Question about E-Machines eMachines Desktop PC
E machines no disc
I had 2 of the 3 after I ran them it now says No active OS partition and press any key to reboot. Any suggesstions I have tried the f2 and del and it takes me to a bios screen with a password but no clue what the password is. Any suggestions?
  • razin3bisons Nov 04, 2008
    Still didn't work. I tried every code known to mankind.
  • 33 Answers
The first part of your question is a little vague and seems to be in response to another post. However, if you need to get into your BIOS, do a google search for "default bios passwords." This should get you started.
Hope this helps - good luck!
Posted on Nov 01, 2008
  • TF Nov 04, 2008
    Well, you can always reset the BIOS.
    The best way to do this to follow the manufacturer's instructions for your specific computer or motherboard. You should be able to find the User's Manual on the manufacturer's web site, if you need one. I recommend doing this instead of using one of the general methods described below.
    I cannot provide specific instructions because you have not provided specific information for your computer or motherboard.
    In general:
    For modern motherboards, the most common way is to turn off the computer and unplug it, open the case, ground yourself to the power supply housing (or any unpainted interior surface), look for a three pin motherboard header labled BIOS or RESET or something to that effect. Remove the jumper from the two adjacent pins that currently havethe jumper installed (for example pin 1 & pin 2), and move it over one pin so that two pins are jumpered (pin 2 & pin 3). Wait about 5 seconds and return the jumper to its original position. The BIOS should be cleared.
    For older motherboards, if the motherboard header has only two pins and the jumper is hanging off of one of the pins place the jumper on both pins. If a jumper is not installed at all, use a spare. Wait about 5 seconds and return the jumper to its original position (or remove it). The BIOS should be cleared.
    For very old motherboards, there may not be a BIOS header at all. In this case the CMOS battery must be removed. Wait about 5 seconds and reinstall the battery to its original position. The BIOS should be cleared.
    WARNING: Make sure you do not reconnect the power until you return the BIOS jumper to its original position. Do not leave the jumper in the "Clear BIOS" position. If you do connect power while the jumper is in the "Clear Bios," you will destroy your BIOS!
    CAUTION: Clearing the BIOS sets it back to its default settings. The default BIOS settings may recognize your configuration, but you most likely will have to manualy set all of its settings for your specific configuration, ie. CPU, memory, HDD, FDD, CD/DVD, ports, boot sequence, etc. Dont forget to set the date & time, because, an improper date & time setting can cause havoc using update web sites and financial programs Once again the manufacturer instructions are the best place to find good BIOS settings.
    NOTE: If you look around the internet you will most likely find several sites (mainly in forums) that offer specialized/optimized BIOS settings that many users find work better than the ones recommended by the manufacturer.
    Good Luck!
I'm trying to get my computer back to factory settings
If you have a Recovery Partition, It is still there. You didn't supply your Make, Model of laptop or the OS you are using. But, Remove all media for the machine,DVD,CD,USB,...etc. Shut down, Unplug, remove battery, plug in, reboot using the proper F key to enter the Recovery Partition, do A Full Factory Recovery. If asked format the drive. Your Recovery Partition is designated as another drive, it's a partition in software. The machine see the HDD as two, C ,your OS and D, Recovery , for instance.
Dec 28, 2012 | Computers & Internet
I bought a laptop with Lonovo Window Vista Ultimate, but when my system crashed and I reinstalled it, But needed to activate kindly assist me
Welcome to FixYa!
I believed you are having problem with the Operating System on the laptop itself,. You said you already reinstall it, there are two ways of reinstalling the Operating System on Lenovo, By using One Key Recovery and by using the Recovery Disc. If you are going to use the Recovery Disc, make sure that you boot from the disc itself so it will not ask for any activation key, please follow the steps below.
For One Key Recovery:
1. Turn off the computer.
2. Press the little button near the power button, it usually do have a drawing of an icon that looks like a horse shoe or a headset.
