Back to:
Tags:
Microsoft Windows XP Professional for PC
Crashing during Windows Setup
posted by Lane5slacker on Sep 17, 2006
I am loading XP Pro. I boot from the CD and it goes about loading all the drivers and what not. When it gets to the part when it says "Starting Windows" the hard drive light blinks a couple of times then it crashes to a BSOD. The error code I get is STOP OxOOOOOO7B. I have tried this with two different hard drives.
Mobo - ASUS P5LD2-VM Socket T (LGA 775) Intel 945G Micro ATX Intel Motherboard - Retail
Comment by Lane5slacker, posted on Sep 18, 2006
All the hardware I have is pretty standard and supported. I have no PCI cards installed and I useing onboard video...
Western Digital Caviar SE WD1600JS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive
Intel Pentium D 805 Smithfield 2.66GHz LGA 775 Dual Core,EM64T Processor Model BX80551PE2666FN
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5400) Dual Channel Kit System Memory Model F2-5400PHU2-2GBNT
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Sep 17, 2006
Thanks for Trying (70)
vijay
Rank:Master Master
Rating: 83%, 62 votes
Check out any hardware that doesnot supports windows xp. remove that and reload the os. it works.
or
remove all the additional addon cards like modem, network card, printers etc., (just maintain only hard disk, cd rom and floppy drive)then install the os. once os installs add the components one by one to so that the os will detect one by one
cheers!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Crashing during Windows Setup:
I don't want to Accept this solution
Solution #2
posted on Apr 02, 2007
Not Rated (0)
dasdasdasd
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Dear sir ,
iam using internet in my pc. when i concted internet net is concted properly.after 15 to 20 mints net is automatically disconcted. im using windows xp pro. i had formated the my hard disk so many times .but the problem is not solved. pls help me
Thank You!
Can you Help with these Operating Systems problems?
I have a new to me/used computer that I know works,...
Why can't I open profile I click on profile but the little...
wm internet went out when dell walked me thro it came back...
no there is no file like that in the windows folder.
http://www.wireshark.org/ Im captureing only spesific...
Loading problems.
Repair Service
Find Operating System Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
