP. Look here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 19, 2009 | Microsoft Windows XP Professional
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
How do i transfer data from windows 98 formatted drives 2 xp ones
Set up your old drive as a slave and copy the data. Good luck.
Jun 19, 2009 | Computers & Internet
Flatscreen goes blank and displays the message
Out of range indicates that the refresh rate or resolution is set too high for the monitor to display. I would suggest re booting into safe mode by pressing F8 during boot, before windows begins to load. Select safe mode with networking if you can, and once in safe mode, uninstall the ati display driver from the control panel. Then go to ATI's site and download the latest driver for your card. Save that file to your desktop. Reboot normally, as Windows should load default vga drivers for your card. Once in Windows, install the latest driver you just downloaded. That should reset the resoultion to one that your monitor can display. Good luck:)
Jan 02, 2009 | ATI RADEON X1650 Graphic Card
No icons appear when we turn our computer on
try this >>>
right click anywhere on your desktop, point your mouse to " arrange icons by" and in the box that will appear click "show desktop icons"
Oct 21, 2008 | Toshiba Satellite A135 Notebook
Star Logic 17" LCD Monitor Logo
74 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
ray gallant
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
