Question about byD sign d:4232 42 in. HD-Ready Plasma Television
Tv hookup with cable line
When i pug in the cable wire I Have to keep moveing it around to try to get a picture .
  • 67 Answers
There maybe a loose connection in the tv (connection port) or cable is broken
Posted on Oct 31, 2008
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
High pitch noise
Sorry to hear about your issue, let me see if I can help.
What type of tv is this? tube or flat panel? If tube, have you recently moved it and shook it up a little?
If panel, are you using an hdmi hookup or just regular cable from a cable box?
Be sure that your hookups are on tightly and that your cables are not tangled as well especially hdmi cable. Let me know if any of this is helpful in solving your issue or if I can be of more assistance. Once you respond I can help more, just need more information..
Thanks,
d
Feb 26, 2008 | Sanyo DS31520 31" TV
Hi, I have an old sony trinitron ku27ts27 and out of the blue yesterday it went to snow on me it's not the cable system, how can I get to somesort of setup menu when there isn't a setup button? Thanks...
Try knocking on the cable connector whith the cable pugged in and the set on and also put the tv on a channel between 2 and 13, if the picture comes back then you have bad solder joint in or around tuner ***`y. you may also want to check you cable connectors. the tv setup won`t help you here. good luck
Oct 31, 2009 | Sony FD Trinitron WEGA KV-27HS420 27" TV
Cable box-dvd/vcr- tv hookup problems
buy you one of those little boxes from like walmart,,that converts rca jacks to cable pugs ,,,there real cheap,,that will do it ,,in the electrinic isle,,
May 17, 2009 | Philips Magnavox DVD/VCR Dual Player
NO VOLUME
first use only a coaxcil cable to hook up to tv ;second try using standard colored wire hookup (red/white/yellow if you can0 third make sure all cables are plug in tight and in the right area. If still nothing the try adjusting volume on tv and the dvd recorder before you do any of these things.
Apr 02, 2009 | Cyberhome DVR 1600 DVD Recorder
TV & DVD HookUp (No Box) Can't get picture
As far as I know, my Go Video machine when there was no box involved...
The cable came from the wall to the IN of the Go Video box. Then another cable coming from the OUT of the video box and to the IN to the TV. TV should be on channel 3. As far as I can remember, I don't need to push the TV/VCR button, but instead, have to channel down to below channel 2 on the TV to the LINE/INPUT selection. Once you go there, and the Go-Video machine is on, you should be able to see a clear picture.
You'll push the TV/VCR button if you want to toggle back and forth from the VCR picture to the TV picture (which will be technically blank since it's on the 'line input selection.)
Hope that helps.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
Olevia 30 HVS
I had the same problem. I unplugged my tv to move to another room and it will not cut on at all. I have only had the tv for three years
Dec 12, 2007 | Syntax LT30HV 30 in. HD-Ready LCD...
See lines in HD cable or DVD source images, also maybe a problem w/ color, see extra blue haze
It sounds like convergence problem to me. There are two ways to correct these concerns; Samsung does sell boards, so if you are handy you can replace the boards yourself. BUT I recommend calling a factory authorized service company. It isn't costly, the cost will run around $400 -$550.
Aug 14, 2007 | Samsung HCL4715W 47" Rear Projection...
byD sign d:4232 42 in. HD-Ready Plasma Television Logo
107 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
