Question about Sony VPL-VW100 (Ruby) Multimedia Projector
Sometimes it will not come on...
If it comes on its a great projector. lately it does not always come on. I press "on" a 100 times it does not come on. Then the next day it comes on and plays like nothing happened. I have made sure the cover is on, the filter screen is clean - no change. When it does not come on it clicks 4 times - when it does work it clicks (different sound) once and there it is. Sounds like there is a relay that does not always make contact. help. I just know that if I turn it in someplace that it will work always until I take it home. Help Help
  • racer60 Oct 31, 2008
    Can I have a second opinion
    If it does come on it will work great all day long. Would that be the case if a Capacitor is bad?
Contact your local Sony service and ask them to install a "hard start kit mod" in your Ruby. That solves the starting up problems! This usually goes under warranty.
Posted on Dec 29, 2008
  • 905 Answers
There is a protection circut that detects when there is a voltage change , and if it is not correct then the relay will not stay on or it may take a long time for the protection circut to get the power correctly
this could be the cause of a bad power transformer( wires not creating a good magnetic field) or the protection circut is not working correctly anymore
it will need to be taken to an electronic repair shop to determine the exact cause of the power not engaging and working correctly
electech
Posted on Oct 31, 2008
    Scholar:
  • 155 Answers
Its the problem in the board mostly  .check out any bulged up capacitors or any capacitor loose on the main board which is not letting the projector to get ON.it could also be the switch which you r pressing on the projector to make it on as sometimes its getting pressed properly and other times it is missing the contact on the main board.just on the main board check out this back of the switch if the button is loose on the circuit board that might be the problem.just resolder that button and then check it should work.
thanks.
  • 320 Answers
I have the service and training manuals for this model and have worked on a few. Are you getting any flashing LED lights when the set does not power on correctly?
  • 1 more comment
  • Any Guy
    Any Guy Oct 31, 2008
    Also,
    Pleases try removing the power and waiting about 3 or 4 minutes and then plugging it back in and telling me how many relay clicks you here as that is important. Please disregard some of the solutions posted here, I am a Sony trained technician and will do my vest to assist you in narrowing down the problem.
  • Any Guy
    Fixexpert, this repair is outside your expertise, please leave it to one of the qualified experts. Thanks!
  • Any Guy
    Depending on the number of clicks you hear when you first apply power, it could be one of 4 different boards. Can you take voltage measurements?
  • Sony Master
  • 13,433 Answers
Hey,
this is most likely a problem in the power adapter or power board. Best solution is to get it looked at by a professional, if you are going to look at it yourself, look for bulky and or broken capasitors.
here are some clearly faulty capasitors, leaked
  • Ekse Oct 31, 2008
    I would say its definitely a problem with the power board.
Hello., I've just tried to power up a Proxima 9310., and for the first time in my experience the orange light has come on and shut down has effected after a couple of seconds. I would like to ask for...
hi,
Time to replace the lamp of you projector.Lighting up of the orange light indicates that. All the projectors comes with self disorganizing program. if there is any complaint except power supply that will indicated by the projector by its self disorganizing system.
switch OFF the projector for some time. then power it ON. if picture come then first of all reset the lamp hour timer. To do the same do the follwing
1. Press the menu button and press rear click button or select button
2. Select settings press the rear click or select button
3. On setting display select Lamp age and press the rear click or select button
4. Move the arrow to Yes and press the rear click select button
OK will displayed and wait for your conformation
5. Move the arrow to Yes and press the rear click or select button
if there is no picture when you switch on the projector then go for a new lamp. you hve to do the reset procedure after replacing the lamp. It is always recommended the you should reset the lamp hour only after replacing the lamp.
ok
Apr 04, 2011 | InFocus Proxima Pro AV 9310 Multimedia...
Mitsubishi WS-65611 losing HD signal
Not to worry.Its really a Great tv...But...the only thing you should do to fix this just get it hd ready and your and dont get it integrated with an hd receiver and everything will be fine!
Oct 11, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Projector turns on. The blue screen comes on. After the ben Q symbol disapears a warning measage comes up 2004 hrs, change bolb if not bright. Then picture disapears and the temp light comes on! Any...
hi,
its because ur lamps life comes on its end. its time to replace the lamp. after replacing u should rest the lamp timer to zero. if u have already replaced the lamp do the following,if not also.
1 Press and hold the Exit (up arrow) button on the projector for 5
seconds to display the total used lamp time.
2.Press Auto button the projector or on the remote control to
reset the lamp hour to "0".
3. Wait about 5 seconds to let the OSD disappear.
ok
Dec 22, 2010 | BenQ PB6110 Multimedia Projector
When I turn on my ViewSonic Precision 1080P projector on the indicator status light flashes red and sometimes the projector still comes on but currently it is not interfacing with the receiver. I just see...
I found out how to reset the "clean" icon on the status menu and then moved some connecting wires around on my receiver. They were not totally connected. works great now. Thanks
Jan 02, 2010 | ViewSonic Precision Pro8100 Projector
PLV-Z2 Won't come on.
Hi There,
Yup you definatly have a temp sensor issue. But dont worry, Its not a major issue. Ive had a plv-z3, and a plc-sw35,And both projectors gave me a temp sensor issue at one time or another. Its just a sanyo thing...
Heres what happend.. The ambient temp inside the projector shouldnt reach more than 100 degrees celcius, when it does the temp sensor (which looks like a small black pot, with a shaft, and a ceramic white tip) Opens up, and cuts off the high voltage supply to the projector, A fail safe to prevent any major damage. What essentially should happen is, that once the projector has cooled, the temp sensor should return to normal possition, and allow normal operation... BUT... sometimes it doesnt. And until you manually push the shft back down, You projector wont work again.
What you need to do, Is take off the top cover, Locate the sensor (its normally mounted next to, or on the lamp housing) And push on the white tip with a pen or small screwdriver to close the circut again.
Here it a full service manual for a plv-z3, which is almost identical to your unit.http://yama.co.za/forum/index.php?topic=147.0
Hope Ive helped in some way. :)
good luck
May 16, 2009 | Sanyo PLV-Z2 Multimedia Projector
Comes on but won't project from laptop
Plug it into the s-video port and press the combination of buttone for your computer, that assigns a different monitor. Mine is FN + F5, yours could be different.
Feb 12, 2009 | Optoma EP716 Multimedia Projector
Indicator lights on, no function, no fan, no lamp
Press the MENU button to display the "MAIN MENU", and then select "OPTION".
Press the ENTER button to display the "OPTION" menu, and then select "LAMP RUNTIME".
Press and hold the ENTER button for approximately 3 seconds.
The "LAMP RUNTIME" will change to "TIME RESET [POWER OFF]".
Turn off the power and disconnect the power cord.
This will reset the cumulative usage time for the lamp unit to "0".
Oct 11, 2008 | Panasonic PT-LB20U Multimedia Projector
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
185 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
