Question about Acer Ferrari 3200 Notebook
UJ-825-C is Compatible with UJ-825S ?
I have a Acer Ferrari 3200 with UJ-825S Combo DVD+CDRW broken and I would like to replace it. I found the UJ-825-C to replace it, but I don't know if it's compatible. Do you know if it's?
5 Suggested Answers
migregorio
  • 42 Answers
SOURCE: acer ferrari 3200 pc notebook problem
Hello. Vista needs a repair. You will want to start by putting in your own vista disc or borrowing one from someone. If your laptop isn't booting from the disc, then enter the bios (by hitting f2 or f12 usually) at bootup and select the DVD/CD rom drive to boot first. When the vista disc loads you will want to select recovery tools. Then select "startup repair". That should fix your problem.
Posted on Apr 12, 2008
Mark_Webber
  • 472 Answers
SOURCE: acer ferrari display problem
If you mean like squares of pixels then it will be the video memory on your video card failing or over heating.
Check the video card and make sure it's not clogged with hair and dust etc and reseat it. Also use good thermal paste when you put it back together between the heat sink and the GPU.
If that fails to improve things then a new video card will sort it right out.
You could always send it to me.. I have a thing for Ferrari's ;)
Posted on May 24, 2008
  • 107 Answers
SOURCE: (ACER ferrari 3200)earphone and disc drive
The headphone jack is soldered directly to the motherboard. finding a new one and getting it soldered on is the only option. As to the dvd I would remove it (one screw holds it in either on the bottom or under the keyboard) finding the model number and ordering a new one on ebay
Posted on Jul 15, 2009
SOURCE: acer dvd driver missing
CD/DVD drive drivers are Operating System generic drivers and need not to be installed explicitly. The CD/DVD drive drivers are installed along with the Operating System and can be reinstalled automatically at next restart, if missing.
Check in the Device Manager under the "CD/DVD drive" category if there is any device listed there and having exclamation mark. If there is any exclamation mark visible beside the CD/DVD drive name then right click on it and restart the Computer.
Restarting the Computer will reinstall the CD/DVD drive driver thus causing it to work normally.
Posted on Nov 25, 2009
How to connect acer ferrari one 200 netbook to tv through VGA TO VGA CABLE ??
i have acer ferrari 200series i have a problem on usb internet key..i did not run automatically, on the device manager show a question mark on dvd/cd rom, but when i update the driver it keep say is up to date,,,
Jan 27, 2011 | Acer Ferrari 3200 Notebook
Acer dvd driver missing acer ferrari 400 dvd uj-845-c
Nov 25, 2009 | Acer Ferrari 4005WLMi Notebook
Jul 15, 2009 | Acer Ferrari 3200 Notebook
Change the HD in the Acer Ferrari 3200
uslaly u fold sceen open all way pop top panel off then remove kb then top then dvd rom drive
Jun 16, 2008 | Acer Ferrari 3200 Notebook
Hard drive
To change a drive is not hard at all,ones u can identify it then un screw the ferrari 3200 and replace the drive.Note:while replacing u must take note of how u un screw it and where u un screw it and make sure u dont lost any screw or misplace the connector when u are screwling the drive back.and before u replace any drive at all make sure the system is off and make sure to romove the battery b4 removing any drive to avoid burning of the motherboard.
May 14, 2008 | Acer Ferrari 3200 Notebook
DVD RW
I can not give you a YES, but I've found TOSHIBA CD/DVD compatible with Compay/HP provided the connections and size are the same - not the otherway round though .....
May 07, 2008 | Toshiba UJ-820BTJV-A (K000015860) DVD...
Acer ferrari 3200 pc notebook problem
Apr 12, 2008 | Acer Ferrari 3200 Notebook
Four Beeps on startup on a Panasonic uj-810b
sounds like it's trying to boot to the dead drive- pay attention to the screen when you power on F12 or F1 whatever get's you to boot menu- change the order to exclude the broken drive- it should stop beeping.
Jan 14, 2008 | Panasonic (UJ-825-B) DVD±RW Burner
Ferrari Acer 3200 Cd/DVD Drive Eject Problems
This is a hardware problem and you will need to replace the drive. The hinge screws need to be removed in order for the keypad to lift up. Under the keypad should have at least 2 screws holding the dvd rom. Remove them. If you turn over the laptop, check to see if there are any screws needing to be removed before taking out the drive. If the connection and physical size of the drive of the ferrari 3400 dvd drive is the same as this, it should work as a replacement. Make sure you check the port of the dvd drives that they are the same, as you don't want to force it and bend any pins.
Mar 17, 2007 | Acer Ferrari 3200 Notebook
Cd dvd combo drive
Can you be more specific about which error messages you are getting? This is important because it will tell us whether the laser or motor is burned out, or if you are just being stopped by copy protection.
Sep 25, 2006 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Acer Ferrari 3200 Notebook Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
