Question about Onkyo TX-SR602 Receiver
Onkyo TX-SR502 AV receiver
When powered up there is no sound at all. It receives a signal , but has no output. It is three or four years old and has had only medium use. I have a TX-SR602 and the same thing happened this morning. Working fine last night. Could only find 4 fuses but all were good and power related. Everything works on unit except sound output.
  • 905 Answers
This could be the pre amp transistor or the power amp that needs replacing
the pre amp transistor is cheap but the power amp is not
if you did not crank it , then it is probably just the transistor that needs replacing
electech
Posted on Oct 31, 2008
I'm trying to connect my old onkyo tx-sr502 receiver to my panasonic smart tv and my xbox 360 to get surround sound. Any help would be appreciated
Hello, Since the TX-SR502 does not have HDMI inputs you need to connect the HDMI from the XBox 360 to the TV. You can connect an optical cable from the XBox to the receiver if the XBox has an optical output. If not you can connect the optical out from the TV to the receiver. Connect to the optical #2 port on the receiver and press the video 2 button. You should have audio. Thank you, Onkyo USA
Apr 26, 2017 | Onkyo Audio Players & Recorders
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
When connecting optical inputs there is no audio output
You have to assign each digital input.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR502-Receivers-manual/id/365ag217/t/2/
Search the document for "assign".
Mar 27, 2011 | Onkyo TX-SR502 Receiver
My Onkyo TX-SR502 suddenly no sound output. Why?
Same issue on a friend's receiver. I have checked and no signals from preamp pcb to main amp board, which is idling just fine, all channels. The day he brought in we checked it and it played just fine. I then took apart the faceplate to clean the display window and after that had it working for a day and a half while working on other stuff. He comes back a month later to pick up and now nothing. I have decided this is not going to go any further and just thought I'd share my findings. I think it's time we all move on.
Feb 22, 2010 | Onkyo TX-SR502 Receiver
My TX-SR502 AV receiver has no output sound in any mode but CD. Thsi has been a progressivly deterioration from sometimes sound to finally no sound.
sounds like the receiver input mode may be in the wrong setting. or check the 'direct' button. turn it off
Nov 03, 2009 | Onkyo TX-SR502 Receiver
My Onkyo tx sr502 quit producing sound?
I have the same problem.It's definitely the pre-amplifier board (board with speaker terminals).I did not quite nail the exact component yet but I replaced with a working one and got back sound output.
Jan 06, 2009 | Onkyo TX-SR502 Receiver
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
Onkyo Subwoofer Pre Out Problem
May not necessarily be the out put, discontect the sub from the receiver and see if it still makes a hum, Making sure that you turn auto on, off on the sub woffer.
If it still makes a hum, then you have a earthing problem, you can get a earth filter put on your internal wiring in your home, or you can remove the earth pin on your sub woffer
Dec 13, 2007 | Onkyo TX-SR502 Receiver
Onkyo TX-SR502 - o Sound!
pls make it reset at factory level ,but pls note that you have to keep it in aauto mode
Mar 12, 2007 | Onkyo TX-SR502 Receiver
Onkyo TX-SR602 Receiver Logo
570 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
