Question about Canon imageRUNNER 5000 Copier
Open the duplex then take it out from the mechine and see the roller out side the edges you can find c look remove it then
Posted on Nov 01, 2008
Canon IR8070 paper jam infront of Registration roller
If you can reach the paper in the jam you will have to pull it out to dislodge the jam. Be careful not to rip the paper in doing so!
Aug 28, 2014 | Canon Office Equipment & Supplies
E0732-0001 CANON IR5000
If you are looking for the driver, please download it from HERE. or from here this driver support Windows 32 bit operating system. This download link is for Windows 64bit operating systems (LINK) or
You can also search the driver HERE.
Let me know if you have problem.
Good Luck.
Thanks for using FixYa.
Oct 28, 2012 | Canon iR5000-6000-L1 PS Ver 1.0
How to remove error E000013-000 canon IR5000 Photocopy mashine?
Waste toner feedscrew (locked)It is likely that the feedscrew inside the waste toner pipe is preventedfrom rotating because of some fault. If the outlet of thewaste toner pipe is clogged with toner, remove the waste tonerdrive unit, and remove the toner. If otherwise, try turning the mainmotor clockwise by hand. If the screw rotates, wait and see whathappens; if the screw does not rotate, replace the waste toner feedingunit.
Jan 06, 2012 | Canon imageRUNNER 5000 Copier
Canon 6551 copier-rollers are grabbing causing smear on the copy
check the paper path you need to control the main drive mecanism, and all bushing roller : registration roller, pickup, fixing and exit: you can see exemple of the bushing to check: mabroukmedal_41.jpg
the roller that you need to check and replace the bushing:
Dec 21, 2010 | Canon NP 6551 Black and White Copier
I have a canon imagerunner 210s recently bought already used. It was working ok but now copies are comming white, it does not print anything. could you please tell me what to change either toner or drum...
With the IR-200 one of the main problem is that the transfer roller falls out of place. It's a weak link, you will find that the transfer roller has poped out of the transfer unit. It is located on the transport unit. You can get to it from the front door and release the main lever for removing paper jams... The part are most likely all there,but you will need to put it back togather.... Good Luck
Oct 23, 2010 | Canon imageRUNNER 210S Copier
User manual or User Guide of iR325s and iR5000/6000
give me your email and ill try to get some manual for you
Mar 11, 2010 | Canon imageRUNNER 5000 Copier
Need guidance to install a web cleaner for canon copier ir5000
4.2.1 Removing the Fixing Web
1) Slide out the fixing/feeding unit.
.2) Remove the 1screw , and detach the
fixing assembly upper cover (yellow cover)
3) Remove the two screws used to hold
the fixing web assembly in place, and
open the fixing web upper assembly
While pushing the web feed roller
and the web take-up roller toward
the rear, remove the web Mount the fixing web by reversing the steps used to remove it.
4) Wind the web around the web take up
roller two or three times while
making sure that the arm guide plate
will be outside the take-up roller (when
attaching to the front).
At this time, check to make sure that the
area of contact with the roller is impregnated with oil.
Jun 02, 2009 | Canon imageRUNNER 5000 Copier
IR5000 bloque
this is a code for detection of no or faulty charge to the drum open front door remove toner hopper take out primary charge unit see if any wires are broke on grid , then see if the wires underneath the grid are still there... if all seems ok gently clean the grid with cloth and windex then clean wires underneath dont break grid wires . put it back in let me know
Dec 23, 2008 | Canon imageRUNNER 8500 Copier
How to replace HDD IR5000??
how to clear hard disk IR 5000 and where i can find hard disk software
Dec 20, 2008 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER 5000 Copier Logo
137 people viewed this question
old marine
old marine
