Question about Panasonic Lumix DMC-TZ3 Digital Camera
Aerial photos whilst landing at birmingham airport and taking aerial photos -I had a message on the camera to say I must not photograph and must turn off as told by the cabin staff - I have never been told that before -what has this camera got to pick this up -blue tooth infra red?? Thanx ronacj
My DMC-TZ3 always displays this message when in aerial mode - I would think that Panasonic programmed this into the setting.  You might never have noticed the message before or never used the aerial mode before ??
Posted on Nov 15, 2008
I want to scan a picture and make it A4 size
take a photograph of the spoons, depending on the camera quality, and the ability of the camera to take macro photographs, ( most of the modern cameras do have) Then take the photo into some sort of photo editing program, and enlarge the file/photo up to A4 at 300 dpi and print out
Jan 12, 2013 | Office Equipment & Supplies
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
Blurry photos on the Sony DSC 170
This issue often is related to lighting, subjects in the foreground, and the lack of optimal settings when using the Easy / Auto function.
First, you should look at subject matter.  If you have the camera set to Easy / Auto, it will focus for you.  This is good if the subject of the photo is the only thing (or the nearest thing) in the frame, however if there is anything else closer to the camera, it will assume that the nearest object is the one being photographed, and will adjust accordingly.  Although it may be something large such as a chair, sofa, table or even a houseplant, it may also be focusing on something as small as a child's toy.  If you must use the Easy / Auto function when photographing your children, make sure that your children are the only (or the closest) subjects in the photo, and the camera ought to set the focus on them.
The second issue is lighting.  Even when using the easiest settings on this camera, you still must make sure that the lighting and flash are optimal.  The flash, for instance, can be set to three different intensities, as not all situations require the same amount of additional light.  Make sure that if photographing indoors, you have either a decent amount of lighting, or the flash set to add the appropriate amount of additional light.  If the area photographed is too dark / bright, the camera (when set to the easiest settings, without any additional specifications from the user) will have difficulty finding (or choosing) the main subject of the photograph.  This is why you will occasionally see multiple little green squares, when it looks (to you) as though your children ought to be the primary --and only-- focus of the photo.  In simple terms, the camera is confused, and will choose what stands out as the main subject.
Remember that although this camera is technically of the point-and-click variety, one of the things that makes it stand out as a digital camera is the ability to adjust the settings as the situation dictates.  I suggest learning what each of the camera settings are used for (it seems daunting at first, but I assure you that it isn't as difficult as it first appears to be... remember, this camera is technically for those who have little-to-no experience with photogrpahy) and applying the available settings to the photos you take.  I am able to turn on my Sony Cyber-Shot DSC W170, adjust the settings to the situation, and photograph my children in less than two seconds more than it would take to turn it on and set it to Auto.  I have taken photos with this camera that have come out beautifully enough to print at the actual stated 8"x10" size (which is rare for a point-and-click), by adjusting only the ISO and flash (and nothing more) to accomodate the setting.
If you are looking for strictly a point-and-click camera that you do not need to set anything on (essentially the digital version of a quality 35mm disposable camera), there are some excellent ones on the market today.  I would reccommend the Sony Cyber-Shot DSC W170 to those who are looking for a camera that is slightly above "beginner" level (though well below "expert" level) cameras.  My husband purchased this for me as a birthday gift, to have on hand for quick photo-taking (quicker than setting up a tripod and adjusting my primary camera) while out and about with our children.
I have been able to take some very beautiful photos with this camera (three outdoor photos were nice enough to sell), however I have only made use of the Easy / Auto settings a few times, while playing with the settings after first receiving the camera.  There are other beginner-level point-and-click cameras that, in my opinion, take far better digital photos than photos taken using the Easy / Auto functions of the Sony Cyber-Shot DSC W170.
This camera was designed for consumers who make use of the various settings, to ensure an optimal photographic experience (much like the difference between a professional photographer's 35mm camera and a basic 35mm camera).  For this reason, anyone looking for a camera that is an easy, simple point-and-click (i.e. you turn it on, take the photos, and that's it), I would suggest shopping around for a simpler camera.  There are many excellent ones that are designed to be quick and easy, and take good quality photos, without needing to adjust anything.
Dec 26, 2008 | Sony Cyber-shot DSC-W170 Digital Camera
Stylus 700 error D:5f08 5e02
The error message (D: 5f08 5e02) means that your lens is dying / dead. It just happened to mine (on the Mju 700, but it's the same thing) and I was told that it could be repaired, but it would cost as much as a new camera. I've only had mine 2 years and I've been really careful with it, so I'm a bit annoyed, but I have used it a lot!
Dec 22, 2008 | Olympus Stylus 700 / 700 Digital Camera
My Camera keeps giving me an error message and the zoom lens is staying out even when the camera is switched off. I am unable to take any photos
Hello!!
Firstly switch off the camera
press and hold the ok button and turn the camera on and off for few times
whilst keeping this button depressed
Regards
Smilemaker.
Aug 19, 2008 | Cameras
Can't take photographs when flash is on
Hi
The powershot s5 IS does in fact have some strange behaviour issues especially on the first rev firmware. For example if you take 15-20 flash photos consecutively without powering down your camera the flash recycle times will increase to about 15sec, so you'll have to wait about 15sec before you can take another flash photo. The work around is to power down the camera and then turn it back ON. Another strange behaviour is manifested by its inability to lock focus after taking a "no-flash" photo, then popping up the flash and trying to take a flash photo. Again the work-around is to power down the camera, pop-up the flash and then power it back up. Confirmed these behaviours in two other cameras of the same model.
Jul 13, 2008 | Canon PowerShot S5 IS Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
124 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
