Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Hotpoint aquarius deluxe1000 WM22 Its not working........
Hi Theres power to the washing machine but its not filling up with water and its not starting any of its programmes isit repairable or not
    President:
  • 1,294 Answers
Surely by now you've checked to see if your water inlet into the machine is good, ie turn on the taps. The machine wont start if there is no water coming in. Try the spin only function, it works??
Posted on Apr 15, 2007
  • prem mathew Apr 16, 2007
    What is the clothes capacity of the machine; try to limit within capacity. Try the "spin only" function aft putting the clothes. Then put the machine off & continue with the main cycle.
  • prem mathew Apr 27, 2007
    Have a look at where your drain hose is going. The highest point in the hose needs to be higher than the "minimum drainage hose height" line marked on the back of the machine.
    Washing machines don't have valves to keep the water in - they simply rely on the pump pushing water over the hump in the hose when you want to empty them, and the water not being able to climb the hill on its own the rest of the time.
Hotpoint aquarius will not heat water
Although I do not know your particular machine I strongly suspect that the heater element is malfunctioning/broken. Even if it is a hot and cold fill it still requires the element to heat the water up to the correct temperature for the selected wash. If it is cold fill only it certainly needs the element all of the time- apart from rinses!
Sorry but it depends now on who you have at hand to repair as to your next step.
John C
Feb 09, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
My washer/dryer will not fill with water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 23, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Electronic 800 WM 12 Aquarius won't rinse
If it won't rinse because it won't fill, it's most probably because the cold water inlet valve is faulty. Many machines will only rinse with cold water....No cold water.....No rinse!! Not a big job.....Nomess
Apr 13, 2010 | Washing Machines
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
WM 22 will not spin
yes.dose it drain,see it must drain before it can spinso if water is standing in it it wont spin and that would mean your pump is ither blocked or reciving power but not working.
Jan 01, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
247 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
