Question about Hotpoint Ultima WF840 Front Load Washer / Dryer
My washing machine is stuck on TEST
My machine is not working. it displays test on the screen, is there any way i can get out of test mode?? is there any buttons to press. help i have children.
I have just experienced this problem and husband has been able to sort it. You just press On/Off and Start/Cancel buttons at the same time for a couple of seconds. You will have sorted this by now but someone may find this helpful.
Posted on Jan 29, 2007
Kenmore Elite HE4T washing machine diagnostic test not completing - getting stuck on C05
http://www.managemylife.com/images/6975/original/346.jpg?1303498921
According to this it could be either the Computer (don't think so but don't rule it out just yet.), the fill valve, or the heater. Appliance Repair Forums
This link will help you test the fill valves.
This will link you to a service manual for the HE3T washer which is very similar to yours and the diagnostics and tests will be the same. https://www.ifixit.com/Document/1074/.pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jan 20, 2017 | Kenmore Washing Machines
SERVICE MODE
From the manual I have
1. Press the power pad to turn on
    press home pad to ensure home screen is displayed
2. Press the help pad. the main help screen is displayed.
3. Press the help and start stop pads for 3 sec simultainiously.
    The factory test screen is displayed.
4. Press test load on the screen.
5. The contrast screen is displayed. Press the start/stop pad once to cycle through the screen
6. press start/stop pad. The test load screen is displayed.
More to come... I will try to copy and paste what it says. I can try to send a copy of the pdf if you give an email.
Oct 19, 2007 | GE WPGT9360EPL Top Load Washer
Hotpoint aquarius washing machine displaying tESt +won't do anything
Someone has accidentally pressed some buttons and locked you into test mode.
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Oct 21, 2012 | Hotpoint Washing Machines
Everytime i put my washing on it goes onto test mode. I reset it so it is back to the on screen and then evertime i press a cycle it goes back onto test mode. Ho9w can i get it out of test mode and back to...
You will have to look at the manufacturer's plate, probably on the back of the machine to find the appropriate date then-
Date code 39, March 2005
Press start/cancel until ALL LEDS are lit
Press both start/cancel AND on/off together until 'dOFF' is displayed
Date code 39, March 2005 to date code 42, June 2005
Press the cancel button and the machine should return to normal
Date code 43, July 2005 onwards
Press both start/cancel AND on/off TOGETHER with top left option button until 'dOFF' is displayed.
Good luck,
John C
Apr 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
I dialed ##8378<SEND>, then clicked
Typing ##8378 Send brings up the phone test screen. When you select #2 (Field Test) and then select OEM monitor and select "enable" the phone resets and enters test mode.
In test mode you can press the volume up button to bring up the test menu. You can navigate this menu using the 1 and 3 keys on the number pad.
The most notable screen in test mode is found by pressing 3 until you reach SHDR protocol monitor will bring up the screen that displays real time reception and transmission information.
Other screens display other system information, but I caution against "playing around" with these menus too much.
To temporarily hide the test mode screen you can press the volume keys again. To take the phone out of test mode completely follow these steps:
1. dial ##test or ##8378 and press send 2. select 2 (field test) 3. scroll down to and select 10 (OEM monitor) 4. scroll down and select Monitor DISABLE 5. the phone will reset and return to normal mode.
Feb 13, 2011 | Casio G''zOne Type S Cellular Phone
My washer is digital, and at the moment every time i press start it says test can u help me
hello, Someone has accidentally pressed some buttons and locked you into test mode.
Your machine should now work. hope it helps
regards
shaun
Jan 03, 2011 | Hotpoint Aquarius WD640 Front Load...
New g.e. Dryer displays a fault code e61 on screen and will not power on or clear...this dryer is brand new...straight out of box with this fault code...
Sorry to read about your problem, I hope this helps you out.
you should have a electrician work on your wiring, with luck no further damage has happened, E61 means you have the neutral and the L2 wire either reversed or in the wrong position.
ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect the power for 30 seconds.
2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.
3.Press the "SIGNAL"button.
4.Press the "DELAY START"button.
5.Press the "SIGNAL"button.
6.Press the "DELAY START"button.
Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | GE DBVH512EFWW Dryer
Washing machine it test mode
To exit the DEMO/TEST mode, press and hold down the "On/
OFF" and "Start/Cancel" buttons until "d off" is displayed
Mar 14, 2010 | Hotpoint Ultima WF860 Front Load Washer
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Hotpoint Ultima WF840 Front Load Washer / Dryer Logo
70 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
