Dishwasher is near new. it has a e4 fault message that means that it has too much water. however it does not have any water in it. We have cleared the drain pipe and checked the filters.
SOURCE: how to clear a delonghi dishwasher error code 4
Try removing all dish trays and salt softner lid, check if the salt softner compartment is full of water, if so place the machine on its side and allow all the water to drain from the compartment, once this is done your machine should be good to go. This is how i resolved my problem. The salt softner is located next to the water drain filter.
SOURCE: bosch classixx dishwasher not draining
try removing pump some models can be serviced fron inside well of machine glass can stop the pump from turning
clean out water and remove filters find a screw in base of well remove and remove pump housing check with torch to see if any obstuctions there if not see if the impellor moves around when turned and make shure that the pump is not worn out
SOURCE: Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
SOURCE: Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
