Question about Vodavi Starplus DHS 7312 Enhanced Phone
Ring Tone not turned on
Thanks for your help - you fixed my problem and I really appreciate it!!!
Tom Keating
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
Jun 06, 2011 | Samsung GTC3300 Cell Phone
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
How to change the incomming ring tone on panasonic kx-t7630
Oh hell... you must be going nuts if its the ring tone I think you're stuck with. I loath the manual that comes with this system so here it is in English:
  • Press 'Prog'
  • Press 'Intercom' twice
  • Now you can either go through the different ring tones by pressing 'SEL' on the LCD screen or using the Up and Down keys on the circular pad on the bottom right of the phone.
  • Once you have the tone you like click on 'Enter'
  • Pick up handset and hangup to complete the process.
Dec 04, 2008 | Panasonic KX-T7630 Corded Phone
Sony PS-LX500 Linear tracking turntable
I think it's kind of cheap to ask someone to pay $10 for an answer to one question. Sheesh!
I haven't gotten the answer yet, but a local stereo store pointed me in the right direction. Thanks anyway.
Regards,
Tom
Sep 19, 2008 | Sony PS-LX250H Turntable
Ring Tone
if you want to make it silent hold down the hash key. ifnot then you may have to turn the volume of the ringtone down to 0.
Jul 15, 2008 | GE 2-9438C Corded Phone
Ringer on Sony SPP-S2730
The main board in the base is bad, I was never able to pinpoint the bad component after changing a few circuit board parts.
I only saw this problem in the 2730.
The only fix I found while at the Sony Service Center was to replace the board.
Radio Shack sells a remote ringer.... You could hook that to the phone line and it would ring... Not the best fix but it would help... Even another phone in another room...
Sorry.... This problem frustrated me.... Wanted to find the fix... The board is expensive if avaliable....
AL
Mar 20, 2008 | Sony SPP-S2730 Cordless Phone
Blackberry 8100
Go to profiles; scroll down to advanced, and select. Select the profile you wish to edit, hit the menu key, and select edit. Click on sms text, then scroll to ring tone and click. Then scroll up and switch to browse. Select music or audio and select your song.
Mar 08, 2008 | RIM BlackBerry Pearl 8100
B T Decor 110 telephone.
just go to the tone satting opt on u r phone u will find the rington on off opt and set off
Mar 02, 2008 | Cell Phones
Help
Remote ring detection provides a low tone * triple beep in your wireless headset when you receive an incoming call. This feature requires a handset lifter accessory, such as the Plantronics HL1 or HL10. If you do have a handset lifter but do not hear the remote ring detection, please check the following:
  • Check the placement of the lifter. - Make sure the handset lifter positioned directly over the phone's speaker.
  • Try adjusting the phone's ringer volume. If the phone's ringer is too quiet, it may not trigger the ring detection built into the lifter. Try turning up the ringer volume of your phone.
  • Check the ring tone of the phone. - If your phone's ring tone provides short beeps or plays music, the lifter's microphone may not detect it. Try switching your ring tone to a traditional ring or long beep.
  • Does the phone have different rings? - For example internal calls vs external calls vs transferred calls. Does the phone ring the same for each type of these calls. If so try changing so all calls use the same tone.
  • Attach the optional "external ring detector" cable. This cable plugs into the lifter and provides a small, black microphone. It is included in the plastic bag of lifter accessories. Mount the microphone near your telephone's speaker. Click here for more details.
  • There are 2 versions of the Lifter accessory - HL10 and HL1. The HL1 is a larger older version of the liter with a more sensitive rind detector. Some phones will require the older version of the lifter.
  • Please view the On Line Compatibility Guide to see if the older version (HL1) will be required for your phone.
*Please note the volume of notification beep in the headset cannot be altered, it will always be a low tone triple beep .
Jan 15, 2008 | Plantronics CS50 Wireless Office Headset...
Lands Phones Logo
37 people viewed this question
Top Vodavi Lands Phones Experts
george  peters
george peters
Oloyede Monsuru
ray gallant
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
