Question about Technics Audio Players & Recorders
Hi, I have recently purchased a pair of technics 1200 mk2 turntables. One works fine but the other skips, even though I have tried adjusting the height of the arm and adjusting balance etc, no combination seems to work!! I have tried a different needle but it still skips. I have bought these second hand is it possibly a problem with the arm?
  • oatcakes Nov 01, 2008
    funny u should say that, I randomly tried sticking a lump of blue tac on top and it seems to have stopped it! thanks!
  • 905 Answers
There may be a weight missing on the arm , look at the other one to see the parts on that arm and make sure they are exactly the same nothing missing , otherwise there may be something wrong with the armitures guide
try tape on a penny then put it on top of the arm and see if it still skips
Posted on Oct 31, 2008
  • jason Nov 04, 2008
    plz give me a good rating for at least pin pointing the problem , and if you need anymore help just let me know , thanks
Technic 1200mk2 pitch problems
Check for bad solderings on Q201 and surrounding areas.
Resolder IC101 and IC201. If that doesn't help, Q2 and Q3, both 2SD637R, could be broken. If that doesn't fix it replace the electrolytic capacitors. Cheers john. Styluscity
Mar 03, 2012 | Technics SL-1200MK2 Turntable
When i play a record it skips and when i play it on another turntable the same record doesnt skip
Hi, most likely a worn stylus or the tracking weight is set too lightly. Adjust the balance weight at the back end of tonearm forward slightly. If no weight adjustment available put a very small coin on the end of tonearm above the stylus.
Jul 08, 2010 | Technics SL-1200 Turntable
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki
May 10, 2010 | Technics SL-1200 Turntable
Plastic top for technics 1200 mk2 turntable
Hi, What do you mean by this pls, you need a new top or how do you fix a broken one?
Thanks Mark H (superstar DJ)
May 03, 2010 | Panasonic Technics SL-1200MK2 Turntable
My technic 1200 mk2 skips records, i tried other needles and adjusted tone arm. Even tried pennies on cartridge
Ensure that the turntable is sitting as flat as possible and does not allow any external vibration to penetrate.
Also try operating it without a record on it make sure that the plate is turning smoothly without interruption and also does not have any vibration.
Nov 23, 2009 | Technics SL-1200 Turntable
Technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
Sep 22, 2009 | Technics SL-1200 Turntable
User manual Technics DZ-1200 turntables & Pioneer DJXM600 mixer
I found your manuals below:
Sep 22, 2009 | Technics SL-1210 Turntable
Pitch Control issues on Technics 1200 mk2
The pitch pots have been altered.
there located under the platter & cover on the main circuit's a peace of **** to sort them.
if you help e-mail me
Jul 20, 2009 | Technics SL-1200MK5 Turntable
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
216 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
