Question about Samsung RS2630SH Side by Side Refrigerator
Samsung RS21DCSV Side By Side Refrigerator
I cannot find the make of Samsung that I have but it looks very close to this one. My problem is that I can dispense water but the ice tray is not filling. When I hit the test button the ice tray rotates but again it does not fill with water. Has anyone had this problem before and do you know how to fix it please.
  • Anonymous Apr 18, 2008
    srs2028
  • Sean Gray
    Sean Gray Dec 26, 2016
    Really simple fix, it is a frozen water valve. You need to get yourself a big syringe and hot water. Remove the rubber flex pipe where the water comes out and get as much boiling hot water as you can in the exposed pipe, don't worry it will come straight back out. After you have put a couple of syringes down press the reset button. I cycled through this about 5 times. Now all is well
Don't buy another Samsung reffigerator. I won't. I and I will always tell everyone I know the same.
I paid over 1200.000 for my refrigerator in Nov 2006. It has never worked correctly. They have replaced everything on the back three times and it is still not working correctly. Since then the refrigator part is not cooling. Today is Sept 10 2008 and I am going to purchase a new refrigerator. It will never be Samsung again.
Posted on Sep 10, 2008
  • 3 Answers
I had the same problem - the twin valve at the back which lets the water into the ice tray (and also the water dispenser) was faulty - only the ice tray valve, not the dispenser one. So the dispenser worked but the ice did not. repairman replaced it and has worked fine since.
The valve is at the back, to your right as you face the rear. You'll need to take the plate off and the vlve is the unit, about 3 inches by 2 inches and has one water inlet and two outlets. It was quite easy to replace (if only I had known, could've save 200 quid) - I think currys partmaster sell the part.
Hope this helps
Posted on Feb 17, 2009
Fill tray with water then the sensor starts again i find problem occurs after ice box has been full for a while cheers rabbit53
Posted on Sep 02, 2008
    Problem Solver:
  • 10 Answers
Sometimes there is water became ice inside pipe comes to ice maker.please switch off for 24hrs.then check with test switch the water is coming or not problem will get resolved
regards
sandy
Posted on Jun 19, 2008
Sometimes there is an air lock in the water tubing. Do you think pushing the water paddle for a considerable period of time will resolve the airlock and your ice tray might start filling up?
Posted on Jun 03, 2008
  • 237 Answers
Did you ever get any advice for this problem? Please repost if not.
Posted on Dec 23, 2006
I have a Samsung side by side refrigerator Model No: RS21DCSV. The water and ice dispenser are working. However, the water is no longer chilled?
Water is stored in a tube bundle located behind the crisper drawers (bottom, back of the refrigerator) and is chilled to the temp of the refrigerator (perhaps 40 degrees F). This tubing holds approx. 16-32 ounces (less than a liter) and incoming water pushes the chilled water to the dispenser, but also begins to warm the output water temps.
The only way to get colder water is the set the refrigerator to a lower temperature. But be careful that the temps are not so low as to cause other food items to freeze.
Sep 30, 2016 | Samsung Refrigerators
Samsung rs21dcsv not cooling displaying high temperatures evaporator fans running, but compressor not running
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 01, 2009 | Samsung RS2534 Side by Side Refrigerator
My samsung american style fridge freezer RS21DCSV will not re-start after the power was off the light comes on but the control panel will not work
you may need to just unplug this unit for 5-10 mins
for some reason samsungs have a way of getting lost in the program, usually hapens durring a powersurge or power draw, of whatever kind,,,,
anyway sometime this "repair" will clear the eprom and you should be all set....
Oct 27, 2009 | Samsung RS2578BB Side by Side Refrigerator
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Icemaker tuns but ice does not drop out
OK the reason the Ice isn't dropping is that the element under the icecube tray isn't working. You'll need a new Ice tray with element I'd be guessing, but see how you can buy it. Some models you need a whole new ice maker. Cheers
May 21, 2009 | Samsung RM255LASH Side by Side...
Water dipenser
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Sep 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
My rs21dcsv side by side fridge freezer
This sounds like the same problem I had with my model. I contacted Samsung and they confirmed there was a design fault which they will provide a modification kit for. The service engineer is due to carry out the modification tomorrow, 4th June.
Suggest you contact Samsung directly on 0845 7267864
May 19, 2008 | Samsung RS2630SH Side by Side Refrigerator
RS21DCSV
try a full defrost first then if it reoccurs you may need to replace the thermistors behind the back wall inside.
Jun 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs21dcsv refridgerator
THE PROBLEM CANT BE ON THE FRIDGES PIPES.THE PROBLEM MUST BE AT THE FILTER OR ON THE WATERSUPPLY.
Feb 13, 2007 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
575 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
