Question about Sanyo PLC XU35 Multimedia Projector
Green ball on projector screen
When the projector is on the green ball on projector screen shows and somebody said that blue lens may be damaged . Can I repair it or where I can buy replacement? I live in Montenegro!
I have connect to hp laptop with projecter but showing error mouse not working in laptop.mouse is shoing in projector
Posted on Dec 04, 2008
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
Oct 01, 2014 | Dell 1210S Projector
I'm seeing an uneven darker blue or a haze along the bottom after I changed the bulb. Looks like a blue cloud along the bottom darker, very noticable when I first shut the TV off and it blue screens during...
You have something on the lens. If the lens was producing excessive heat it could be the melting around the lens itself, or it could be grease from your finger that was clear until it got hot enough to cook onto the glass. Either way, remove and clean the bulb lens (the one on the bulb you change out when the bulb blows) and then re-clean the focus lens on the front of the projector (the one you turn to focus).
If this doesn't clear it up, look for damage on the focus lens or the bulb lens.
Jun 03, 2010 | Sony XL-2100U Projector Lamp for...
GREEN GLOW on NEC VT 770 projector
That will be a worn or damaged green LCD unit. If still available, extremely expensive.
Jun 22, 2017 | NEC VT770 Multimedia Projector
Abnomal reverse picture
if it was the fault of the technician, they are responsible for the repair. if the green filter is bad, it needs replacing.
Jul 28, 2009 | Sharp XR-32X Projector
I have an InFocus SP5000 projector that has started showing a green glow in mid-screen (center). Before I buy a $300 lamp want to know the cause of the green glow.
either the light filter behind the blue lcd panel or the fly-eye lens (both inside the optical engine) have developed a burn spot from overheating. infocus doesn't sell individual parts for the optical engine, and the whole thing must be replaced. but unfortunately, it's the most expensive part of the projector, usually upwards of $2000 (and there's none in stock).
Jun 24, 2009 | InFocus SP5000 Home Theater Projector,...
Pt-lb10vu has extra colors
Chances are your Blue and Green Lens' need replaced. Common problem with projectors that are used more than what they were designed for.
May 28, 2008 | Panasonic PT-LB10VU Multimedia Projector
Mitsubishi XL8U Projector
Hi terry2421
No this is not the bulb. You will have to get the Mainboard repaired at a service provider. Losing signal and a discolouration showing up is a clear indication of a faulty Mainboard.
Get a quote first , because some service providers overcharge on these sort of repairs. The most you should pay is $150.
May 20, 2008 | Mitsubishi XL8U Multimedia Projector
Big blue dot
This is going to hurt..
You probably have a polarizer failing on one of the LCD panels inside.
There are 3 of these in LCD projectors, red, green, and blue. They all get the light fed into them, that light is then combined and fed through the projection lens.
You will need to contact Sanyo to find a service centre to replace it.
Apr 17, 2008 | Sanyo PLC-SW30 Multimedia Projector
Color not correct on project
Hi there
You will have to find your nearest InFocus repair centre.
But that said , it is the most expensive part on a Projector to have repaired , because they will have to replace it.
My advice would be to rather purchase a new unit.
Apr 15, 2008 | InFocus LP640 Projector Multimedia...
Yellow area in the projected image
Hello Media Man,
Looks like your projector has done it. Thats acommon trouble to ageing polirising lens, usually the blue. less blue, the green and red make up the yellowish image on the screen. The blue is bombarded with tremendous heat from the lamp and it fade and wash out. If its free, its worth replacing. Get quote for the poliriser; 2 pieces each color.
Good Luck.
Sep 28, 2007 | Mitsubishi ColorView XL30U Multimedia...
Sanyo PLC XU35 Multimedia Projector Logo
134 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
