Question about OKI C3530N Color MFP Printer
OKI C3530N Multifunction Printer
I have had my C3530 for a couple of years. I have replaced the OEM toner cartridges with InkjetSuperstore compatible cartridges and they seemed to work fine. But now I am getting toner sensor error messages (for Black and Magenta so far). Is there as history of compatible cartridges causing problems with OKI printers? Is there something I can do to remedy this problem with my printer?
  • rhammer55 Apr 21, 2009
    every time I replace the toner cartridges I get "toner sensor error". I've tried everything I know to do and nothing works. HELP!!!!!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 97 Answers
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Posted on Dec 07, 2008
I have an oki c3530 and it is making a terrible grinding noise, any ideas?
One of the drums needs to be replaced. Systematically remove one at a time until the grinding noise no longer happens, then replace that drum.
Jan 26, 2010 | OKI C3530N Color MFP Printer
OKI C3530N
Take cartridges out of the printer.
Close cover.
Unplug printer for 30 minutes.
Reconnect printer to power.
Printer demands cartridges.
Reinsert cartridges as demanded.
Oct 31, 2008 | OKI C3530N Color MFP Printer
COMPATIBLE TONER VS. OEM TONER
Compatible toner is more cheaper than original, risking quality and due to low quality of the powder you can damage your printer.
I suggest to use original toner and at the printer properties set your printer to work in save toner mode.
Sep 30, 2009 | Brother HL-2040 Laser Printer
I have a C3530 MFP and it won't print because it says check toner cartridge black. Toner Sensor Error
Hi
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | OKI C3530N Color MFP Printer
OEM vs Compatible laser toners
It makes absolutely no difference to your printer settings if you go back to OEM cartridges. And yes its ok to mix the toners too.
Apr 04, 2009 | OKI Electric Industry C3520 Laser Printer
OKI C3530 Fatal Error 031
Hi.. i only remove the memory ROM in the board and refixed it, then i turn on the printer and now its working :)
thanks Admin
Feb 19, 2009 | OKI C3530N Color MFP Printer
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Toner sensor error after replacing cartrige...
Hopefully this will clear up a little confusion I had:
1. Follow instructions for replacing toner cartridge.
2. Remove drum from printer. Take care not to handle the drum surface. Look for a small rectangular window or depression. The window will be completely or partially blocked by a flap.
3. Use a fine pointed instrument to move the flap up, so that the sensor underneath is visible.
4. Replace the drum. The error should clear after the print engine has reset.
Sep 09, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Oki C3530 MFP
Con el cartucho instalado en su posición, tiramos de él para arriba y sacamos todo el alojamiento del mismo. En la parte derecha del mismo hay un cuadradito con una ventanilla de plástico que debe estar totalmente liberada. El problema es que ésta a veces se queda medio tapada y el sensor no detecta el cartucho. Levantar ese plástico hacia arriba todo lo que se pueda ( con algo que tenga punta, un boli por ejemplo) y volver a poner todo el alojamiento en su sitio. Suele funcionar a la primera, y si no, apagar y encender de nuevo la impresora.
Jul 16, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI C3530N Color MFP Printer Logo
736 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
