Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
I am trying to wire up a new bell box to an exisiting panel the wiring layaout is as follows panel : 19.20= strobe ( with link ) T A (SCB) DB (BELL) BOX : HOLD HOLD- TG- STB- RETURN I have followed the insructiond as per manuel but to no avail i can get the strobe to work but not the bell please help
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    Are you working with a Portman BL-1000 BELL-BOX?
    Novelist:
  • 91 Answers
Bell wire is color coded ,red terminal red wire ,white terminal white wire , when connecting theese wires be careful not to staple into one by accident because it will definetly cause a short , don,t worry it won,t cause a fire because it is low voltage , you can stick the wire in your mouth and still not get a shock , but seriously the wire that comes with theese machines is flimsy and can get broken fairly easy , just double check your wiring , infrared sensors are white and black and must be put in the proper stick in terminals on the machine , Here is your configuration from left to right ,RED/WHITE /WHITE,BLACK , remember do not take the white wires from sensors and stick them into the white terminal next to red because that one is for the bell and the whit thats next to the black is for the infrared sensors ONLY theese two cannot be crossed and always keep the two wires together till your ready to wire to the machine because if you seperate them before they are impossible to distinguish from one another when it comes time to wire it to the opener ,Hopefully i was able to help you ,if you have any more questions i will be happy to answer them , lets get this thing working Sincerely Glenn
Posted on Mar 04, 2009
Gardtec 370 repetitive bb tamper alarm
Yes any bell box will do. Just note your terminals.
you can link out the bellbox tamper from the control panel as a temporary measure until you replace the bellbox, assuming its faulty
Apr 12, 2014 | Home Security
Digital timer switch and LED light
Timer is wired incorrectly.
White wire is a neutral.
Copy following link for correct wiring instructions.
http://waterheatertimer.org/How-to-wire-timers.html
Aug 19, 2012 | Hardware & Accessories
I HAVE 3 NOS DB IN DIFFERENT LOCATION FOR LIGHTING HOW TO MAKE 1 TIMER PANEL TO CONTROL THOSE 3 LOCATION OF DB
What is NOS DB?
You want to control 3 locations of lights using 1 control panel.
Are you going to run wire from each light to the control panel?
Are you using 120Volt or 240V? What voltage are you using?
Model number of control panel is unknown, and which timer is inside control panel is unknown. Copy following link for overview of control panels.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#pool
Aug 05, 2012 | Intermatic 40 Amp Control Panel & 220V...
We have installed the timer and when on manual the light strobes
Your timer is wired incorrectly.
Copy following link for wiring illustration and explanation.
For more help, include the timer model number and add what type switch you are replacing.
Aug 01, 2012 | General Electric Hardware & Accessories
How can i get the tamper light to go out, so i can reset my alarm on the cooper menvier 9448+ alarm control panel
Find out where the tamper fault is. This panel has tamper monitoring for external bell remote keypad zones and cover. Check all devices for loose covers ,wiring for breaks (especially if new carpets fitted) and bell box.You can check for continuety with a multimeter inside the panel you should have a short between A/T terminals and between 0v and TR if not check the wiring.
HTH
Oct 06, 2009 | Kitchen Appliances - Others
I am attempting to install an after market stereo system in a Ford F150 1999 model. I have, unfortunately, run into a small problem, there are two plugs that connected to the original stereo I bought a...
This is a useful website to help in identifying FORD plug/socket wiring
http://www.tehnomagazin.com/Auto-radio-car-connector/FORD-Car-Radio-Wiring-Connector.htm
Sep 20, 2009 | 1999 Ford F150 Regular Cab
I need a radio wiring diagram for a 2004 pt cruiser
There is a sticker behind of the radio, but if you don't have radio, here some help: B+ 1 PK/LB B+ 12 PK/LB Panel lamps 3 OR IGN 2 RD/WT PCI 14 VT/YL GND 11,22 BK LeftRear+ 18 RP/YL LeftRear- 19 BR/LB RightRear+ 21 DB/WT RightRear- 20 DB/BK LeftFront- 10 DG LeftFront+ 9 BR/DB RightFront+ 7 VT RightFront- 8 DB/RD
Jan 04, 2009 | 2004 Chrysler PT Cruiser
Intruder alarms
you get i tunes , then drag the songs that are mp4 over too i tunes.
Jun 17, 2008 | Computers & Internet
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
47 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Vince Heuser
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
