Question about Samsung SC-D103 Mini DV Digital Camcorder
Can't record My camera is giving me the "tape protection" display, but the protection on the tape is turned off. I am positive its not the tape, I've tried many different tapes with the protection off and had no luck. Is there anything i can do, or am I stuck.
  • 9 more comments
  • Anonymous Nov 26, 2007
    same problem
    pls help
  • hardworker Dec 08, 2007
    can't record tape protection display. got a new battery it did not help
  • mrussum Dec 14, 2007
    Hi, I have the same problem. I get the word "protection" flashing on my screen. It has a new battery fully charged. It also has a Symbol and the letter "R" on the screen.
    mailto:mrussum@cableone.net
    Thank you
  • Anonymous Dec 19, 2007
    flashing yellow "protection" lame ass shit
  • sha-ney-ney Dec 20, 2007
    yes. i have the same problem and tried everything. The yellow protection keeps blinking and you can't record anything. But i can watch the previous video i recored earlier.
  • Joe McQ Dec 25, 2007
    camcorder is displaying protection sign and won't allow me to record.
  • gmdeleon Jan 07, 2008
    have the same problem. tried changing tapes, batteries, downloading the pictures off the memory card, tried removing the memory card, tried different memory cards but nothing works. Please help
  • Anonymous Feb 17, 2008
    i have the same problen can't remove the protection from camara
    can't remove protection
  • dipolo Feb 20, 2008
    HELLO,
    MY PROBLEM WITH THE CAMERA IS THE SAME, I CAN'T REMOVE THE PROTECTION, AS CONSEQUENCE I CAN'T RECORD ANYTHING.
    I SAW THE MANUAL, I TRIED TO FIX IT FOLLOWING THE MANUAL BUT I COULD NOT DO IT.
  • Alex1088 Feb 27, 2008
    Has no one found a solution? I've been having the SAME problem
Same problem here
Posted on Jul 05, 2008
Same problem here.
Posted on Mar 25, 2008
I am having the same problem..
Posted on Dec 21, 2007
I have the same problem!
Apparently their is a ribbon cable on the tape drive mechanism that tore because of samsung's crappy design that ribbon cable sends a signal form the tape protection switch.
Since the ribbon is torn and the circuit open the camera thinks the protection on the tape is on
if any one knows where i can buy samsung parts, please let me know
Posted on Jul 07, 2008
Sony CCD TRV12 once I place tape, i cant rewind, fast forward, play or record. I get an up arrow with underline. According to the manual, it should be the red tab on the tape in the save position. But...
your protection switch is jammed to the on position its a ver small slide arm insert tapes take them out and give the camera a little knock try to spring it back into off mode
Dec 25, 2010 | Sony Handycam CCD-TRV12 Camcorder
WHEN I PUT MY JVC GR-D770U IN VIDEO MODE TO RECORD VIDEOS, AN ERROR MESSAGE IS DISPLAYED THAT SAYS, "CHECK TAPE PROTECTION TAB". HOW DO I TAKE CAMERA OFF PROTECTION MODE SO I CAN RECORD VIDEOS?
Mini-DV tapes have a small physical switch on them to protect the contents from being overwritten. It is probably just that this switch is set, not a problem with the camera.
Oct 31, 2010 | JVC GR-D850 Mini DV Camcorder
Tape doesn't stay down, keeps popping back out of cassette, on my Sony CCD-TVR608. Any ideas?
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Aug 17, 2010 | Sony Handycam CCD-TRV608 Camcorder
Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Dec 29, 2009 | Sony DCR-HC28E Camcorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Wont let me record! Flashes "Protection!"
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Feb 08, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung VP-D102D Camcorder
Remove the DV tape from the camcorder and check the position of the red tab on top of the tape. Reverse the position and see if it protection goes away.
Jan 17, 2009 | Samsung SC-D105 Mini DV Digital Camcorder
Problem when Trying to record
If you are trying to record to a tape and the display shows "Protection", you must slide the protection tab at the top of the tape to the "Rec" position.
Jul 23, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Sharp Viewcam VL-AH151 Hi-8
Make sure the little red tab on top of the tape is set to record and not save. The camcorder will not let you record it its set to save
Jan 20, 2008 | Sharp Viewcam VL-AH151U Camcorder
Samsung SC-D103 Mini DV Digital Camcorder Logo
402 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
