Touchpad tapping for MSI Wind U100 laptop
I'm unable to turn off the tapping feature of my touchpad - There is no tap for it under ther mouse settings in control panel like my other laptop?
  • Anonymous Dec 23, 2008
    The non-Synaptics touchpad MSI has introduced is very irritating because of the 'Tap to Click' for which no disabling driver is supplied.
    PE London W4
    Scholar:
  • 136 Answers
Usually this on/off feature comes with the manufacturer drivers. If (I'm assuming you are using windows) the OS was re-installed, it just uses a generic driver which does not include advanced options. And MSI seem to not provide this driver (I've searched). Maybe there is an option for it on their System Control Manager. You can download it here:
http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=135&prod_no=1474
In LINUX, it is a bit more complex, because it is not easy to get a specific driver for the touchpads .
Posted on Nov 02, 2008
How to disable mouse pad double tap
On all Panasonic Toughbook models, if the Touchpad driver is
properly installed then you can disable the "TAPPING" feature.
Check under device manager. If the driver says PS2 Mouse,
then you need to locate your touchpad driver. Otherwise
locate the advanced setting under MOUSE under the control
panel and find "TAPPING" and un-check to disable feature.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
May 10, 2014 | Panasonic Toughbook CF-52 (CF-52ELNBDAM)...
Cursor hopping backwards
One of the innovative features about laptops is the built-in trackpad in lieu of a standard computer mouse. This device eliminates the need to have a mouse dangling from your PC as you tote it from palce to place. Unfortunately, this feature can also wreak havoc on word processing, as the text cursor will jump around the document if the trackpad is accidentally grazed during typing. Fortunately, this is a problem that is simple to correct for both PCs and Macs.
Click on the "Start" icon. Select "Control Panel," then select "Hardware and Sound." Select "Mouse," then select "Device Settings." Select "Settings." Under this tab select the option for "Tapping." This will let you turn off the feature that moves the cursor when you tap the touchpad. Stopping Cursor Jumping for Macintosh Select "System Preferences." Select "Trackpad." Uncheck the box next to "Clicking." This will disable the tapping feature.
Mar 01, 2013 | Computers & Internet
MSI U100 touchpad Solution
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "MSI Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.If the touchpad still does not work after the above steps then maybe a virus or infection has hijacked the touchpad. Try booting into Safe Mode then download and install MalwareBytes and run a Quick Scan.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode With Networking option (this will give youinternet connectivity) and let it boot up. Safe Mode will look different toyou, the screen will be darker and the icons bigger, this is normal. Open your internet browser, then download and install MalwareBytes and run a Quick Scan.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
Jun 08, 2012 | MSI Wind U100-030US Laptop
My cursor jumps suddenly from one place to another, it's very annoying while typing emails, word documents, everywhere... pls help
The usual reason this happens in laptops is that as you're typing, you hit the touchpad with the heel of your hand and the cursor moves. I've done it myself. What I suggest is turning off the touchpad and using an external mouse if you do a lot of typing. This eliminates the accidental contact, and (to me, at least) a real mouse is more comfortable for frequent use. Most computers have a switch that turns the touchpad on or off, or you can disable it through the Windows Control Panel or touchpad utility program.
Mar 29, 2011 | MSI Wind U100 Netbook
Toshiba u505 cursor jumps to other line when typing n
Hi.
Based on the information you have provided, it seems that the issue might be due to the Touchpad "Tapping feature".
This issue usually occurs when the Touchpad Tapping feature is enabled.
You may disable this option by following the steps mentioned below:
1) Click on the "Windows" logo icon. 2) Then, type "mouse" in the search option. 3) Click on the Mouse options which should be mentioned on the search list. 4) Once you have the Mouse options window open, click on the "Device Settings" tab. 5) Then, click on the "Settings" tab. 6) This will open the "Touchpad settings" window. 7) In this window, check for the "Tapping" option. 8) Once you have found that, disable that. 9) By doing this, you will disable the Touchpad tapping feature.
Hope this helps.
Please feel free to contact for further information and assistance.
Feb 01, 2011 | Toshiba Satellite U505-S2940 Notebook
I am having major problems with my sony vaio laptop curser. It keeps jumping when am typing. Can you help?
1. Disable the touchpad tapping feature.
a. Click on start>Control Panel>Hardware and Sound>Under Devices and Printers option, select the Mouse option.
b. Click on the Tapping tab, then, disable the tapping feature.
If the tapping tab is not available, then reinstall the touchpad drivers and disable the tapping feature.
You can reintsll the touchpad drivers either using the VAIO Care Software in the computer or from the support page of your notebook.
Aug 05, 2010 | Sony VAIO VGN-S460 Notebook
U100 wind mini laptop and i cant turn off the
the mouse system keypad sucks as when typing it looks like you never went to school, very frustrating. turn off the key pad when typing by pushing the function fn key and f3 at same time.
i love my wind but hate this problem and i use a regular mouse
Mar 10, 2010 | MSI Wind U100-030US Laptop
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Mar 09, 2010 | Compaq Presario CQ60-220US PC Laptop
U100 msi wind netbook, webcam problems
You should be able to start the device with a default windows driver. Open windows explorer. Look at the left FOLDER pane. Under My Computer you should see USB Video device. Select it to start the webcam with default drivers. This confirms the device as working. Now, loading the correct drivers will give proper resolutions and other device-specific features of the device.
Jan 08, 2010 | MSI Wind U100 Netbook
Computers & Internet Logo
2,493 people viewed this question
David Payne
David Payne
