Question about HP Computers & Internet
Not able to record sound on Conexant AMC
My HP Pavilion ZE 2000 is not detecting mic. In recording control, Microphone's control is disabled. In speech control, there is only text to speech tab and no speech recognition tab. But it is recording sounds which are coming on speaker.
    Scholar:
  • 136 Answers
Maybe you should uninstall and reinstall the drivers, so that the mixer device is set properly.
Posted on Oct 31, 2008
How can i disable HP 6910 Integrated Microphone. I do not want the mic picking up sound automatically.
Hi there!
You will have to go to Start - > Control Panel - > Sound and Audio Devices, then click the Voice tab, then click the on the Voice Recording section, you can modify the Volume of the Microphone to your liking.
Best regards!
May 02, 2011 | HP Pavilion dv6000z Notebook
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
HP pavilion dv9005us. When using built in mic receivers say volume is very low. When I move the lid I get a crackling sound in the speakers like the mic wires a lose ..
To fix the low volume problem in mic receiver follow the steps below:
  1. Click Start , Control Panel .
  2. In the left panel, select Classic View .
  3. Select Sound , and then select the Recording tab.
  4. Right-click on Microphone and select Properties .
  5. On the Custom tab, select Microphone Boost .
  6. On the Levels tab, increase the microphone recording volume to the maximum level.
Then please check if it works fine otherwise you need to install the latest sound driver.
Windows VISTA 64bit and 32 bitsound driver:
ftp://ftp.hp.com/pub/softpaq/sp35501-36000/sp35684.exe
Windows XP sound driver:
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34200.exe
Install the sound driver as per your operating system.
Apr 04, 2010 | HP Computers & Internet
Internal microphone does not pick up sound
Have you tried to go to Control Panel>Sound>Recording Tab and be sure that the mic is not disabled? There are also adjustment levels there too. If all else fails try to uninstall through Device Manager and allow the PC to rediscover the mic.
Oct 04, 2009 | HP Pavilion dv1000 Notebook
Please help me
You need to check if the mic/s is working?
Are you certain the Logitech webcam has a built-in mic?
To check if the mic works go to Start - All programs - Accessories - Entertainment - Sound Recorder and test record your voice and play back to check, also try it with the laptop's built-in mic (if it has one) and the Logitech mic.
If both mics work then you have a choice of which one you can use in Skype, most likely the best one would be the Logitech one.
You need to configure your audio settings in Skype.
When you open Skype click on Tools - Options - Audio Settings and click on Select Microphone and select the microphone you are using and save the setting.
If you still have problems get back to me with all details and error messages.
May 15, 2009 | HP 510 Notebook
HP Mic doesn't work in sound recorder but does in video recorder
This is not a problem.
Just configure your microphone as a recording device under Recording device properties.
You can do it by double clicking on the volume control and get to the recording devices property pages.
You can do the same through Control Panel as well.
Hope this helps.
Thanks.
Mar 16, 2009 | Computers & Internet
Hp Dv6000, problems recording with built in microphones
go into your device manager and disable the onboard microphone
Feb 13, 2009 | HP Pavilion dv6000z Notebook
How do i disable my built in microphone?
double click on the sound icon in sys tray to access properties and disable from there or just turn the slider all the way down
Jan 30, 2009 | HP Pavilion dv6000z Notebook
For Vista:
1) go to Start > Control Panel > Sound
2) click the recording tab
3) Right click the device that is not the new one you bought.
4) choose Disable
For XP:
1) Right click My Computer or go to Start > Control Panel > System
2) On the system window click the hardware tab
3) Click the Device Manager button
4) Scroll down to the Sound, video and game controllers.
5) Look for any device that is not your new mic as well as your sound card.
6) Right click and disable anything that are not the mentioned above.
7) Exit and test.
If you have XP and the XP Method above doesnt work then please make a comment stating so so I can give you another solution.
Dec 17, 2008 | HP Pavilion dv9000z Notebook
Hi i have an hp pavilion dv2000 lap top, i am trying to record my acoustic guitar into the comp. This lap has conexant high definition audio sound card inbuilt. However when i try and plug a microphone...
The mic may be muted on the computer. In XP, double click the volume control icon in the bottom right of the screen to get the mixer. If you don't see the microphone input, go to 'options' then 'properties' and place a check in the box to show it. Then make sure it is unmuted and the volume is up.
In Vista, right-click the volume icon and choose recording devices and make sure it is on and volume up.
Apr 23, 2008 | Computers & Internet
Computers & Internet Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
