Question about ASUS P5LD2-VM Motherboard
Sata Hard drive problems
The Sata hard drive I have is always recognized as Third primary master even though it is connected to the Sata 1 plug and is the only hard drive
    Problem Solver:
  • 10 Answers
This is normal- The BIOS shows the IDE bus as the Primary and Secondary master -The SATA 1 bus is almost always the third master.
Posted on Oct 31, 2007
In the Bios, make sure you have set the Sata mode to 'compatible'
Posted on Oct 11, 2007
  • 4 Answers
I have come across this before, and I think its to do with the arrangement of the jumpers on the back of the hard drive. It usually gives a picture on the top panel of the hard drive to show you what way the jumper(s) have to be arranged to make your drive work on the Primary channel. This shouldn't really cause for much concern if your PC boots up from the third primary master, however if you have other harddrives you may have a cause of concern. Hope this helps.
Posted on Apr 02, 2007
WD1001fals as slave
SATA Hard Disk as a Slave b> An SATA hard drive is an internal hard drive that connects to your computer's motherboard. It is even possible to connect multiple drives to the same computer; however, only one drive can be the master hard drive; the other(s) must be slave drives. This is because the master drive has the operating system installed and must be used to boot up the system. When installing a new SATA hard drive onto your computer, you must set it as a slave.
Power down your computer and disconnect the cables. Remove the Phillips screws from the exterior of the computer case and slide the case open to expose the interior of your computer. Identify the hard drive at the front of your computer, then slide the new SATA drive in underneath. Insert the smaller power cable into the power port on the side of the SATA hard drive. Follow the power cable running out of the current hard drive and insert it next to it on the motherboard. Pull out the ribbon cable, which has three different connection ports: one on each end of the cable and one in the middle. The connection port on the middle inserts into the slave drive and is slightly different than the other two ends (the pins built into the port are in different locations than the other ends). Insert the middle connection port into the ribbon port on the back end of the SATA hard drive. Plug one of the opposite ends of the cable (doesn't matter which one) into the SATA connection port on the motherboard (your current hard drive is inserted here). Once connected, this completes your slave drive connection. Second SATA 2 Hard Drive as a Slave b> Installing a second hard drive in your desktop PC or notebook is an option used to increase hard disk space without losing or transferring the data from your original hard drive. Using this method not only increases hard disk space, it also increases the virtual memory space for the Windows operating system, increasing operational efficiency. One of the ways in which a BIOS can recognize the second hard drive is to boot it as a slave drive, with the primary hard drive booted as a master drive.
Turn the PC off and remove the desktop chassis. Refer to the pin connector diagram. This is displayed on the sticker, on top of the hard drive, for the position of the slave pin. Place the plastic connector on the slave pin as detailed on the diagram. Connect the hard drive to the power and IDE/SATA cable. Ensure the other ends are connected to the motherboard. Use the screws to mount the drive. Replace the desktop chassis. Turn on the PC. Enter the BIOS, by default this can be done by pressing F2. If this does not work consult your motherboard manual. In the BIOS, press right until the boot device tab is highlighted. Set the slave drive to boot following the primary drive. Read the bottom line and use the relevant key to save the settings. Restart the PC.
Hope it helps.
http://www.pcmech.com/article/installing-a-hard-drive-step-by-step/ Installing a hard drive.
Jan 24, 2013 | Western Digital WD Caviar Black WD1001FALS...
Unable to make SATA dive as primary master .
Remove the IDE hard drive, and connect the SATA drive to SATA0 (zero) port. Install the OS on SATA drive. You may have to check BIOS. F2 on boot should get you there.
Oct 09, 2012 | Dell Precision Computers & Internet
I have connected my 300 gb sata hdd to my pc which already has a 160gb sata hdd set to master when i start up my pc they r both set to master but i am told sata hdds dont have master / slave settings
They don't have master/slave settings as only one SATA drive can connect to a controller, however some BIOS have a setting designed to facilitate older OS's like XP that don't always have drivers available for the newer SATA RAID controllers built into most mid to high end PC's. If this setting is enabled on your PC then they would look to windows like a pair of master IDE drives on a Primary and Secondary IDE Channel even though each has it's own dedicated controller.
