Question about Mitsubishi WD-52825 52" Rear Projection HDTV
Mitsubishi Mod. WD-52825 projection tv
Green timer light flashes and TV will not turn on. Is there aan easy fix?clyde@nextfrontiermedia.com
  • 4 more comments
  • Anonymous Nov 17, 2008
    The timer light continues to flash even after pressing the reset. We also do not get a blue screen when it is turned on.
  • Tabboo Mar 01, 2009
    green timer light continues to flash, will not quit but cannot turn on the tv.
    Green timer light continues to flash- tv will not turn on.
  • cc_nike Mar 08, 2009
    52 inch mitsubishi dlp
    green timer switch flashed cant power on
  • Anonymous Apr 20, 2009
    Hardly use this tv. Now timer green light is blinking and tv will not turn on
  • Anonymous Apr 30, 2009
    green timer light is blinking and tv wont urn on
  • 179 Answers
9 times out of 10 it is not an easy fix. however ot is not an expensive fix either. checkout www.tv-techs.com
Posted on Dec 29, 2008
Tv shut off and will not restart flashing green timer light tried system restart also unpluged and restarted checked the cable singnal changed the bulb
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected indication of this is a flashing light on the front panel
this is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Nov 21, 2010 | Mitsubishi WD-52825 52" Rear Projection...
When i try to turn my tv on it just flashs green were it says timer and will not come om what do i do
The V26 DM repair kit from www.tvrepairworld.com should repair that issue. The kiy contains the capacitors and the CD with detailed instructions.
Nov 25, 2009 | Mitsubishi WD-52825 52" Rear Projection...
Mitsubishi wd-52825. red lamp indicator, new lamp installed
Failed caps on the power supply will cause that. The V26 Power pwb repair kit will usually correct that issue. Its available from www.tvrepairworld.com the kit contains the capacitors and the CD with instructions.
Oct 30, 2009 | Mitsubishi WD-52825 52" Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Flashing Green "Timer" light on my Mitsubishi WD-62525
My Sony had the same problem. Unplug from the wall for 36 hours and it should solve the problem
Mar 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Blinking green light
if you are very good at soldering surface mount parts you could fix it yourself, however you could destroy it too. the chassis is bad. check out www.tv-techs.com
Nov 22, 2008 | Mitsubishi WD-52825 52" Rear Projection...
TIMER BLINKING RED
That set is plaqued with bad capacitors on the PWB, FMT and DM doards. Usually all problems assosciated with that model can be attributed to those capacitors. You can purchase a service manual that they will email you at the following link, and they will provide free tech support to help you straighten it out. Heres the link.
http://servicemanuals.vstore.ca/
May 03, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
Mitsubishi WD-52825 52" Rear Projection HDTV Logo
583 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
