Question about Toshiba E-STUDIO 850 Copier
Department counters toshiba e studio 850
Will not copy/print, it says check dept. counters....it just gives me the count. Bought the machine used do not have admin pass codes. Can they be reset. WHat do I have to do to dept counters
  • 6 Answers
SOURCE: toshiba studio 35
switch off...hold down 0 + 8 keys,
switch on holding keys for 5-10 secs then let go.
service mode...
punch in 251 then print key should show pm set figure,punch in say / add 20,000 on to figure then press set in the display.
switch off then on should have cancelled prevent maintenance.
Posted on Jul 17, 2008
  • 168 Answers
SOURCE: when i print online, copier counter does not give me print count
if you have the codes in the copiers allready you need to turn job accounting on in the print driver settings find copier under your pronters and faxes right click on it select properties then i believe under the device settings you have to check job accounting then enter the id code
Posted on Dec 11, 2008
Bubbabear64
  • 2794 Answers
SOURCE: wrong count
It may need a firmware upgrade to fix the count. You will have to contact a Toshiba dealer in your area to get one.
Posted on Jan 28, 2009
copiersplusw
  • 136 Answers
SOURCE: Toshiba e-studio 230 call for service
Call a Service tech
Have him reset yor Counter AFTER he over checks your copier and inspects the Drum,.Transer Unit, and Fuser Unit chances are the previous tech may not have reset the counter
but call for Service to verify those parts are good first ok. I would not want a counter reset to occur if a fuser unit is bad or something. At that low copies it maybe time for corona's to be replaced.
http://www.copierspluswwllc.com
Posted on Sep 13, 2009
goodgold
  • 389 Answers
SOURCE: a bought a used toshiba e-studio 200 copier , dont have dept cod
Toshiba e-STUDIO
The questions became more frequent In recently as of device. It Is Caused this rather broad spreading of this technology on elbowroom C.I.S. and for his(its) limit. In the first place on itself call attention price. But not all that cheaply bad. Yes, there is determined defect, but with them possible to fight and try to explain some methods fights
In the first place wanted stop on model row. 163/203 - a most budgetary variant and the first swallows in given segment. From option here possible to hang only автоподатчик and additional pallet. Else exactly in these models possible to add the memory. With begin summer 2007 are replaced on 166/206. The Removed глюки in lace trim and is changed a design of the scanner. But if more exactly - that is increased a depth of the scan. The Whole possible memory - in apparate. already
165/205 - a variant for more serious functioning. Here already possible hang the heap an option and transform Your device in serious office assistant. With begin summer 2007 are replaced on 167/207 and is added 237-I machine. Is it Again changed design of the scanner and is added memory. All this is built on one and same basis and, except electronicses and panels of control, given devices nor than do not differ. The Base design of the device was taken from machine more high-class - e-STUDIO 230 (ORS and девелопер are used exactly from this machines, block of the scene itself much powerfully looks like прародителя, but is simplified. Much total moments possible to find and in stove
One of the the most wide-spread questions - than fuel? The Answer rather simple - use the original toner. Shall Not extend to subjects of the ecologies and other мелочевки . On original toner device does not require interference of the service before time of the periodic service. The Producer recommends herewith to change девелопер, фотобарабан, ракель, as well as repair the stove and else much what. For this there is two ремкомплекта. About they will recall a little later. If You are going to to change all on resource of the producer - then possible dare and fuel the left toner, but if You want to prolong the periods to usages of these details - then experiments with toner - not Your way. There is two types of the tubas with toner - on 5900 pages and on 24000 pages. The First tuba starting and goes in kit with device, the second to come already to buy by itself. Possible, certainly, buy and start tuba, but simple mathematics shows that to do this at a loss. The Tuba on 5900 cost(stand)s beside 40 u.e. then, as tuba on 24000 is valued in 80 u.e. (the price very aproximate, but order of the numerals to understand possible). On tuba with toner cost(stand)s the chip, which functioning(working) the device does NOT block. The Purpose of the chip warn the user about that that toner ends that device did not stop without toner in most not suitable moment. Possible use the toner from прародителя - e-STUDIO 230/232/280/282 with пересыпкой in original tuba, but chip will constantly speak of being absent toner. Given пересыпка economic itself not opravdyvaet.