3. There will be a window that will appear which do have three option, One Key Antivirus, One Key Recovery and System Setup. Choose One key Recovery.
4. There will be another window that will appear which do have two option, Restore from initial backup and Restore from user backup,Choose Restore from initial back up
5. It will asked you if you want to continue, Just click on OK or YES.
6. Once done, Reboot the computer.
For Recovery Disc,
1. Insert the disc inside the drive.
2. Turn off the computer then turn it back on and keep on tapping F12
3. There will a window that will appear which do have three options, HDD,ODD/DVD/CD, and NAT, choose ODD/DVD/CD
4. It will asked you to press any key immediately, you will need to press any key immediately so that it will boot from ODD.
5. It will asked you to choose a partition, choose Disc 0 partition 1
6. Reboot computer once done.
I hope this information will be helpful. Thank you for using FixYa...
Nov 27, 2010 | Lenovo 3000V200 Laptop
How to completely clean /delete/and thn reboot
What do you mean clean, delete and reboot? Are you trying to re-format the whole hard drive? If yes then follow this. 1. Prepare the Windows OS disc. 2. Use ac adapter on laptop. 3. Power on laptop then immediately keep tapping on F12. 4. Boot menu will appear use then the arrow keys highlight on onboard CD/DVD-ROM then insert the windows OS disc then press the enter key. Just wait until it loaded the windows setup. Just follow the prompt on the screen on deleting the partition. Windows has its instructions during the process.
Mar 31, 2010 | Dell INSPIRON 6000 CENTRINO...
Two O.S.
put the windows xp cd into ur dvd writer ... restart the machine... then after showing the dell logo... it will say "press any key to boot from cd.."
press any key.. wait until a blue screen appears...
there will be three options
choose "press esc for a clean install"
it will show the partitions of installed windows
delete the partition of your choice....
create a new partition on the unallocated space...
press f3 to quit...
machine will restart ...
wait upto the blue screen...now choose
"press R for recovery console"
press R
type fixboot | enter
type fixmbr | enter
restart the machine
whoa...your are good to go..
Dec 19, 2009 | Dell Vostro 1510 Notebook
Software disc
You need your original installation disc(s), or start up the machine and hold down the f8 key and then, 1st boot on the last known good.
2nd, reboot holding down the f8 key and then try the restore method. Most machines have a 4 to 10 gig partitioned on the C drive which holds your restore partition. Else, if you have the orginal OS disc, put it in your cd reader, it will come up with the start up screen for installation. when you get to the install window say OK, then when the window comes up you should have a choice of intalling new or repairing the hard drive ... repair the hard is the correct choice. This should work if there isn't a hard drive problem, or your hit with a virus, or that the hard drive has a bad boot mbr.
Jun 17, 2009 | Computers & Internet
T30 cant find os
when you start does it come to point where it shows xp and ibm
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
Compacq Presario
Prior to re-installing your OS, backup all your documents..
Insert your recovery disk cd on the cd rom drive and reboot your pc.
As it reboots press any key to continue so it will boot from cd and delete the partition, create a partition and active it.
Then install the OS which goes to C:\ drive. After the installation is complete install all the drivers and the applications. You can go to the manufacturer's website and download others drivers as needed.
Activate Windows then go to Microsoft Update
Dec 09, 2008 | Computers & Internet
Dell inspiron 6400 rebooting
it is an issue with your software which is not able to find the os in hard drive please perform a operating system reinstall
  1. Ensure all of the Windows XP installation discs and information are present.
  2. Install the Windows XP disc.
  3. Press and hold <Ctrl>+<Alt>+<Del> at the same time to restart the computer.
  4. When the computer restarts and the Dell splash screen appears, press <F12>.
  5. In the Boot menu, use the <Up> and <Down> arrows to select either CD or DVD, and then press <Enter> to continue.
  6. If prompted, press any key to continue. If you do not press a key, the computer starts from the hard drive. In that case, wait until Windows has completed started up, and then begin again.
