Question about Sony Ericsson Z525a Cellular Phone
Setup wizard i cant see the screen on my z525a and i want to get through the setup wizard by button press
    Problem Solver:
  • 8 Answers
First open your phone, then press upper right (-) key to get to menu. press joystick down 2 times, then right 1 time, to get to Settings. Press joystick center select button, press joystick down 9 times to get to Master Reset, press center select button. Joystick down 1 time to get Reset Device, press center select, then press upper left (-) key. This will delete all user settings & data, including pictures, messages, data, sounds, games, contacts etc. The phone will be restarted. If this doesn't fix the problem, you will most likely need to replace the internal wiring harness.(Not a job even I would enjoy!) Hope this helps.
Posted on Mar 21, 2009
I have a router i forget everything to it i cant get into it at all cant access the internet or nothing
To access a router on which you forgotten everything, do the following...
1. apply power to the router and connect an ethernet cable from PC to one of the router's LAN ports
2. press the router's reset button (usually located beside its power supply jack) for at least 5 seconds
3. (pressing reset for 5 seconds resets the router to its factory defaults)
4. with factory defaults, you can now use the Setup Wizard on the router's Setup CD-ROM
5. if no Setup CD or to configure advanced settings see router manual about web-based utility
6. open Internet Explorer and enter the router's default IP address (see router manual for address)
7. IE presents a login window for entry of router userid and password (see manual for defaults)
8. once into the router's Basic Setup screen, follow the steps in the router's manual to do the setup.
9. if your ISP requires a registered MAC address, enter it on the clone MAC address screen
10. for better wireless security, change router SSID from its default and enable WEP or WPA
Feb 22, 2011 | Computers & Internet
I have a hp photosmart c7200 all-in-printer and have a desktop which it is setup to. I also have a laptop which I'm tring to setup up wirelessly but having trobule. Any suggestions.
Have you run the Wireless setup wizard from Printer ? If No, Press Setup button on printer front panel - Scroll till Wireless/Network settings - Choose Wireless setup Wizard and follow the directions.
After you have setup printer on network - Run the Printer s/w disk and Choose Add a Device and Choose Wired/Wireless network and continue with the Installation screen.
Jun 24, 2010 | HP Photosmart C7280 Laser Printer
P990i touch screen not possible to calibrate
First, upgrade the software of the phone. After the upgrade, the setup wizard appears; complete it, and start it again from "Control panel", "Other", "setup wizard": now, just press the next button until 1 2 3 4 appears in the screen: don't select anything else, just the next button, or the calibration screen would not appear.
Jun 17, 2009 | Sony Ericsson P990i Cellular Phone
Z525a screen comes on but stays vacant.
If you have access to a laptop computer that has an Infrared Port or Bluetooth communications, you can download your videos and picture files via either of these two methods. I use an old IBM Thinkpad 600 with IR port to download mine. You have to put your z525 phone into Infrared mode first, its kind of tricky with out seeing what you are doing. First, open your phone, press upper right (-) sign to get menu, click joystick control down 2 times then right 1 time. next press upper left (-) sign to select. next joystick right 4 times, and down 1 time. press upper left (-) sign, then joystick up 1 time. press upper left (-) 1 time. Your Infrared Port will now be turned on, and your I.R. enabled laptop can now receive the files from your phone. Close your phone, open it again, press upper right (-) , press joystick down 1 time, then left 1 time, then press the joystick center select button 2 times. Joystick right 1 time, press joystick select 1 time. press upper right (-) 1 time, joystick down 5 times, joystick right 1 time, joystick down 3 times, joystick center select 1 time. Hold the lower left corner of your phone toward the I.R. port of the laptop, it will receive the first photo file in your camera pictures file. Another possible method would be to obtain a usb connector cable for the z525 phone to connect it to your computer. Using the usb cable the computer would recognize the phone, you could click on the phone icon, under "MyComputer" and transfer the files to your hard drive. I hope this helps. -Mike
Mar 09, 2009 | Sony Ericsson Z525a Cellular Phone
Problem with Setup Wizard for Linksys 2.4 GHz Wireless-G Broadband Router
burn disk reset router unplug power. plug ethernet cord to laptop to router type 192.168.1.1. then admin
admin
now you should be forwarded to router setup check settings hit save then go wireless security choose wpa2 choose password has to be a word atleast 8 letters long plus numbers
Aug 30, 2008 | Linksys Wireless-G WRT54G Router
Since you're having problem in setting this router up, the best to way to set it up is by doing a mnual configuration and you dont need to use the setup CD that came with it, I'm suggesting you to call the linksys tech support and they will walk you through on the manual setup it will only take about 10 minutes this is the number 800-3267114.
Hope that helps.........
Aug 13, 2008 | Linksys Wireless-G Broadband Router
I got an unlock code from att, now how do I enter it in phone (Z525a)?
try this steps :
Remove the SIM card from your phone
Turn on the phone with NO sim card at all in it, you will get a "insert smartchip" message
Press * * {Note: is the left joystick button}
Click on the "Network" item on the menu
Enter your unlock code and press OK
Jun 12, 2008 | Sony Ericsson Z525a Cellular Phone
Sony Ericsson Z525A-COPY PHONE NUMBERS TO SIM CARD -BLANK SCREEN
to retrieve your numbers you would need to follow these key strokes...
center, toggle down (1 time), center, toggle up (2 times), center, toggle down (5 times), center, toggle down (5 times), center (3 times)
then wait for quite some time...it takes a while to copy all of the contacts...I would say anywhere from 5 to 10 mins...
this should work to save your contacts.
To save your pictures (and any other data you might want to retrieve) you could buy Sony's data cable2.gif for the z525a. I haven't tried this but it should work since that is what the cable is for.
Its called a DCU-60 USB data cable, and is listed as being compatible with the z525a.
Dec 26, 2007 | Sony Ericsson Z525a Cellular Phone
Retrieve files from sony 525a with blank screen?
to turn on the bluetooth: center, toggle down (2 times), toggle left (1 time), center, toggle left (4 times), center (2 times). then the return button 3 times to go back to the "main screen". hope this helps
Dec 20, 2007 | Sony Ericsson Z525a Cellular Phone
Sony Ericsson Z525a Cellular Phone Logo
74 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
