Question about Sprint Hitachi P300 Cellular Phone
Hitachi EX 450 LC instruction manual repair heater blower motor in cab...
Do you have manuals for large machinery made by Hitachi?
How to repair a blower motor
Replace faulty motor. Not worth trying to repair. Shop manual gives step by step details.
May 24, 2015 | 2012 Chevrolet Colorado 1LT Crew Cab...
Heater ac fan won't blow 05 silverado. Started truck on cold day fan was blowing and turned it off waiting for truck to warm up and heater would not come back on. Checked all the fuses, all were good. Fan...
Test the electrical circuits ! Manual HVAC or automatic HVAC ?
Do you know the difference ? Heater / A/C blower motor electrical control diffrent . Manual has resistors an a relay for different speeds , automatic has a blower motor control module .Free wiring diagrams here http://www.bbbind.com/free-tsb Enter vehicle info year , make , model and engine size . Under system click on HVAC ,then under subsystem HVAC controls will pop up . Click the search button , then the blue links . First off you need to know what system yours has , manual or automatic.
GMC Yukon HVAC Blower Motor Won Turn On
Blower Motor Problems Auto Repair Help
Feb 27, 2018 | 2004 Chevrolet Aveo
Heater fan only blows on high speed
most likely the resister. Not very expensive part and should be easy to change out if you know where its located ( usually under the dash) You can buy a repair manual for your model at any parts store, and be sure to ask the parts guy if he knows where its located. he might just be able to save you the cost of the manual. Good luck with it.
Nov 27, 2012 | 1998 Chevrolet Cavalier
Looking for a manual for a KTM 450 smr
Thank you for contacting FixYa with your inquiry.
Here is a link that will take you to useful information and the manual for this bike.
http://motors-bay.com/ktm/266-ktm-450-smr.html
Here is an alternate site allowing you to download in pdf format. http://safemanuals.com/user-guide-instructions-owner-manual/KTM/450-SMR-_E
This is probably the best site: http://www.pdf-manual.com/user-guide-instruction-owner-manual-ktm-450-smr-supermoto-2004-17823.html
Thank you again for contacting FixYa please advise if we can provide further assistance.
TF
Apr 07, 2011 | 2004 KTM SX 450 racing
My heat has stop blowing. replaced blower, and heater on off switch. what else could it be?
LX? DX? EX? Hatchback? sedan? wagon?coupe? engine size? did you check the fuse? Fuse #19, 30 amps in the auxilary fuse box (your owners manual may show the location ,it may be near the blower ?). The Blue/White wire at the heater blower motor should be HOT (12v) with key on. If you ground the Blue/Black wire the motor should run full speed.
Dec 17, 2010 | 1991 Honda Civic
The heater fan motor quit on my 2002 Ford F-150 Super Cab and I can't find a fuse for it. How do I repair it?
Owners manual lists the fuses as :
Engine compartment fuse # 105, 40A
- This is the power to the blower motor relay to drive the blower.
Cab Fuse Panel, Fuse #22, 10A. This is the power to the switch in the HVAC panel.
- This fuse through the switch to operate the relay coil on the blower motor relay.
The other thing to check is the blower motor resistor, to see if there is any damage to it ( usually this is the blower only works on high )
This is behind the glove box
Nov 02, 2010 | 2000 Ford F150 Flareside SuperCab
Heater blower motor repair need to know how to repair or troubleshoot heater core works but doesnt blow heat into car
First check all your fuses. If you have power to the blower motor and it is not working then you are probably going to have pull the blower motor. This usually involves pulling a large portion of the dash. I recommend you buy a Haynes manual from autozone (approximately $20) for guidance.
Feb 11, 2010 | 1997 Oldsmobile Bravada
What size fuse does the heater take?
The Blower itself is a 40A in the Engine compartment fuse panel, Fuse # 105. This is to the blower motor relay ( under the dash with the flasher relay ), to power the blower motor.
The function selector panel for the manual HVAC version is the cab fuse panel, fuse # 22, 10A.
The blend door actuator is cab fuse panel, Fuse # 5, 15A
AC fuses are seperate fuses from these.
If you did not get an owners manual with your truck ( purchased used ), you can download one from Ford :
https://www.fleet.ford.com/maintenance/owners_manuals/default.asp
Nov 21, 2009 | 2001 Ford F150 Styleside SuperCrew
Blower replacment f-150 03 were is it and how to change it
THE BLOWER MOTOR FOR THE HEATER/AC SHOULD BE LOCATED ON THE FIREWALL. DEPENDING ON ACCESSORIES, IT CAN BE A LITTLE DIFFICULT TO ACCESS. I SUGGEST YOU GO TO A LOCAL PARTS STORE AND ASK TO USE THEIR "CHILTONS REPAIR MANUAL" (OR PERHAPS YOUR LOCAL LIBRARY), FOR YOUR MAKE AND MODEL OF VEHICLE. THERE SHOULD BE TWO WIRES AND SOME TYPE OF HOSE TO REMOVE AND THEN REMOVE THE THREE SCREWS THAT ATTACH IT TO THE FIREWALL.
IT SHOULD THEN PULL STRAIGHT OUT OF THE FIREWALL FOR REMOVAL. A LITTLE TWISTING OF THE MOTOR TO BREAK THE SEAL IF IT IS NEEDED. AGAIN, I SUGGEST THE CHILTONS MANUAL FIRST, IT WILL BE OF GREAT ASSISTANCE. GOOD LUCK............JLR4
Jul 27, 2008 | 2003 Ford F150 Regular Cab
Sprint Hitachi P300 Cellular Phone Logo
249 people viewed this question
Top Sprint Cell Phones Experts
Vernon Taylor
rgnestle
Level 1 Expert
Are you a Sprint Cell Phone Expert? Answer questions, earn points and help others
