Question about Whirlpool Refrigerators
Whirlpool refrig side by side
The bulbs on the fridge side make noises. We took off the bulbs and replaced them with new bulbs still the bulbs makes flickering noises..so took out the new bulbs as well..
    President:
  • Whirlpool Master
  • 2,651 Answers
Flickering noises??? are they working at all. or are tehy flickering on/off along with the noiise. id be willling to bet that if you removed the back panel from behind the refrig, youll find a control board mounted on the left side(when lookin at from behind) alongside the compresssor assy in a white box. if thats the case that, that there is a board there and your lights are not functioning and you hear "chattering" when the doors open you have a faulty board, look up via model number and replace it
Posted on Nov 01, 2008
The fridge light flickers and makes a strange knocking noise when screwed in. I put in a new light hoping that would help, but it didn't work. The mechanism which displays the freezer and fridge setting...
I suspect the main control down by the compressor may be faulty. Without a model number I can't give you specific information, but these controls have a pretty high failure rate. The "knocking" you describe is likely the relay(s) chattering. The board controls every function on the refrigerator, including the turning on of the lights. Have someone screw the bulb in while you are behind the refrig listening down by the compressor area. The control is mounted to the LH side of the compressor in a plastic case.
Dec 29, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
New whirlpool refrig. freezer ok at 0 but refrig
The freezer get the first crack at cooling and combination units have a fan and adjustable vents to steal some of the cooling capacity for the refrigerator. The vent are normally located in the back of the refrigerator compartment and with these, you can balance the cooling capacity between freezer and fridge. I recommend you swap your thermometer back and forth until you get the balance you want; typically the freezer should be at 5 degrees F or below and the fridge at 35-40 degrees F. Adjusting the control for temperature and having the vents set to supply the cold air you want in each compartment should give you the range you want in each.
Sep 09, 2009 | Whirlpool Freezers
Bulb went uot new bulb not working
...will need to check power at socket. using a multimeter.
Jun 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Light won't work even tho changed bulb whirlpool fridge
Have you checked the door switch, might be stuck in or defective.
Apr 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool GD5RHAXNT00 Side By Side Refrigerator
your  problem on this is the main control in the compressor compartment. unplug your refrig then remove this control unplug all connectors and reconnect. this will probably get you working temporarily In almost every case I've seen we ended up replacing the control board. thx peyton
Feb 07, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
FREEZER OK / FRIDGE SIDE NO INTERNAL LIGHT & NOISE
your refrig has a bad electronic control heres the part #W10135090 the noise your hearing is an internal relay on the board buzzing trying to turn the lights on. i found the part at sears.com and it was ony about 80 bucks it is a plug and play part so you should be able to replace it yourself. the board is located in the white box next to the compressor in the back of your refrig. thanks peyton
Jan 13, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold refridgerator light not working and is making funny noise
Had the identical symptoms with my Whirlpool Gold GS6SHEXNB00 side-by-side refrigerator. Had a technician come on site, indicated it was the "circuit board/ timer" (Whirlpool part # 1394052). Board is accessible from behind fridge (lower left side in a white plastic housing to left of compressor).
Swapped the board out (noticed a scorched circuit on the old circuit board). Lightbulbs now work, temperature readouts also good to go.
Mar 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Lights out in the fridge side only
yes, and it should be covered under warranty. whirlpool has experienced problems with interference on this model . could have taken out one or both of these. control 2303805, and 2304056. tech must also install a ferrite insulator on control to filter interference and move the water valve wiring away from all other wires. use this info to get it fixed under warranty.
Jan 31, 2008 | Whirlpool GS5SHAXN Side by Side...
Refrigerators Logo
166 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
