Question about E-Machines eMachines Monitor E15T4
COMPUTER MONITOR SAYS NO SIGNAL
MY COMPUTER SCREEN POWERS UP BUT SAYS NO SIGNAL, THEN GOES BLACK, BUT DOESN'T POWER OFF.
  • davejones Dec 12, 2008
    hey I have the same problem.... but it just randomly started doing that.... it was working before but then i turned it off and when i turned it back on it did whats happening to the gsmathis computor so it was working then suddenly just started doing this got any idea?
  • Anonymous Dec 12, 2008
    i have the same prob, i power up my computer and it pops up on the screen no sign, the monitor switches its self off but the computer is still on. i have tried a diffrent monitor and the same thing happens, so it must be my computer. Any help would be great. ta
    Scholar:
  • 45 Answers
Your monitor may not be compatible with your computer. Is it the monitor that came with the computer or an aftermarket one? One surefire way to tell if your monitor is the problem is the simplest trick in the book. Get another monitor and hook it up to your computer, I know easier said than done but borrow a friends or something and this will definitely answer your question. If another monitor works on your computer it's definitely the monitor and that can be a slew of things like not enough power is going to the monitor, it needs a driver to work with your computer or it may be broken or not working properly. Just see if the other monitor that you test works on your computer and get back to me.
Posted on Oct 31, 2008
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
I need to unlock my monitor
Here is a link to the manual for your AOC 22" monitor.
When the window opens you will see "pdf downloads" on the right side of the page. Click on your manual and download it.
Hope this helps to unlock it.
http://us.aoc.com/support/manuals_drivers
Nov 13, 2009 | Computers & Internet
When PC is not used, screen goes black, then Check Signal Cable
right click on your desktop.go to properties.in properties go to the screen saver tab.click on the screen saver tab.under the screen saver tab you will a tab called power.click on power.change you monitor settings there.let me know if it works
Sep 07, 2009 | Computers & Internet
Dell E171FP Monitor goes black after 2 secs
Hi, I don't think the problem is with your monitor. Your monitor sounds like it's doing exactly what it's supposed to do. The monitor is supposed to turn off if there's no cable attached, which means there's no signal input. When the screen goes black, does the power light stay on and turn orange? or does it go off as well? I would recommend that you lower your screen resolution to 1280x1024 or lower in the Display Properties window, then remove your primary monitor, and connect the monitor to your desktop computer. You should see it light up when connected. The monitor auto-senses when there's a computer attached to the cable and when there's a signal. If it doesn't see a signal, it goes black to save power.
Jun 17, 2009 | Dell E171FP 17" Flat Panel LCD Monitor
Why do I get a "No Signal" on my Acer x193w monitor?
sounds like a video card issue.  Check the screen on another computer.  If it is doing the same thing, it is the monitor.  If it doesn't, then you have a video card issue
Feb 24, 2009 | Acer X193W LCD Monitor
Monitor comes on, I can see everything perfect then goes black
"Most" newer monitors will let you know if the are no longer receiving a signal. Sounds like the backlight is burnt out. Try getting a bright (LED works best) flashlight and shining it at the screen at all angles to see if you can see any of what you were doing. If the backlight is on the fritz, either return it on warranty or buy a new one.
Jan 31, 2009 | Westinghouse L2046NV Monitor
Black screen, blinking power light, no signal
Hi...there,
It's seems you got a defective DVI card. Try using a VGA cable instead. Have nice day!
Aug 22, 2008 | ViewSonic VX924 19" LCD Monitor
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
StudioWorks 700s Monitor No Signal
Try to connect the monitor to a different desktop/laptop, to see if it works at all.
Try a different monitor on your computer, to see if the video-card in your computer is the problem.
Or, spend $50 to $100 to buy a used 15-inch or 17-inch LCD monitor.
Sep 20, 2007 | Computers & Internet
E-Machines eMachines Monitor E15T4 Logo
335 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
