Question about JVC HR-XVC33U DVD Player/VCR
Split Screen Output
Somehow a button was pushed accidently or something. Now every DVD plays in a Split Screen Mode (2 Pictures side by side). How do we shut off or cancell this option?
Many thanks in advance
Jim
    Genius:
  • JVC Master
  • 1,550 Answers
Check on the remote if got some function of format ntsc or pal or check on the menu of the dvd
Posted on Oct 31, 2008
How do I access the AV1/2 channels to view my DVD player''s signal?
Normally there is an INPUT button on the remote control or on the front of the TV itself.
Just push that until it shows VIDEO 1 or something to that effect on the TV screen.
Power up your DVD player and make sure it is hooked up to the correct input connectors on your TV and then play a disk in it.
You should see the video displayed on the screen, and if not just push the INPUT selector button repeatedly until you get to the correct input mode for your DVD player.
Good luck.
Apr 21, 2011 | Televison & Video
I purchased a RCA DRC-8335 DVD/VCR RECORDER COMBO
For anyone who has an RCA DRC 8335 with dvd Recorder, here is a suggestion.
If your tapes have been recorded in SLP Mode, om another player, I can tell you they will NOT play on this thing!!
So, merely take another VCR, and a blank tape, Place the blank tape into the RCA DRC 8335 VCR side, and then, go to its Set-Up Menu, and go to OUTPUT. On the "ACTION BAR"Change the the RCA's output to "FRONT" and then, play the VCRr you stuck on top of the RCA!!
When the inage on the "Source tape is shown,
Record onto the RCA, in SLP Mode, Now, it will play, just fine.
Hope this helps. Jon (Found BY Accident!!)
Jul 31, 2009 | Televison & Video
Problem with vertical hold.
with your control push the set up button and on TV Output choose NTSC and Video Output choose S- Video.
Feb 15, 2009 | TruTech TT320
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
Split screen
It appears that it has something to do with Progressive Scan been turned on. Progressive Scan is a feature built in your dvd player, wich by using it, it would give you a better picture//resolution on your tv, you need to use Component or HDMI cables to hook up the dvd to your tv if you want this settings, but if you are using composite RCA cables (Red,White & Yellow) and the Progressive funtion is turned on by accident, it may give you a split screen, black & white, or no picture problems. Also if you are using Component (Blue, Green & Red) cables, if one of them is unplug, the picture can be out of colors, or no picture. Check this things, if not, write back with more details about your set up.
Jun 23, 2008 | Panasonic DVD-RP56 DVD Player
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
Sudden split screen
Your dvd player is in progressive mode, and your tv isnt capable of playing progressive mode.  To fix this, look on your remote for a button called "Progressive", and press it.  If you dont have a button like that, then look through your service manual for anything that says progressive mode, and it should give instructions on how to set it back to interlace mode.  This is a very common problem I come across when servicing DVD players, as inadvertently pressing the wrong button the remote will cause this.
Sep 07, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
I called Panasonic, and they told me to try a reset. I'm sorry, but I forgot which button to push and hold to reset it, but it has worked GREAT ever since! A local shop said it was a loss when I described the problem to them. Call the Panasonic Service Center, and they can tell you how to do a reset.
Feb 20, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
Memorex dvd player pscan split screen
Memorex MVD2042 - The only switch on the back of the unit had gotten bumped when something fell behind the unit, thus causing the same issue mentioned here. Looking at the front of the unit, the switch is straight back from the disc tray on the left. (of course, if you're looking at the back, it's on the right side) This switch is for "Progressive Scan" either "on" or "off" Thanks, Wizard_Yo
Jul 03, 2006 | Memorex MVD2022 DVD Player
Dvd player split screen
Could be that some combination of the progressive scan and the line input is confusing your system. Sometimes the line doubler on the TV set causes this when recieving a 480p input. If this effect doesn't reproduce on another set, then there you have it. Try turning progressive scan off, or change between the analog(yellow) video, the component(RGB), and the S video(fat one with pins). Good luck
May 20, 2006 | Samsung SV-DVD3E DVD Player/VCR
JVC HR-XVC33U DVD Player/VCR Logo
211 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
