Question about Nintendo DS Lite Console
Top screen goes opaque white, but looks fine with pressed L button.
Hello, I have a problem with my NDS lite where the top screen (only the top screen, the bottom is fine) goes semi-opaque white. When holding down the L button the screen looks normal. I was wondering if anyone knew specifically what the problem is, so that I can order the right parts & try to fix it. Default http://i38.tinypic.com/4j5pp3.png L Button pressed. http://i36.tinypic.com/hrylh5.png Thank you very much!
  • 1 more comment
  • puchigusu Nov 01, 2008
    Well I opened it up.... but I'm not sure if it needs to be replaced or not.
    http://i34.tinypic.com/122bucn.jpg
    No wires seem to be loose/dislodged. The ribbon cable is slightly bent upwards as seen in the photo, is that significant?
    Ah pressing down on the ribbon causes the screen to light up normally, how do I go about finding a more permanent solution?
  • puchigusu Nov 02, 2008
    The picture.
  • 103 Answers
Puchigusu,
You have a defective flatcable of the upper screen, or the calble is not correct seated in the connector on the systemboard.
The upper screen connector is on the bottom side of the Left button-switch.
If the flatcable is defective (most likely because of the open-close actions every time the DS Lite is used) you have to replace the complete upper screen (the cable cannot be removed without replacing the whole screen).
First try to reseat the flatcable in the connector. If that is not working, replace the screen (manuals how to open the DS Lite etc etc can be found on the Internet)
John
Posted on Nov 01, 2008
  • John Andriessen Nov 06, 2008
    Puchigusu.
    Order a new upper LCD screen (flatcable is attached on it). You can find them on the well know auction site. Google for a manual how to replace the screen (take the time) and replace it. Your problem wil be solved with that
    John
    Puchigusu.
    John
NDS Lite dont run or only completely opened
most likely its the top screen ribbon.Because when you open the ds all the way it might push the ribbon in just enough to be read but when not open it cant read the top screen and it will shut down.I have instructions on how to change a top screen you can use them to put the ribbon back in. the only difference is you don't need to unplug the white and black wires.First you need a tri wing screwdriver and a cross screwdriver.You can get both on ebay.Then their are seven screws four tri wing and three cross.You will need to pry the back off be very careful.Start on the side that doesn't have the on off switch and work your way around.Once you have the back off unscrew the two cross screws that hold the logic board on.Then unplug the white and black wifi2_bing.gif and mic wires they snap on and off.Then flip the logic board over by pushing the bottom screen out.On the other side is where the ribbon for the top screen is.To get the hinge apart their are two more cross screws in the top left corner take them out that releases the hinge.very carefully roll the ribbon so you can get it through the metal ring and the wires pull the wires first.to get the top apart the four cross screws are above and below the speakers2_bing.gif under those small squares.A needle will get them out easily .Once you get the screws out then slid the back of the top up 1/8 of an inch then pull the back off carefully.You need to push the screen out and unsolder the speaker wires or use new ones.Make sure when putting it back together you roll the new ribbon the right way look at the old one to find out .Getting the old ribbon out and the new one in is a little difficult so take it all apart first and get the wires out then the ribbon and put the ribbon in first.
Mar 09, 2010 | Nintendo DS Lite
NDS LITE WILL NOT TURN ON
send it to the nintendo people
Jun 21, 2009 | Nintendo DS Lite Console
Movie doesn't play on NDS top screen
Dear person,
Maybe you should get a new DS.When the screen goes blank that means it's old and wants to be left alone.
Nov 05, 2008 | Nintendo DS Lite Console
Nds lite screen
you could try to buy a screen on ebay but i think you are out of luck they are not made to be changed
May 02, 2008 | Nintendo DS Lite Console
NDS powers on then back off
i think you have answered that question yourself but what i would do, find a game repaireshop near by, and they will repair anything to do with game consoles, it should cost too much either, so its either them or the trash or try your pot look, learn a bit more and you might probably be able to fix it yourself, dont give up just yet, believe in yourself and concentrate
Apr 10, 2008 | Nintendo DS Lite Console
NDS Lite will not turn on
I hear about the ribbon cable not being inserted wel.
Lots of people had it put in place, looking ok but no action from the ds. I suggest to reinsert the ribon cables, i heard its quite tricky with the ds...
I find the top screen goes white when its moved about its fine when playing steady games when it goes white i just move the top part and it works fine maybe some ribbon or lose connector this is on a...
hello, yes it sounds like the ribbin connection the top screen (also video and power) may have a fine break on one of the fingers,
You can try find a broken one and repair it or bring to a games console repair agent.
you could also return it to the store if it is still under warrenty.
Hope this helps...
Feb 20, 2008 | Video Game Consoles & Games
Conection?
Here is a guide to dismantle an original Nintendo2.gif DS:
How to dismantle a Nintendo DS.
If yours is the NDS Lite, just find this video2.gif in youtube: "Disassembling Nintendo DS2.gif Lite"
And after opening it you can do your work. Make sure the flexible cables connecting the top screen part of your DS are well in place and not broken. Your problem may be only a loosen cable but in case the cable is broken you gonna need a replacement. Be careful not to damage the screen or other sensitive electronic parts on your device and you will be on your way.
Good Luck...
Dec 01, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
181 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
