Question about Maytag Dryers
Dryer was working fine. Opened door, then dryer stopped running, will not start. Has done this before. After drying sitting for a while unused, would work again. Now not working again.
  • 67 Answers
There is a saftey switch that is activated and deactivated by the door maybe its faulty
Posted on Oct 31, 2008
Dryer continues to run when I open the dryer door.
The door lock is more than just a latch; it is an electrical interlock. From your description it is likely that the interlock has failed
Jun 02, 2013 | Maytag Neptune MCE8000AY Electric Dryer
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
Electric dryer was running fine.had towels in there an opened door to check how wet an noticed it was really hot inside an then closed it an went to pull knob outward to start the dryer again an it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Dryer stopped working, sounds like timer still running
I suspect it is the thermal fuse. Seen here. You will need to determine what caused it to blow. on these machines the blower wheel is notorious for getting loose and causing the element to over heat. This makes the heating element shut down faster and takes a long time to dry the clothes. 7fc125e.jpg
Apr 10, 2010 | Magic Chef CYE4000AWW Electric Dryer
Kenmore 70 dryer smells burnt
There could be dust settled on the motor inside from the few years in storage. Unplug and remove back, with a hoover brush **** off all dust but do this lightly as to not disturb any connections.
Jan 04, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Timer runs continuously - Does not stop at all
There should be a timer motor on the timer. That is most likely burnt out and will cause the timer to not shut down. Just replace the timer and that will solve the problem
Jan 01, 2009 | Maytag Neptune MDE4000 Electric Dryer
Whirlpool Dryer won't start
You probably had been using the dryer alot today. As long as the motor was running there was enough air flow over the motor to keep it just cool enough to allow it to continue to run. When you stopped the dryer the heat tripped the thermal protector in the motor. Let it sit an hour or so and it should restart. The motor is probably coated in dryer lint, and / or the motor bearings are getting bad. If you space your drying loads out a bit you can get by for a long time without having to do anything.
Sep 16, 2008 | Dryers
Dryers Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
