Question about RCA RTD255 System
Powering up/DVD loader opening problem RCA RTD255
I bought this a couple years ago, no problems at all and the surround was awesome. Recently, it wouldn't power up, then would with no problem. I noticed it powered up more often when not plugged into a surge protector. Now the unit powers up, but the door and tray loader for the dvd changer won't open. There's no DVDs in there, and the door isn't stuck (I was able to open the door without the power to make sure). What could this be?
  • yhprum Nov 13, 2008
    my RCA rtd255 will power up but will not open up the door to load disks I don't beleave it is a problem with greasing because it does not attempt to open at all.
Your dvd loader sysyem is dirty and needs a little lythem grease on anything that slides.
Posted on May 18, 2007
Hi what you have is a malfunction, and just because the design. look I have a RTD255, I had the same prob that you, what did I do? I desarmed, and underneath the trays, you will find a big pinion, it is the one who moves the tray out and in, it has a screw in the midle a golden one. I removed, then I put the pinion out and I found a wheel moved by an ruber band, thatmoves another pinion this is the pproblem the real one. what I did was to put an screw in order to not let it move up and down. but you must be carefull because no every screw can be located in the midle hole, the idea is to remove a little bit of the black plastic that is in the center an put an screw then yu can assemble your device again and enjoy!! if you need better explications may be an diagram or something like that do not doubt in contact me, because describe the issu is very hard you might not understand what i just wrote. tks any ways
Posted on Feb 08, 2009
How do i program rca home theater
How to Setup a RCA DVD Home Theatre System RTD325W ...
? 10:31
https://www.youtube.com/watch?v=20dRIj8KWPU
Jan 28, 2012 - Uploaded by TheHandofOdd
Just how to setup and get the optical cable working for those who need help.
RCA Home Theater System Set Up - YouTube
? 5:37
https://www.youtube.com/watch?v=j0UhnbrjJto
Sep 14, 2012 - Uploaded by gangstafly5000
The RCA hooked up to 43' plasma Samsung. ... RCA Home Theater System Set Up. gangstafly5000 ...
RCA 5.1 Surround Sound 1000 Watt HOME THEATER ...
? 13:06
https://www.youtube.com/watch?v=1xfEmkwCwyA
Oct 18, 2014 - Uploaded by bigtruckseriesreview .
I bought recently rca system home theater and makes strong fan.... +Aiden woodruff Change he settings to surround, and make sure all of the ...
How to Set Up an RCA Home
Jan 13, 2016 | RCA Televison & Video
Confusion connecting my receiver to the RCA255 dvd receiver for cd use
Ok is your cash converters purchase a RCA, RTD255 system or is the RCA255 you quote something else, I'll assume that we are dealing with the first, and that seems to be a All in one system that contains speaks amp etc
You also have your new AVR 310 which is amplifier that one would connect a stand alone DVD/CD player to, You wouldn't connect the cash converter purchase to it, it is a seperate system.
You could use your cash converter system alone without the AVR310 but not with it.
Nov 18, 2007 | RCA RTD255 System
I have a dvd surround system. The dvd drawer will not open. Any suggestion
Unplug the system from power outlet for a minute then plug in and retry
Dec 08, 2014 | RCA RTD255 DVD Home Theatre System System
My Volume and Channel button won't work and so I have bout 2 remotes, neither of them have worked, one is the RCR311BR remote which has been noted to work for this tv. What else can I do
I have a 2000 model RCA P52923 and I had the same problem occur a couple of days ago. The sound hasn't worked for a couple of years, but the TV is connected to an RCA surround sound to resolve that issue. Most recently, while watching TV, it began to start scanning channels by itself. I shut it off and unplugged it for a couple of days, but each time that I turn it on, it begins to immediately start scanning each channel. Neither the remote, nor the channel buttons on the set are able to stop the scanning, and neither of them will perform any functions, including turning the set on and off.
Any advice would be greatly appreciated.
Mar 11, 2011 | RCA P52926 52" Rear Projection Television
I have the rca dvd 5 dics theatre system (rtd,217a) the problem is the the 1,2,3 changer don't play. I just bought it from the store and they want to exchange it do to the fact I open it
Your problem with the store is unclear. If you just purchased it, take it back. And I urge you to dig into your pockets for something a little better, as this system is not known to be reliable or exactly high-quality.
Nov 20, 2009 | RCA RTD255 DVD Home Theatre System System
Decoding my RCA DVD player
Some players are harder than others to do this but you may want to try here or here
Sep 14, 2009 | RCA RTD255 DVD Home Theatre System System
RCA RTD215
try running a laser eye cleaner-disc cleaner when dust gets on the optics sometimes it wont read the disc
Oct 24, 2008 | RCA RTD255 System
Rca rtd255
if possible i would recommend returning this for a replacement.
May 28, 2008 | RCA RTD255 System
Broken DVD Loader Door
generally they put pressure on the door panel to "open" the door, doesn't really matter where as long as they are out of the way of the disk and the hinge, if you do it correctly they will self seat and not be an issue. hope this helps just keep thinking about it and it will become obvious, while you look at the assembly.
Sep 22, 2007 | RCA RTD255 System
RCA RTD255 System Logo
321 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
