Noticed primer bulb returns really slow after being pushed in
SOURCE: how do you relace the recoil spring in poulan weed eater lt1500le
Hello dan_montecar:
>>The Following is a General Instruction File I Made to Perform this Repair. If you have Any Suggestions or Remarks, then Please Let me Know. Thanks.
>>**Remove the Boom/Shaft from the Engine. Remove the Mounting Bolts and the Boom and Center Drive Shaft should Slide Away from the Starter Housing Assembly.
>>**On Some Model Trimmers, there is a Torx Screw Inside the Coupling Drive that has to be Removed.
>>****There is also a Locking Screw on the Side of the Housing that is a Anti-Vibration Lock.****
>>Using the Breakdown as a Guide Remove the Starter Housing Assembly from the Engine Assembly.
>>Now Carefully/Slowly Remove the Pressure Plate Assembly from the Starter Housing.
>>The Spring May have Broken and Sometimes a Section will Jump Out when the Pressure Plate Assembly is Removed from the Starter Housing. When it Jumps, it Pushes the Recoil Pulley Out Also.
>>Look at the Direction of the Coil of the Spring in the Housing and Make an Arrow in the Direction of the Coil with a Magic Marker on the Inside of the Housing.
>>Remove the Broken Spring and Clean the Housing with Spray Lubrication. You can Use Solvent if Required, Just be Sure to Wipe it Before Assembly with Spray Lubricant. The New Spring should come with a Retainer that Holds it in a Circle.
>>If you have Removed the Spring from the Retainer, then Use a Piece of Plastic Pipe About 2" Long that is the Same Inside Diameter as the Retainer (Slightly Smaller than the Recess that the Spring Coils Into if you Lost the Retainer).
>>Coil the Spring Into the Pipe and then Set the Spring Into the Recess. Make Sure the Spring Tab of the Spring Engages the Spring Lock in the Recess.
>>Use a Socket to Hold the Spring in Place and Pull the Pipe Out of the Recess.
>>Lock the Pulley in Place.
>>Now Turn the Pulley in the Same Direction that the Pulley would Turn if the Rope was Turning it.
>>Once the Pulley will Turn No More, then Reverse Direction 1 or 2 Turns and Thread the New Rope Through the Hole in the Center of the Pulley and Out the Hole in the Blower Housing.
>>Pull the Rope Through Until it is Tight Against the Pulley. Now Tie a Slip Knot in the Rope to Hold the Pulley in Place While the Handle is Attached to the Rope.
>>Once the Handle is Attached, Release the Slip Knot and the Rope Should Retract Into the Housing. Reassemble the Blower Housing Onto the Engine.
>>On Some Models you May have to Install the Rope Before you Lock the Pulley in Place. If So, there is a U in the Pulley that the Rope is Held in While Turning the Pulley to Tighten the Spring.
This is a Basic File and your Unit May be Slightly Different.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog Poulan/Weed Eater.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: ryobi weed eater ONLY RUNS WITH CHOKE ON HALF WAY
Check the carb jets, they might be a gummed up!
SOURCE: Poulan/Weed Eater No. Bvm200le kills when taking
Most likely low compression caused by stuck piston rings or a scored piston
and cylinder. This unit was made by Poulan and they have had an epidemic of this
problem. The solution is to tear the unit down and put in new piston rings.
Before you install the new rings you need to get a sheet of glass and some 600
grit wet dry sand paper. Sand each ring down about .002 to .003 and reinstall.
This should solve your problem as long as you have good fire and the piston and
cylinder is not scored.
You might also need to rebuild the carb.
SOURCE: Troy-Bilt weed eater, Model TB90BC, had rotten
Prime and watch the fuel move up to the carb. This is the fuel line and it should be long. Make sure it goes to the bottom of the fuel tank.
