Question about Logitech X-530 Computer Speakers
ONLY 2 SPEAKERS ARE WORKING
The Main Spaeker. With The Controls work and the Front left works the rest of the 3 has no sonund at all coming out ??? does anyone eles have this problem or does anyone no how to fix it ??
Could be your sound card. Look to see if it has the minimum requirements as listed in your manual. Otherwise you could just be plugging it in wrong.
Posted on Nov 04, 2008
On my klh subwoofer the high speaker output stop working the sub works just fine but when I hook up the other speakers to it they don't play at all. I know if I go and buy a receiver I can bypass it.
The speakers connections have to come from an amplifier with sound coming from it in the first place. Once connected to the unit the bass signal is then extracted from the signal and the rest of the signal sent to the main speakers. The KLH will not power the main speakers on it's own. The unit will only take the two main stereo channels, from an amplifier, the left and right then go to one set of inputs and they then come out of the other two outputs.
Dec 27, 2016 | KLH Audio Players & Recorders
No music coming from my left front speaker. I ran the level calibration and I can hear the pink noise coming loud and clear to that speaker. I have both front speakers set to the same level, but I only...
Looks like your volume control switch is not working on the left side, you can check it by tapping the knob on the volume control and sound will come out on left side.
The only way to get the sound again is to replace the volume control or pull out the volume control and open it up to clean the contacts in it.
Hope that helps you out!
Thanks for using Fixya!
Dec 12, 2010 | Onkyo TX-DS787 Receiver
Why my speaker cannot function normally?
Find soundcard control in control panel. May be ytour sound is working in karaoke or bathroom mode :)
Apr 11, 2010 | BenQ Computers & Internet
Outside bose speakers keep turning off after a few seconds
It sounds like the speakers are either peaking and shutting down or they are dodgy. Check the volume going into the speakers and turn it down see if that works, otherwise take the speakers back. It might be worth trying a different set of speakers as well
May 24, 2009 | Bose Lifestyle V30 Home Theater System -...
Left front speaker works the rest dont and the sub makes a hum
Either you have it configured incorrectly this time around, or the settings are defaulted back to original on your DVR........ adjust your DVR sound properties/settings. and check all wires/connections as well.
Apr 20, 2009 | Creative Labs Gigaworks S750 Computer...
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Mar 15, 2009 | Yamaha RX-V663 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Denon avr-2500 left main speakers very quiet.
The Denon 2500 was one of the best ProLogic receivers built, it was a work horse and very little ever went wrong with them.
To make sure you're only supposed to hear right & left speakers, press the Stereo button on the remote. Also recheck your speaker connections - this is the single most overlooked connection problem folks have.
Check the balance control to make sure it's in the center position
Make sure the Tape Monitor is not engaged.
Then, check to make sure that the Pre-Out, Main-In jumpers are connected properly on the rear panel.
If that is not the problem, try pressing the Tone Direct button on the remote (aka Tone Defeat on the front panel).
Jul 26, 2008 | Denon AVR-2500 Receiver
Hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Jul 11, 2008 | Audio Players & Recorders
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Logitech X-530 Computer Speakers Logo
55 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
