Question about De Dietrich LZ9619 Front Load Washer / Dryer
Washer Dryer - drum is filled with water even when switched off and door can still open!
Washer Dryer drum is filled with water when not in use and when switched off (not from the mains just off on the machine). Washer dryer door can still open with the water gushing out. Machine can still run manual drain and spin cycle as a temporary measure to stop the issue. Is this a washer dryer problem or a plumbing problem?
Thanks.
    Prodigy:
    An expert who has answered 500 questions.
  • De Dietrich Expert
  • 517 Answers
Just need to change the water valve ???take out your soap dish look inside you will see water dripping and it will be the one to change
Posted on Dec 27, 2013
  • 574 Answers
Well your machine running with the door open maybe a stuck door switch so when you open the door the switch is stuck in and therefore it thinks the door is closed. Now, will the water drain out of it at the end of the cycle and then later on it fills backk up with water or is the water just not draining out.
Posted on Jan 22, 2010
    Scholar:
  • 150 Answers
Try the valves inside the back where the water hoses connect to the machine they should default to the closed position when water is not required
Posted on Sep 23, 2009
I have SE showing on my Samsung washer/dryer please respond with any suggestions
Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
Sep 30, 2016 | Samsung Washing Machines
I have the LG wm2487h*ma front load washer.My washer is filling up with water when not in use. When I wash a load, the water does not go in the washer. Have opened the door thinking the wash cycle is done...
The problem would appear to be the water inlet solenoid valve.
The valve is not operating correctly for some reason allowing water into the machine even when switched off
Sep 02, 2017 | LG WM2487H Front Load Washer
My maytage washer went off balance. just discovered it and it doesn't drain, spin, wash the timer works and it also fills. It just clicks. How do I fixi t?
If the inlet valve works to bring in water to the drum and still the washer does not start then the water level sensor can be defective.
You need to check on the voltage on the timer controller unit to confirm if there is a output even after the water fills up. also check the door switch , if open the washer will not start.
Sep 09, 2011 | Refrigerators
The washing machine fills with water but then the door light comes on and the drum wont turn
Hello
The door light comes on when the washer control senses that the door is still open, please check the door lock assembly and the switch. You can also test it with a voltmeter and check how many volts its getting, you can also take a hair dryer and blow air on the door lock assembly so that if there is any dust this will blow it off. If the door lock/switch tests fine then check the wire going to the control. Please get back to me if you have any other questions.
Kevin
Nov 17, 2010 | Tricity Bendix AW1200 Front Load Washer
Drum keeps filling with water even in dryer mode
Open up the top of the machine. Plug off the wall mains. Turn off the wall faucet. How is the wire connection for the inlet valve, the water inlet. Fine? If not unscrew the inlet valve from the corner of the machine after disconnecting the hoses, & dismantle to clean it up, re-assemble, refit back to machine.
Mar 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Even when not programmed to the washer/dryer fills up with water?
Check the water inlet valves, located where the water lines plug into the machine. Also check for proper water pressure and make sure that your water pressure is not surging. If this help please rate. Thank you
Feb 12, 2009 | Hotpoint First Edition FEW12 Front Load...
Continuously fills with water
I'd suspect that the water level switch was malfunctioning. It's easily checked once the top of the washer has been removed. There is a tube running up to it from the tub. Water going up the tube changes the pressure on that switch and it reacts, opening to shut down the fill valves.
Doug
Jun 09, 2008 | Equator EZ 3612 CEE Front Load...
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer problem
front load washing machine all in one are designed to use water supply also in drying cycle to condensed the hot air & move it out to outside , can you check the faucet if its open, so the moist unside the drum can out to the drain and the machine dry properly,if its ok & no water fill to drum may be your inlet water valve for the drying cycle has a problem.So that the time to call a technician to check it .
May 01, 2008 | Electrolux EW1200i Front Load Washer /...
GE washer wont spin or wash
It sound like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. Look if the switch is broken or loose. In case it looks OK mechanically, it might be defective electrical and should be replaced. Good luck!
Sep 09, 2007 | Washing Machines
De Dietrich LZ9619 Front Load Washer / Dryer Logo
282 people viewed this question
Top De Dietrich Washing Machines Experts
Are you a De Dietrich Washing Machine Expert? Answer questions, earn points and help others