The Second from the частых questions - takes on several sheets . отделительный Roller or brake platform are absent In device. Division sheet is produced with the help of two metallic small piece of coals on edge of the pallet. Accordingly paper before boot in device follows well распушивать and without fall fuel under these small piece of coal. If device persistently continues to take on several sheets - change the producer of the paper, in the most uncared-for events check, симметричность small piece of coal and absence of the deformation beside them. There is else opinion that for successful сепарации of the paper device must be grounded, on my glance this advisable, but not without fall (if paper rotten, that earth will not help
The Third from questions - is not included or error F14 . At first thought this two absolutely problem miscellaneous, but root beside these problems total. In data device for duplication system data and counter is used SRAM board. Small such board installed in main board. At discrepancy given in SRAM board and Main board we and shall get any one of above specified problems. From the personal observations - F14 more often points to bad contact in connector of these boards, than on malfunction data. At failure be included is in general recommended conduct the procedure, as when change SRAM board, only with several uproscheniyami.
We Press 1+3+* and include the device. This combination of the keys cleans the memory a device. Through several seconds we switch off. It Is Done therefor that to clean tuning копира, scanner, printer and fax. If device did not try be included (has snapped the relay and more nor what motion occurs), signifies, problem зарыта much deeper and, possible, come to search for the donor for checking the boards and block pitaniya.
Hereinafter follows to fall into mode 08 (holding 0+8 to include the device) and conduct initializing the codes 05 and 08(in folk given procedure is identified unset on factory tuning ). We Enter 655 and press Enter (for 163/166/203/206 press start ). After device will finish to twinkle the led a level to exposures to press Cancel (for 163/166/203/206 press Function clear ). Then we enter 388 and once again Enter (for 163/166/203/206 press start ). This command copies given from Main board in SRAM board; once again дождаться the completions перемигиваний led. Switch off the device and conduct clear to memories once again, but already several other areas - press 1+3+# and include the device. After given procedures device is usually included and leaves in working condition, but afterwards happens to to tune the codes 05 and 08, but in the same way occurs the unset of all passwords and loss some counter. But if more exactly, that gets lost the counters of the functioning ресурсных запчастей (the drum, ракель, grosses in stove and etc), as well as is thrown on zero periodic service counter (about his(its) installation see a little below). The Main counter can change before 300 pages in any side, but on zero his(its) throw impossible. On my glance, the initializing the codes 05 and 08 do does not follow, but I personally got only one device in comatose condition and their own guessworks I check not smog. Possible if device is not included in operating duty, but falls into mode 08, that it is enough will copy the data by code 388 and device оживет, but check was not vozmozhnosti.
The most wide-spread question what throw calling the service? shall leave on dessert. All much simply - in mode 08 codes 252 install in 0. For device with ZHK дисплее we confirm new importance a button Enter , for device without ZHK display acknowledgement new given is produced by button INTERRUPT . Only not it is necessary simply to throw the counter - without fall call on service with change ресурсных details. The Interval of the service beside 16-ti копийных of the machines 72 000, beside more speed 90 000. This interval possible to install and by itself in code 08-251. Exactly in this cell follows to bring given about periodic service after procedure of the zeroizing the device, described above. Napomnyu - for 163/166/165/167 this importances forms 72000, but for 203/206/205/207/237 in this cell follows to contribute 90000. If in cell 251 are installed 0 (that occurs after striking 1+3+*) then in cell 252 counts not to lead. And, accordingly, technical services device will not require in general that for normal сервисника not there is well. Why? On that reason that client can угробить device so that repair on cost will be equal the cost most device if device does not просигнализирует about need of the repair. Well, shall leave importance in cell 08-251 on shame one, his(its) has changed. In cell 08-250 possible bring its telephone number (before 20 signs), and then at faults or need of the service device itself will show where it is necessary to ring for decision all his(its) problem.
