Question about Sanyo SR-4910M Compact Refrigerator
Broken shelf I broke the bottom shelf on the door and I'm having trouble finding any information on where to get a replacement. Duct tape is not working!
  • 3 more comments
  • suzy lovestrand Nov 27, 2006
    Thanks for the help! The model is SR-4910M, serial #040408906
  • Anonymous Nov 19, 2007
    broke a fridge shelf, and i can't find a replacement part. Help! thanks
  • Bakerygirl Feb 15, 2008
    I have a broken door shelf in the upper refrigerator section of my viking. All I need is the transparent bottom part of one of the small door compartments. Thanks for any help on where to find one.
  • ash_receiver Mar 31, 2008
    I am also having trouble finding replacement shelves for a Sanyo Stainless Steel mini fridge, Eclipse series, serial number SR 4431S... Any help would be greatly appreciated.
    Thanks!
  • LNess Apr 22, 2008
    Need a shelf for this refrigerator. Original material calls it a "slide out tray"
We did too... me and my wife bought some gorrilla glue and glued it.. worked great since.
Posted on Apr 26, 2007
Hello I have the same problem can you sugest a place to look for this part?
Posted on Feb 08, 2008
  • 26 Answers
Dear Zuzy,
A friend told me about JB Weld and it really is great for joining things back together. I have fixed one broken shelf already by adding some aluminum to the area that was weak and then glueing it with this JB Weld stuff. The shelf I needed was going to be $49.
I can send you a photo of what I did if you want. HarryF
Posted on Dec 22, 2007
I also broke a glass shelf in my Maytag refrigerator. I took the measurement to a framing shop and got a lexan shelf. No more problem.
Posted on Apr 13, 2007
  • 237 Answers
Give me all the model number and serial number and I can likely give you a link to a replacement part.
Posted on Nov 09, 2006
My bag style RY7500 Vacuum has a broken hose.. i can't find the part to replace anywhere online. Also don't know how to remove/replace.
You don't mention where it broke. Is it broken off at the very end or in the middle somewhere. If the ends are still OK and you love that vac, you can fall back on an old trick used by the military in WWII - duct tape! Find another vac hose the same diameter (any vacuum repair store will have them in stock) or you can take a piece of hose to a home improvement store to match up.
Cut out the broken area as evenly as possible. Cut a new piece of hose the same size you removed so the hose remains the same length. Wipe off the edges to remove any dirt. Lay your tubing on newspaper or cardboard. Next you'll need a sealant that will not only stick the parts together, it will remain strong after drying. (Silicone or epoxy glues both work.) Work on ONE break at a time. Apply a thin bead between the two pieces & press together. DO NOT DISTURB but leave the pieces to dry 24hrs. After it's dry use duct tape to reinforce the break (trust me, you'll be glad you did). Then fix the other side of the cut-out.
If it broke off at the very end, remove the hose from the connectors on both ends. Clean out any old hose -if any - if the hose fits inside the connectors. If it fits over a connector, make sure the outside's clean & smooth. Insert/Apply a new hose using the sealant. Duct tape after it's dry. (Yeah, I love the stuff. Saves a ton of extra work by supporting the stressed area.)
If it's just a small crack in the hose clean the broken ends so there's no dirt. Fill the crack in the hose with a thin bead of sealant, dry & duct tape it.
I've used this trick many times, so I know it works. Good Luck!
Feb 11, 2015 | Royal RY7500 Bagged Upright Vacuum
The tailgate window latch is broken on my 2008 Mazda Tribute
Find a suitable replacement and use gorilla glass glue. Good luck.
Jan 06, 2018 | 2008 Mazda Tribute
The throttle cable broke off from the operator presence control bar
If the cable broke, you'll have to replace it, but if you're in a hurry to mow, try this: get 2" of wire and duct tape 1" to the upper broken cable, and 1" to the lower broken cable piece. Might work, and if it fails, nothing bad happens, the mower just stops. Good luck. Please rate if you find this helpful, thanks!
Jun 05, 2010 | Poulan Pro 22" Self Propelled High Wheel...
My drivers side window on my 1994 ford Taurus is stuck in the down position. how do i get it to go up and down again? the window motor is working ok. just that the window will not move
If the motor is working but the glass is not moving something must have broke inside the door. See if you can sneak a piece of duct tape down along side the glass, get it down as far as possible. Use a butter knife or something to make the tape stick to the glass, now try pulling the glass up with the tape. You may want run the window motor at the same time maybe it will catch. If you get the window up, tape it with duct tape so you can get it to a shop to get it fixed. Good luck.
Feb 21, 2010 | 1994 Ford Taurus
We have a subzero 201R and I need a door shelf replacement
subzero number 1800 222 78 20. EXCELLENT CUSTOMER SERVICE. depends in what part of the usa.they have information for your close store
Aug 02, 2009 | Sub-Zero Bottom Freezer Refrigerator
Cassete deck will not work, I put a tape in deck 2 and hit the record button and all it did is started to make a clicking noise. Next I tried to take tape out and the door would not open. I forcefully...
I have a sony twin cassete deck and the same thing happened to mine , it turned out to be the rubber belt inside was broken so i just bought a pack of assorted belts for $7.97 and replaced both belts .
Jun 05, 2009 | Aiwa NSX-A767 Shelf System
Broken Shelf and side shelf
only thing i can tell you is to go to a appliance parts store with the model # and they will find it for you
Aug 01, 2007 | Frigidaire GLRT83TES Top Freezer...
The tape cover raising mechanism is broken.
Tritronics Inc. is my parts supplier of choice. They usually have or can get any parts I need and their prices are reasonable. www.tritronicsinc.com. They are agents for just about every manufacturer and will research parts based on model no., location of part and/or part description. It sounds like you will need a new door if it is broken. I've tried glueing these lids before with limited success. Tritronics would have the service manual also which would help with disassembly. Good luck.
Dec 18, 2005 | Aiwa XR-MD100 Shelf System
Sanyo SR-4910M Compact Refrigerator Logo
1,476 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Steve
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
