Question about Protron PLTV-32 Television
Protron 32inch flatscreen TV
Sound but no picture
    Problem Solver:
  • 6 Answers
Use a flash light to see if image on panel may have issues with back light.
Posted on Nov 15, 2008
I have a 2005 Protron 32 flatscreen TV and recently disconnetted it from Direct TV and just want basic TV 4 6 10..... when I plug the tv into the wall without cable I only get a blue screen. Do I need a...
You do need an antenna and need to access the menu and change input to antenna. Through the menu you should be able to let the tv auto scan for channels.
Sep 17, 2011 | Protron PLTV-32 Television
My protron tv pltv-32c has no picture but has sound, if you change channels the picture will flash on for about 1 second
Hi.
If there is sound but no picture, screen is completely dark and the picture is occasionally flashing, then the fault is likely a faulty inverter. In some case a faulty controller board or a defective PSU can cause the same problem.
I summarized the problem here:My LCD TV has sound but no picture.
I posted general procedure to test inverter, PSU and controller board on LCD here : How to test an LCD TV or monitor PSU and inverter.
If screen is not dark, but has blacklight or noise things are different. In that case check connection cables first. Parts that may be defective are main controller board, terminal circuit and tuner board.
Protron parts are available using the link below. Ensure that parts are compatible with your model before purchasing.
ShopJimmy - Protron Parts.
Regards.
May 15, 2010 | Televison & Video
Hi I have a Philips 32inch ambilight TV about
No a lot of HDMI does NOT send the sound signal through the HDMI cable & must be run AV to AV, the RED WHITE & YELLOW plugs Color to color for RED & WHITE, the YELLOW is Composite Video. . The SCART should indeed have it "All in one" however that signal is only RGB, or Composite Video, a lower quality, than HDMI. Just use HDMI & AV. you'll be all good.
Feb 06, 2010 | Televison & Video
Protron 32inch tv.
check the output of your power supply with avometer
Sep 19, 2008 | Protron PLTV-32 Television
Crackle and Pop
sonds like the power transistor. you will need to get it repaired by a someone qualified
Jul 27, 2008 | Protron PLTV-32 Television
Help With My Protron Flat Screen TV
I rebooted the television. Turned it off, unplugged it and disconnected the cabletelevision. I left it that way for about 10 minutes and replugged it all back in and turned it on. It works great now!
Jun 10, 2008 | Protron PLTV-32 Television
No sound
Look in your tv settings menu and see if the speakers are turned off there is an on/off setting in the menu..
Dec 15, 2007 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
107 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
