HP f1905  19 in. Flat Panel LCD Monitor
Problem for HP f1905 (Gray) 19 in. Flat Panel LCD Monitor
Removing casing from HP vs19/f1905 monitor
By mocha_jo on Oct 31, 2008
What is the best way to get the casing apart on this monitor? Like so many other people, my screen is now blank and from what I read here, it may be the capacitors.
Comments:
Mar 16, 2009
- I thought it was from this site but I could be mistaken. I don't have a digital camera to take a picture of the inside of the monitor. Also, the person who was going to try to take the monitor apart has been reluctant to try it as of yet.
Same Problem
Dec 03, 2008
-   My screen is white
-   Guest
Best Solution
posted on Mar 14, 2009
Helpful)
ced70
Rank: Guru
Rating: 90%, 28 votes
I also have a white screen. I checked the capacitors on mine....well at least visually and I did not see anything wrong with them. No bulges. Any other good way to check them? So do you have any links to the areas you have been reading about on these? It seems to me on the larger board and I definitely have a resistor that actually burned the board. It has a black mark on it. Not sure if that has to do with a capacitor or not. Tell you what when you get your face plate off email me a picture of the main board at ced70@hotmail.com and let me check if I am missing a capacitor. I have a spot that looks like a capacitor should be there but it is not. We can also compare resistance reading at different points to see if we can tell where the problem is.
To answer your question I popped it off with 2 small flat head screwdrivers. I took the stand off first (5 screws I think and then popped the front face off and then removed 4 screws on the side. After that just pull the panel display out slowly and disconnect the ribbon cables. There you have it.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for HP f1905 19 in. Flat Panel
Questions and Unsolved Problems for HP f1905 19 in. Flat Panel
Do you recommend HP f1905 (Gray) 19 in. Flat Panel LCD Monitor?
Answer
Answer
There is a yellow vertical strip on the right hand side. What happens?
Answer
Lost all color except black. The windows have faded making it very hard to read script including the... (More)
Answer
power light flashes on monitor but will not turn onthis is an hp f1905 lcd monitor
Answer
HP f1905 monitor problem. The monitor does not turn on after going into the sleep mode. I then have... (More)
Describe your Monitors problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitor Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
