Question about Hardware & Accessories
Grasslin Digital wall mounted timer programme setting instructions please
My wall mounted digital timer was set to operate a door lock and my wife in order to change the time to -1hr. She pressed the wrong button and the timer now only flashing the seven day numbers (1 2 3 4 5 6 7 ) and the door lock is open all the time . I have no instructions.
How do I re-set to seven days programme or can I recover the existing settings PLEASE HELP my e-mail address is orhanugur@hotmail.co.uk
  • 1 more comment
  • kkkirby Jan 07, 2009
    kkkirby@hotmail.co.uk
  • Anonymous Mar 30, 2014
    no operating instructions
    I have a jasco 15150 digital timer the lights go out automatically but won't come on the time set automatically Wut am I doin wrong somebody help
Pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
  • Alan Aldridge May 17, 2011
    Thank you very much, this has enabled me to set the automatic watering system in the greenhouse while I am on holiday.
    Rozalan, Dorset
L have a Grasslin T35/16 without thr manual want to know how to programm it or use it
Grasslin T35 appears to be ordinary 24-hour analog timer.
Copy following link for instructions by experimenting with timer features
http://waterheatertimer.org/How-to-set-timers.html
Aug 30, 2012 | Hardware & Accessories
Instruction manual G1921 Grasslin Digital Timer
I don't have a manual for Grasslin G1921 timer.
You posted under photo of GE15079 which coincidentally has same buttons, but may or may not have same programming
Open following link to identify timer similarities.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
GE 15079 manual:
http://waterheatertimer.org/pdf/GE-15042-15079-15089.pdf
Add a comment and say if these timers are both programmable with same instructions.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 04, 2011 | Jasco 15079 SevenDay TwoOutlet Digital...
I do have and Intermatic ET724 timer and it has stopped working. I don't think it works with battery as it is attached to our bathroom light switch . any luck to fix it? or it is time for a new one??
That's a good old timer.
Grasslin ET724 in-wall timer is no longer available.
http://www.amazon.com/GRASSLIN-ET724-Grasslin-Et724-Electronic/dp/B000BHCFT6
There are several programmable timers on the market.
Intermatic EJ500 is simple to install and program. Works on battery but is for incandescent light only, not for fans.
http://www.amazon.com/Intermatic-EJ500C-Indoor-Digital-Switch/dp/B000E8VAIO
GE 15071 from Home Deport is inexpensive replacement and works with fans, lights.
Needs no battery. Uses electric circuit to operate clock.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
More timers:
http://waterheatertimer.org/Programmable.html
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 20, 2011 | Intermatic ET724-A-CS - 24Hr. and/or 7-Day...
Can't set timer
You posted under Grasslin in-wall mechanical timer.
Instructions for this timer are nearly identical to GE
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
First, the timer has to be wired correctly, so review wiring instructions shown on link above.
Next, the pins have to be set, so read instructions and look at image of pins shown on link above.
Last, the timer switch has to me set. I believe timer switch is moved all the way right for timer program to operate.
To check operation, manually rotate dial clockwise to watch lights turn on-off.
This will tell you exactly how to set pins and switch.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial rotates as time passes, and pins trip a lever that opens and closes switch to your lights.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 08, 2011 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
I have lost the instruction sheet for operation. Can't remember how to set it. Model ET160
ET160 is a UPM plug-in type digital timer
http://waterheatertimer.org/pdf/UPM-ET160-wall-timer.pdf
If you have problems with specific part of manual, add a comment and I will answer
Oct 30, 2010 | UPM Indoor Electronic Programmable Plug-In...
Hardware & Accessories Logo
4,556 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
