Question about OKI C3530N Color MFP Printer
OKI C3530N I have replaced my OEM toner cartridges with toner cartridges from InkjetSuperstore. They compaltible cartridges seemed to work fine for a while, but now I am getting sensor error messages (for Black and Magenta so far). How do I resolve this problem?
    Master:
  • 763 Answers
Try check if it fits the cartridge to the printer correctly it must have been loosed while printing. Ask the shop about the cartridge that youve bought from them and ask for replacement maybe its just a factory defective.
thank you for using fixya
CHARCOIS
Posted on Oct 31, 2008
  • OKI Master
  • 19,396 Answers
Use only original cartridges, this kind of printers often give you problems with non originals ones.
Try removing all the cartridges and putting them back in place.
If that does not work, buy original toners.
  • Ginko
    Ginko Oct 31, 2008
    Try fist removing all the cartridges and then reinserting them.
    If that does not work, you will need to buy original toners.
    Genius:
  • 1,550 Answers
Take cartridges out of the printer.
Close cover.
Unplug printer for 30 minutes.
Reconnect printer to power.
Printer demands cartridges.
Reinsert cartridges as demanded.
My oki data C5200 in printing a faded picture along the right side of the page only. I have cleaned the print heads and checked the levels in the cartridges. Everything seems to be fine. Can you help?
> OKI C5200n laser printer
Take the toner-cartridge out, and gently tilt it left-and-right
to redistribute the remaining toner in the cartridge.
Reinstall it.
Oct 13, 2010 | OKI C5200n Laser Printer
OKI B4400 toner - is the chip reusable? I get toner not installed
The chip is not reusable and needs to be replaced every time. You should be able to find a chip on the internet somewhere. I own a Cartridge World printer cartridge refilling store and I do not recommend refilling your own toner cartridges or buying super cheap ones off the internet. The toner is generally such a low grade that it degrades your drum cartridge causing you to replace a $219 drum unit before you should have to.
Jan 27, 2010 | OKI B4400 Digital Mono Printer - Black
I purchased a "new" recycled cartridge for my HP 2200d. I have the correct cartridge but it prints so light you cannot read it. I put another "new" one that is also recycled in the printer and it is doing...
in the setup there are a option for more toner on print or you have to put a handle in the printer for darker prints mostally where you put the cartridge in
a recycled cartridge works allways the same as a new one
Oct 04, 2009 | OKI C3530N Color MFP Printer
COMPATIBLE TONER VS. OEM TONER
Compatible toner is more cheaper than original, risking quality and due to low quality of the powder you can damage your printer.
I suggest to use original toner and at the printer properties set your printer to work in save toner mode.
Sep 30, 2009 | Brother HL-2040 Laser Printer
Changing the toner cartridge in an oki b4350
Is it a OEM cartridge, which means that its made but the manufacturer of the printer. If it is a refurbished cartridge then it will probably not be "recognized" by the printer and subsequently tell you its low on ink.
Jun 23, 2009 | OKI B4350 Laser Printer
OKI Toner
Have very good experience with Uninet Imaging toner for this model. So replace the drum units and try this one. It also have wax particles in its structure. But wax lubricates fuser, not drums...
Jan 14, 2009 | OKI C9300 Led Printer
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Toner sensor error after replacing cartrige...
Hopefully this will clear up a little confusion I had:
1. Follow instructions for replacing toner cartridge.
2. Remove drum from printer. Take care not to handle the drum surface. Look for a small rectangular window or depression. The window will be completely or partially blocked by a flap.
3. Use a fine pointed instrument to move the flap up, so that the sensor underneath is visible.
4. Replace the drum. The error should clear after the print engine has reset.
Sep 09, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Oki C3530 MFP
Con el cartucho instalado en su posición, tiramos de él para arriba y sacamos todo el alojamiento del mismo. En la parte derecha del mismo hay un cuadradito con una ventanilla de plástico que debe estar totalmente liberada. El problema es que ésta a veces se queda medio tapada y el sensor no detecta el cartucho. Levantar ese plástico hacia arriba todo lo que se pueda ( con algo que tenga punta, un boli por ejemplo) y volver a poner todo el alojamiento en su sitio. Suele funcionar a la primera, y si no, apagar y encender de nuevo la impresora.
Jul 16, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
OKI C3530N Color MFP Printer Logo
286 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
