Question about Paradigm CC-70 Speaker
Center speaker Paradigm CC-70
Sounds is fading away. I increase volume and sound comes back to normal. This problem is intermittent.
Thanks
  • 75 Answers
May be voltage problem..try using stabilizer
Posted on Dec 09, 2008
Renault clio radio not working
Speakers dont usually fade away. IT sounds like there is something in the radio that thinks the volume control is being pressed.
Dec 16, 2013 | Car Audio & Video
I just purchased the RCA RT2910 Theater System yesterday. When I hooked everything up, it was all working great. However, tonight when I was turned it on, all of the speakers were acting weird. They would...
What source(s)? Verify the speaker setup with the test tones to prove the hardware is all okay. Then go back and evaluate the conditions that create the problem. It could be an external cause.
Jun 01, 2011 | RCA RT2910 Theater System
This may not be an actual problem. I've observed after performing a successful Audyssey calibration that a few things seem odd. My large (Paradigm Monitor 11) front speakers are now considered 'small,'...
If it sounds normal, then yes leave them as they are.
But there may need to be an exception made.
The distances are set the way they are for the proper advance or delay in milliseconds of the sound arrival at the listening position.
The system calibrated your speaker settings based on how each channel's frequency responses measured at the listening position. Room acoustics and channel positioning greatly affects this. The settings it made in the system can be a best case scenario compromise that MAY not be good for your surround speakers as it can be delivering signal to them that they were not designed to handle; in which case it is best to increase the crossover value of those speakers.
Mar 29, 2010 | NAD T765
Marshall DSL 100 - volume fades away and gradually comes back on
IF this is a vacuum tube unit, these symptoms are that of a tube that the heater is intermittent, that is it cools off due to a break and then liights again.
Open the back and observe the heaters in the tubes. DO NOT be fooled by some that have TWO heaters in them. (use a mirror if necessary) A single one that comes and goes can cause the problem and the voiration can make it come and go. This behavior in a tube is NOT somthing readily spotted in a tube checker. The delay in fading and coming back would be the delay in warm up following a heater going out and cooling.
Feb 14, 2010 | Marshall Amplification Marshall MG250DFX...
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
Can't find owners manual for paradigm cc-300 center channel
http://www.retrevo.com/s/Paradigm-CC-Speakers-review-manual/id/13247ci865/t/1-2/
May 30, 2009 | Paradigm CC-350 Speaker
Volume fade
Check to be sure there are no speaker wires touching ground, and that the wires are connected in phase to the head unit.
Front Speakers 5 1/4" Doors Left Front (+) Green Left Front (-) Black/White Right Front (+) White/Red Right Front (-) Black/White Rear Speakers 6" x 9" Rear Deck Left Rear (+) Pink/Red Left Rear (-) Pink/Blue Right Rear (+) Pink/Light Blue Right Rear (-) Green/Red
The symptoms you are relaying definately sound like an internal amplifier problem. It is fading in and out for a reason - usually due to heat.
Have you had the radio bench tested (seperate from the car) to eliminate the car as being the culprit?
Since the radio was run with damaged speakers originally, the output or amplifier power supply on the amplifier may be bad.
As an alternative to repairing, I would suggest investing in a small 2 channel amplifier to power the speakers.
The radios claim 50W per channel, but in reality give 12-15W RMS power.
A dedicated amplifier with built in crossovers and gain adjustments will prolong the life of your speakers and add to the tonal qualities of your new speakers. Instead of turning up the volume on the head Unit, and sending out a distorted signal that will blow your speakers, an amplifier will give more CLEAN power to them, so it will be louder at a lower volume setting.
This will bypass the internal amplifier on the radio, and send a Low Level signal ONLY thru a set of RCA cables.
Good Luck!!
Jan 10, 2009 | Car Audio & Video
Car Audio Fade
sounds like you got a bad stereo. it happens. i've i had the same thing happen, but the volume went up instead of down. check all the wires and make SURE they are all hooked up right.
Jan 10, 2009 | 2000 Jaguar Vanden Plas
PAradigm ps-1000 subwoofer
It turns out its most likely one of the resistors on the PCB on the amplifier plate.
My uncle has had the same problem and managed to replace the resistor and its working as normal now.
Jul 14, 2008 | Audio Players & Recorders
JVC dual bridgeble AMP
Have the speaker checked out and if it checks good you need to take the amp back to the repair center and have them test it better. Most repair centers have a 30 day warranty on the work they perform. Make sure they know what the problem is in detail, so they know how to check it properly. But my first thought is the speaker could be faulty. You can check the speaker yourself by switching them at the amplifier. If the same speaker sounds bad you know it is the speaker that is bad. If the sound is bad from the other speaker, then the amp is bad unless it is coming from the head unit. You can also switch the RCA input jacks after that and see if the problem changes speakers, if so, the RCA output of the head unit is bad, but that is less likely.
Jul 01, 2008 | JVC KS-AX4750 Car Audio Amplifier
Paradigm CC-70 Speaker Logo
698 people viewed this question
Top Paradigm Audio Players & Recorders Experts
 Grubhead
Grubhead
woodzowl307
Don Hart
Are you a Paradigm Audio Player and Recorder Expert? Answer questions, earn points and help others