  7. At the Windows XP setup window, select To set up Windows XP now, press Enter, and then press <Enter>.
  8. Press <F8> to accept the terms and conditions specified in the license agreement.
    new_note.jpg Note: By default, unpartitioned space is highlighted. If any other partitions appear that were not previously created by you, they may include a PC Restore partition or a Media Direct partition.
  9. In the Windows Setup Partition screen, press <Enter> to partition the hard drive. On this screen, review the listed partitions. Usually, the original operating system partition is labeled (OS) and is also the largest partition.
  10. Use the <Up> and <Down> arrows on your keyboard to highlight the OS partition and press <D> to delete the partition.
  11. When the Confirmation screen appears, review the warnings and press <Enter>to continue. You will now be returned to the previous screen.
  12. Use the <Up> and <Down> arrows to highlight the unpartitioned space and press <Enter> to set up Windows XP. The Windows XP Setup appears with the following information highlighted: Format the partition using the NTFS system.
  13. Press <Enter> to continue. On the next screen, a progress bar shows the format process. When the format is complete, the setup files are copied to the hard drive.
    The following message appears: Please wait while setup copies files to the Windows installation folders. This might take several minutes.
    Then follows Setup is copying files…. The status bar displays the percentage complete. When complete, the computer reboots and the set up wizard appears.
  14. When the Regional and Language Options window appears, change as needed, then click Next.
  15. When the Personalize Your Software window appears, enter a name and organization if wanted, then click Next.
  16. When the Product Key window appears, enter the product key, then click Next.
  17. When the Computer Name and Administrator Password window appears, enter a password if wanted, then click Next.
    When you enter the password, be sure the caps lock is off; passwords are case sensitive.
  18. When the Date and Time Setting window appears, change as needed, then click Next.Windows is installed, a progress bar indicates approximately how much of the task is complete.
  19. The computer reboots.
    The Windows XP operating system is fully installed.
Aug 14, 2008 | Dell Inspiron 6400 Notebook
Server2003 enterprize edition
Hey There,
You are getting this problem b'cause loss of ur system file i.e. "CONFIG.SYS", Which loads ur initial files and drivers needs to start ur operating System.
You must follow the steps given below to start repairing ur System:
1. Insert the Bootable OS Disk into ur CD/DVD-ROM.
2 Reboot ur System.
3. The system will prompt You to "Press any key to boot from CD".
4. Press Any key.
5. Now the system will load all initial files and hardware driver.
6. After loading driver and files, OS will ask you for acceptence with their Terms and Conditions.
7. You must Agree with terms and condition. press F8 key for accepting terms n conditions.
8. After step 7, OS will search for the partition of ur Previously installed OS. If you have two operating system then it will show two Partitions with their name and drive letters. (You must remember the drive letter where ur OS is installed that u want to repair)
9. Now Leave that option as it is. And press Escape key.
10. Now You'll be able to see all those partitions you have on ur Hard disk, with their drive letter, Name and free space.
11. Select the partition of OS that u wanted to Repair, By Scrolling Arrow Keys. (Be carefull while selecting the Partition. If you select wrong partition then You wont be able to repair ur OS)
12. And then Press "R" Key from ur Keyboard.
13. Now OS Will search for the partition you have specified.
14 It will Delete Old system files and Copy New files (Note: You won't loose any data, Previously you had saved on ur boot partition).
15. After Step 14, OS will save the configuration and Will Reboot itself.
16. Again You will be asked for "press any key to boot from CD". Don't Press Any key at this step.
17. Now follow the wizard n specify correct information you will be asked.
18. It will take about 20 to 30 minutes to Repair ur OS.
Note: These Steps are not valid if you are using Windows Vista
Romy_Dec
Jul 30, 2008 | Microsoft Windows Server Standard 2003 for...
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
41 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