Sep 21, 2010 | Western Digital Hard Drive
Ive built my first pc and all went well until the message no hard drive detected comes on all parts are new so any help would be great in fixing this thanks dave
Verify that the hard disk is connected on both data and power cables and is receiving power (it hums at startup); also that the proper EIDE or SATA slot on the motherboard is used, and properly jumpered (e.g. a SATA 2 disk on a SATA 1 configured port is likely to malfunction).
Check that the BIOS is configured to autodetect the hard disk type, and is using the appropriate adapter (EIDE or SATA port), without RAID options or such.
In a pinch, try also ignoring the motherboard labels (e.g., plug the hard disk on the fourth SATA port instead of the first -- the mobo numbering is not always the "logical" one, even if it usually should be.
Jul 02, 2010 | Computers & Internet
Replacing a hard drive on Sony PCV-RX550 with a Western Digital 320 gig. With the orig disc as primary master, the wd drive is recognized by the bios as secondary master. But when I remove the original...
if you want to connect two hard drive together then remove the jumper of the primary hard drive and don't touch the setting of the secondary drive then start the system.always make primary drive which have the os.
Jan 26, 2010 | Sony VAIO Digital Studio PCV-RX550 PC...
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Start by simplifying the configuration. Disconnect the second IDE cable from the motherboard and disconnect the power to the DVD drive. Disconnect the SATA device. On the #1 IDE cable, connect the master drive to the connection on the end of the cable. Connect the Slave drive to the middle connection on the cable. Start the computer and press the key indicated to enter setup. Verify that drives are properly indentified as master and slave. If they are, shutdown the computer. Now add the IDE DVD drive to the end connection on IDE cable #2. It should be set as a Master drive. Start the PC again and go into setupand verify that the DVD is IDE #2 Master. Shut down the PC. Add the SATA device and start eh PC again. Go into Setup to verify that all of the drives are properly identifed. Restart the computer and let it boot into Windows. Open Windows Explorer to view the drive settings. If the drives are all present, but the letters are not what you want, click on START and then right click on MY COMPUTER and then left click on MANAGE. Under Storage click on DISK MANAGEMEN. The drives will all be displayed with their assisgned letters. If you need to change a drive letter, right click on the drive you want to change and select 'Change drive letter . . .'. Change it to a hight letter in the alphabet, then change the dive you want in the original postion to the now vacant letter. Finally change the original drive to the first available letter. Example: C:=IDE M1 D: E:=IDE S1 Change D: to H: then E: to D: and finally H: to E: they drives would then be: C:=IDE M1 D:=IDE S1 E:=IDE M2(DVD). Restart the PC and the drive should come up as you want them to be labled.
Good luck and please let me know how it works ouot for you.
Feb 26, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Sata HDD set in primary master in Bios
Try considering these:
1. DOS disk doesn't recognize SATA, that's the truth
2. You're going to have a problem if you install OS in your computer (solution: do not select SATA in HDD type but rather IDE)
3. For your SATA HDD to become primary (boot first) try to select your SATA HDD as devic first to boot..
Jan 04, 2009 | Maxtor Hard Drive
CD ROM DETECTION PROBLEM
LEAVE YOU hard drive on primary master port on your main board set as master or single drive ( IF YOU HAVE A STATA HARD DRIVE THEN DONT WORRY ABOUT THAT PART)
SET YOUR FIRST DRIVE AS MASTER
SET THE SECOND AS SECONDARY
use the jumber in the back of the drive to set them the propper setting is labeled on the drive it self
Connect them to the secondary port on your motherboard
so you should have
HARD DRIVE - MASTER OR SINGLE *jumper settiing* connected to the primary port on your main board
DRIVE 1 = MASTER *jumper settiing*
DRIVE 2 = SLAVE *jumpersetting*
connected to the secondary port on your mother board
IF YOU HAVE A SATA HARD DRIVE FORGET THE PARTS ABOUT HARD DRIVES ABOVE
i assumed you had a IDE hard drive
JUST USE THE SETTINGS FOR THE DRIVES and it should work :)
Dec 25, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
ASUS P5LD2-VM Motherboard Logo
267 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