As a matter of convenience servicing there is two ремкомплекта: DEV-KIT-2340 and FR-KIT-1640. In the first enter девелопер, ракель, finger of the branch ORS, blade of the selection, net зарядного коротрона, игольчатый коротрон, threads of the carrying and branches (alike
In the second enter: ozone filter, teflon gross, rubber gross, finger of the branch of the teflon (5 pieces), бушинги teflon gross (the pair). Itself ORS OD1600 in ремкомплекты does not enter and his(its) it is necessary to gain apart. The Cost of the details FR-KIT-1640 without ozone filter on five backses less, than cost of the whole kit. Here is such matematika.
Hope, given mark will help the people in fight with not quite comprehensible problem and at first thought terrible, but enough idle time, on closer examination, technology.
Posted on Sep 23, 2009
Toshiba e-studio 18
replace with original cartage.it starts counting.
Mar 13, 2014 | Toshiba Office Equipment & Supplies
How can i check the copy counter of toshiba e studio 181 copier machine
Date:06/04/2013Sir
My digital copier toshiba 181 showing page counting 179113 but when doing copy the previous reading is not increasing , it is stopped in 179113. could you give me suggestion to(Programe) reactivate the page counting.
Thanks
Golam Rabbani
Chittagong, Bangladesh
Apr 19, 2012 | Toshiba e-STUDIO 50F Plain Paper Laser Fax
How to reset maintenance drum in toshiba e studio 200?? Please reply quickly.
You can use the Toshiba e-studio 160/200 service manual for this machine,
Enter 08 Service mode and:
check these addresses
340 Drum counter end setting. Drum Life:160 and 200 are 27,000 copies.
250 is 33,000 copies. If set to 0:Nothing displays.
673 Resetting drum related counters (08/355 and 08/401) works only if 08/869 is set to 1=SRU, if set to 0 is=CRU.
SRU: Service Replaceable Unit.
CRU: Customer Replaceable Unit.
Good Luck
Jun 27, 2011 | Office Equipment & Supplies
How do I find the copy counter function on the E-Studio 600 copier?
If the e-Studio 600 is similar to other Toshiba models (like the e-Studio 452 or e-Studio 3510c) you can view the copy count by simply pressing the User Functions button, and it should be displayed in the lower right corner.
If you don't see it there, select Total Counter while you're in the User Functions screen, then select Print Counter.
Did that help?
Jun 06, 2011 | Toshiba COPIERS E-STUDIO 600 Copier
How can i change the department code in toshiba estudi 455 series copier
Press the Counter button --> Department Management --> Password --> "123456" (default) --> Department Registration --> Select old dept code--> Change
Mar 06, 2011 | Toshiba e-studio 455 Copier
How do you get the total counter to print? When I log in under Administrator, I can print out department codes, but the total counter will not print. It will only show on the screen.
There is a counter button on the panel that brings up 4 squares. One of them is print out total counter. One button on the panel and one touch on the screen. Hope that helps.
Feb 22, 2011 | Toshiba E-STUDIO 850 Copier
How do i get the total meter count on my toshiba estudio 900?
I'm from Europe,so we don't have here that model (only to e-Studio 850), but it should be the same.
1. Press "User functions" key on the left side of control panel
2. Press "Counter" tab on touchscreen display
3. There You can choose tabs
I hope it helps
Jan 17, 2011 | Toshiba COPIERS - E-STUDIO 900 Copier
We bought a used Toshiba studio 35. The
Hi:
With the copier turned off hold down the 0 and 8 keys together while turning the copier on . Continue holding both those keys down until a function screen comes up. At this point key in 629 and press the Start key. Then press the 7 key and press set. This will disable the Dept code functions. Shut off the machine and power back up.
Good Luck
Andrew
Jun 29, 2009 | Toshiba Office Equipment & Supplies
Wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Jan 28, 2009 | Toshiba Estudio 200L Copier
Toshiba estudio 35
What is the copy count on the machine?
Toshiba copiers have service intervals to replace the drum, cleanerblade, corona wires and developer material.
That could resolve your printing problem.
May 09, 2008 | Toshiba e-Studio 350 Copier
393 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
