After turning on computer just beeps
Computer just beeps after being turned on. disc drawer won't open. Doesn't start system.
  • follin_clift Oct 31, 2008
    thankyou mstahulak24 if the ramis bad how do I fix the problem.
  • Melissa6 Feb 08, 2009
    My computer just beeps when turned on. I took it into bestbuy, they told me I needed a new hard drive. I replaced the hard drive and it worked for a couple of days. Did replacing the ram work?
  • 149 Answers
Your RAM is most likely bad
Posted on Oct 31, 2008
  • matt Stahulak Nov 01, 2008
    you need to open up the side pannel and look on the main board theres a green chip on there its about 6 inches long and very thin theres 2 clips 1 on top and 1 on bottom push them in and take out the ram take te ram to like a computer store or even best buy but it will be more expensive there so u for sure get the right replacement then just push it in the slot and the clips will click on u will hear them
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Dishwasher beeps but won't run
There could be several reasons for the beeping. The dishwasher checks for sensor to make sure it is in good health before it starts. Most likely the drawer close sensor is detecting fault. This is to ensure the drawer is closed fully to avoid water leaks when dishwasher is on. Sometimes sensor itself has failed and has nothing to do with position of drawer. Open top cover carefully to make sure the drawer is travelling ok on the rails. TAKE MAINS POWER CABLE OUT BEFORE WORKING ON DISHWASHER.
Mar 17, 2013 | Fisher and Paykel DD24DCTB6 Builtin...
Computer shows ddo &won't finish the wash
Hello noella_30 - Typically DDO indicates that the washer has detected a problem with the dispenser drawer. Either the drawer is open and will not close properly or a professional needs to check reed switch.
Dec 02, 2012 | Frigidaire GLTF2940ES Front Load Washer
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Go Video DV 2150 - DVD door won't open at all. You can hear a mechanism working behind the closed door, but nothing happens and the door remains shut. Any advice??
There is a small belt under the loading tray which would have gone slack ( loose ) and the sound you hear is it slipping on the motor pulley. If you are confident you can remove the mechanism and turn it upside down and access this belt. Dismantle only if you can get the spare belt or your efforts will be in vain.
Sep 13, 2011 | GoVideo Go Video DVD/VCR Combo
Drawer won't open and get beep code 2 short 1 long
The drawer door seal is locked in. This could be either because the controller has lost power or the seal actuator motor is faulty.
You will have to force open the drawer before you can do anything. (Turn off the mains power when you work on the dishwasher)
Let me know if you can handle electric/ mechanical repairs so that I can guide you further. Otherwise you should call a technician. If you are getting beeps then most likely the door seal system is the problem.
Are you able to use the top drawer?
Jul 26, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Disc drawer won't open and sometimes doesn't power off
The disc drawer is broken, there are motors that open the drawer (what you hear when turned on and off) and it must of got damaged by a cd or some other way. If you want to open it, pry it open with your fingers or screwdriver. I had to take the 5 cd holders out to see the problem and there was a cd that jammed everything. But you might not have that, take a look. And the "bye bye" thing is normal but not if it wont go off at all.
Oct 06, 2009 | RCA RTD207 System
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Fisher-paykel dd203 started filling with water with drawer open
what you can do is take a baster and empty out the water; then check and see if anything is at the bottom of the machine inside meaning under the thing that twirles and anything that is long put on top rack.Because you can something that is stuck or gunk that is blocking the way
Oct 23, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
F&P dish drawers model DD6031
It may be that the DW thinks the drawer may have been pulled open. On the right side, near the top. there are two light pipes on the drawer. One sends an infrared beam of light to a reflective area on the cabinet, the other receives this light. This is how the drawer senses whether the drawer is open or closed. Wipe these areas with a clean dry cloth.
Apr 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
