Question about Nikon Coolpix L11 Digital Camera
Memory card is write protected
I get this message on both my cards, but they aren't. I have to eject the card sometimes 50 times for it to read properly. I cannot reformat the card because my menu won't let me select it. This is less than 1 year old and I'm very disappointed.
  • turtle84 Nov 06, 2008
    My camera keeps saying Write protected and will not work. I had taken the card out to get pics made and put it back in. Help! I cannot use the camera at all!
Hi. I am turtle84. I called Nikon and found out that I had to move the button on the side of the memory card. I guess when you put the card in and out of the machines in the store it moves the button on the side. My camera is fine now. No more annoying message and it works!
Posted on Nov 06, 2008
I got cannon power shot sx130 is it reads memory card error the memory card is not locked but the eject button is not working how to fix this problem. thanks
Try to switch off the Camera and restart it gain. Again, Sometimes, its due to some auto-run software running in the card which prevents that from ejection. You can try to even format the card in the camera itself. That may work also.
As a last resort, check up your camera and get that memory card removed out of your Camera.
Feb 16, 2015 | Canon Powershot SX130IS Black Digital...
My MacBook Pro OS X 10.9.1 won't read my Lexar Professional 800x 8 GB Compact Flash UDMA 7.
You can try using a file recovery software like Bad Copy Pro 4.10.125. It works well for me.
Jan 20, 2014 | Lexar Electronics - Others
How can i pull out my memory stick t of my cer laptop
The memory card is ejected by just pressing it in until you hear a faint click then letting go. The card will pop out by itself about 1/8 inch and you can just grab it and easily pull it out the rest of the way. A word of caution. If you have written anything to the memory card from your laptop, you should not eject the card until you left-click on the tool bar icon "Safely Remove Hardware and Eject Media" then click on the pop-up list item to "Eject Mass Storage Device" which will reply with a "Safe to remove hardware" message. This insures that the contents of the buffer used for writing the memory card or stick has been completely written to the memory card or stick before it is removed. Because the card or stick is much slower to write than it is to read from the laptop's hard disk, there will always be a chance for an incomplete write causing card or stick corruption unless the "Safely Remove Hardware and Eject Media" is used.
Mar 26, 2011 | Computers & Internet
Every time i turn on my camara it says protected card but its not the memory card its not locked! so whats wrong with my camara??
The message which you are getting because you memory stick is write protected.There is a small thing which make a card write protected.
As I dont know which card you are using so here I am giving an simple example with images.
Just click HERE and first read the instruction.It is from SANDISK as it is the most trusted memory stick brand so i am giving its resemblance.
Follow the same steps and make you card working.
If you still persists or you have any more query then get back to me here.
All The Best.
With Regards:-
Subhankar Ghosh
Dec 12, 2010 | Fuji FinePix Z10fd Digital Camera
Write protection on a Transcend 8GB CF card
Having pics on card you don't want to lose is another matter...sometimes a pc won't recognize the cardreader...I have hade to go thru windows explorer/computer/removable drive F:...YOU GET THE IDEA, good luck.
Feb 17, 2010 | Cameras
Cannot remove memory card write protection Nikon Coolpixs9
Take your memory card out and look to see if you may have moved the sliding switch on the memory card, if you have move it back.
Feb 12, 2009 | Nikon Cameras
Memory card is protected how do i switch on memory card when i turn camera on, message reads that the memory card is protected and to reset switch on memory card. what happened?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 11, 2008 | Kodak EasyShare CX7330 Digital Camera
Nikon Coolpix 5200 Getting Message ""Memory Card is Write Protected"
Inspect your SD card carefully. Some SD cards come with a write-protect lock switch on the side of the card. When looking at an SD card from the top there is one required notch on the right side (the side with the diagonal notched corner) and on the left side there is usually a switch. This is the write-protect switch. When this write-protect switch is in the down position (away from the end that is inserted) then it is write protected and read-only. When the switch is in the up position it is write enabled.
Nov 29, 2006 | Nikon Coolpix 5200 Digital Camera
"Read only card, change to internal memory to capture"
This error message indicates that the memory card in the camera is write-protected. To take a picture, turn off the camera and insert a new card, or change the storage location to internal memory.
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
108 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
