Tracking button on remote for a citizen dvd / vcr player model 557dvc
I am trying to set the tracking on the vcr portion of this unit and I can not tell which buttons on the remote to use
  • 905 Answers
It should have auto tracking , but if you need to , then manual tracking settings will be arrows up / down , but your user manual should tell you how they set that up to work for manual , but sometimes even when you manualy set the tracking the auto tracking will take over again
electech
Posted on Oct 31, 2008
I need code(s) for my DVD Video, Model #: NB093 remote control to program my Philips DVD Player/VCR, Model #: DVP3345V/17. Can you please help me? I would greatly appreciate it. Here is a picture of it.
http://remotecodelist.com/remotes/magnavox/magnavox.htm lists the code for your device as possibly being 1000, 1001, 1002, 1003, 1004, or 1005. Of course, you also have the option of using the remote controller's "Code Search" button. 25300580-iv4burzhkawezvl2jbah1xae-2-0.jpg With Codes:
Turn on the DVD/VCR unit directly. Continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Enter the four-digit code (1000, 1001, 1002, 1003, 1004, or 1005) for the DVD/VCR unit. The remote controller's light should go off. Press the remote controller's power button, & when the DVD/VCR unit turns off, then you will know that the remote controller has been correctly programmed.
Without Codes:
With the DVD/VCR unit on, continue to depress the remote controller's "Code Search" button for about ten seconds, release, & the light on the remote controller should stay on. Continue to tap the remote controller's UP or DOWN channel button ONLY UNTIL the DVD/VCR unit responds. Then, press the power button on the remote controller once the channel has changed. If the DVD/VCR unit shuts off, then press the power button again to turn it back on. If the DVD/VCR unit turns on, then the remote controller has been correctly programmed. Otherwise, repeat this whole process until the remote controller is correctly programmed.
Nov 29, 2014 | Televison & Video
Adjust tracking go on go video vr3930
Tracking will only adjust on the VCR and may only be on the original remote.
Note that if there is tape debris or black residue on posts and guides or even video head drum tracking will not adjust--any debris will cause tape to move away from the drum resulting in a tracking like issue---tape cleaners rarely resolve this.
Jun 13, 2012 | GoVideo VR3845 DVD Recorder/VCR
Just hooked up my new Magnavox DV220MW9 DVD Player ? VCR Recorder. I was able to set the time and a vcr timer program but now I can't switch the source. It now comes on as the DVD but neither the remote...
You need to release the timer to access the VCR. Press the Timer Set button on the remote or the Stop/Eject button on the recorder. Then press the VCR button.
Please note: the scheduled recording will not run as programmed unless you press the Timer Set on the remote again. (The timer locks the VCR until the scheduled ON time.) The DVD player is controlled separately and becomes the default unit.
I hope this helps.
Oct 04, 2010 | Philips Magnavox DVD/VCR Dual Player
DVD Player doesn't work on DRC6355N VCR/DVD Combo
With most dvd/vcr combo units there is separate wiring. When I use my emerson combo unit I have it wired that I have to be on different inputs on my tv to view a dvd and a vhs. On some units the vcr portion is wired via a regular cable line, while the dvd portion is wired with the yellow, red, and white component cable. Try inserting a dvd and scrolling through your tv inputs until you find the picture or check your wiring to ensure nothing has come loose. If that has no result you could try wiring it differently if possible to eliminate that as a possibility.
Jul 10, 2010 | RCA DRC6355N DVD Player/VCR
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Ssd803 dvd won't recognize universal remote
Sorry to say that most universal remotes do not work well with combo devices ie. vcr/dvd, tv/vcr, and so on. One thing you can try doing is to program the vcr portion of the remote to controll the vcr side, and the dvd protion to control the dvd side. More than likeley there will be a lack of functionality since combination units have buttons that would not be needed on individual devices.
I have found that the Logitech Harmany universal remotes work very well with anything but they tend to cost quite a bit more. You might be able to find a basic model on ebay or amazon for around $50.
Apr 26, 2009 | Sylvania SSD803 DVD Player/VCR
Cannot use remote to play dvd or vcr
Check lower portion of remote, you will notice a button having 3 command modes. set it on DVD2 and operate dvd recorder with remote.
Jan 21, 2009 | Sony RDR-VX515 DVD Recorder/VCR
I need a code for Citizen 3818 DVD Player
I have a good Philips Universal the code is 1908 Press Code Search until red light comes on Press VCR/DVD light flashes Press 1908 Light goes off It should work.
Jun 11, 2007 | Jensen JR400 Remote Control
Televison & Video Logo
302 people viewed this question
Top Televison & Video Experts
