Question about Gateway GM5084 PC Desktop
Cannot connect to internet
Unable to connect to internet says no network adapter ??? I have connectivity but no activity
  • 36 Answers
Your best answer may come from your ISP. They can help you configure your modem or network to connect with their equipment. My laptop will show limited connectivity when a Network cable is plugged into it also but it isn't set up for use through my router at present.
Posted on Nov 13, 2008
Acer Aspire 5733 Wireless connection lost
Check the wireless router and high-speed modem.
If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
Activate the wireless Internet connection on the laptop computer.
Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu.
Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
Select the appropriate network you wish to connect to.
Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
Restart the computer.
The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
hope this helps
Sep 13, 2012 | Acer Aspire 5733 Laptop
Unable to connect to wireless internet. wireless connection shows disabled.
check whether wireless drivers are installed.
check wireless is enabled.
check in network connections whether u can c wirelass lan connection.
Apr 21, 2009 | Computers & Internet
I have a WCG200 linksys but can not go onto internet.
from what i have read, your router is broadcasting a signal, and your modem has an open and active internet gateway.
pls make sure that the connection from the modem to the router are correct. the modem should be connected in the port with the label internet. you may have to reset your modem AFTER you have connected the wireless router to allow the router to be assigned an ip. now with the wireless router and broadband modem connected, you can connect to the network and access the internet. pls repost if you hit any snags
GOOD LUCK and PLS rate this post.
Mar 18, 2009 | Linksys WCG200 Router
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS: 4.2.2.2, Alternate DNS: 4.2.2.3)
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
if you give the wep key in the router or modem or the access point then you give the wep key in that if not there direct connect it and you can check also where its give the password or not just go to the right click on the wireless icon in the taskbar then go to the view available the network in that your wireless ssid shows just click it in that you show the lock symbol then your network in the password its wirten that unsecure networks then you direct connect it
Jan 12, 2009 | Dell TrueMobile 1180 802.11b Wireless...
No internet service
the wireless adapter needs to connect to a wireless router which then connects to the internet.
it's the router that is connected to the internet and shares it in your home network.
Dec 20, 2008 | Zyxel G-220 802.11g/b Wireless Adapter
Linksys WUSB54GC 802.11g/b can find access point but not internet
do one thing remove the prefered networks from the list of prefered network sand after that connect to the network
u will be able to go online after that ....
Nov 15, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Connected to rounter but not internet
Normally this means that you are not putting in the security key or wireless key. Click on the linksys software then go to site survey select your network then click connect and type in the correct security key.
Jul 25, 2008 | Linksys WUSB54GS 802.11G USB Adapter...
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as 0.0.0.0
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
FW
Apr 30, 2008 | Computers & Internet
Gateway GM5084 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
