Question about Denon AVR-600 Receiver
Every time I put a fuse in my amp and plug it in the fuse blows ?????
When I plug my denon receiver into the plug end the fuse will blow.Put another fuse in and plug it into the wall and the fuse blows again.And it keeps on blowen fuses every time I change it.And it doesent take a while to blow it blows as soon as I plug it into the wall.My amp is a denon AVR-600 receiver. What can I do to fix this problem??????
  • mattallinger Feb 25, 2009
    The fuse on the main power transformer will blow every time it gets power. On my amp it appears to be a short in the 125V windings??? as I can cut the L/V wires that go to the main board (ruling out any problem on the Circuit board) and the transformer will still blow a fuse with no load on it.
  • 6 Answers
SOURCE: denon avr 5800
I can help you solve this problem. However you must describe to me which fuse you have replaced. Is it the fuse on the power line or is it a fuse in the speaker line (which I highly doubt). usually this type of amplifier uses two technologies. One is transistors the second is integrated chips. This is in regard to the output stages. I assumed you speaker cables shorted each other while the volume was set at a high level with music playing. Anyway if you are willing I am able to help.
Posted on Sep 01, 2007
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
SOURCE: when you turn on the avr 600 the display says "protect"
The Control IC broken
Posted on May 31, 2008
Foxyjay
  • 13 Answers
SOURCE: denon avr 2105 died (3 times) dead AVR2105 faulty avr-2105
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
SOURCE: My Denon AVR-887 Keeps turning itself off
My AVR-887 IS SHUTTING OFF ALSO AFTER ABOUT 30 SECONDS.
Posted on Dec 04, 2008
Why is the Display Panel no longer displaying?
There is a fuse on the front panel that needs to be replaced. When doing so, there is also a capacitor that denon suggests replacing to avoid the fuse blowing again.
Oct 29, 2015 | Denon 7.2 Channel Full 4K Ultra HD A/V...
Keeps blowing fuses when unplugged from the wall
you need to replace the outlet your plugging it into or go to a different ciruit in the house n try again.
Jul 19, 2013 | Televison & Video
My teac ag-680 fuse keep blowing everytime i replace it and plug the reciever up
are short in the audio output transistors may have been short since a channel 2 or maybe 4, also open resistance check carefully and change them after you put a 75w bulb in series 100w or where is the fuse clearly, you have to remove the fuse when you put the focus if all is well will turn on only a small incandescent and amplifier work well you put audio speakers and there will, if everything is well put the fuse back and ready.
Jan 14, 2013 | Teac AG-680 Receiver
Denon 1312 makes clicking sound will not turn on
If the front display does not light up at all when the press the power button, it is usually either the main power fuse or the power transformer. If the fuse is blowing, that usually means a short in the amp section.
Dec 26, 2012 | Denon Avr-1312 Home Theater Av A/v...
Why does t4al fuse keep blowing?
Fuses blow when there is an overload. The most common cause is a short-circuited semi-conductor device. Frequently found on the large heat sink of the power amp section of the unit. Very often this will have blown due to bad speaker wires. With the two wires touching each other more often than not. Or simply connecting the wrong type of speakers to it.
Oct 13, 2011 | Denon AVR-2309CI 7.1 Channels Receiver
Goodmans GDVDR319 Was unplugged recently & whn plugged back in wouldn't come back on. Each time a new fuse has been put in the plug. In the past when it has been unplugged it has taken between...
You don't say if it's blowing the fuses.
If it is, it's dangerous to keep turning it on until you have someone resolve the problem.
If it comes back on after a few days of idleness the fuse isn't blowing as they rarely self-heal.
Have you tried another power cord?
Jan 25, 2011 | Audio Players & Recorders
My breaker blew and this receiver was plugged in to that particular AC outlet. Does this receiver have some kind of Power Supply protection?
Is that outlet is the only circuit on that breaker?
The receiver may not have exceeded its own internal parameters to blow the fuse or enter protection but it (and whatever else is drawing power from its convenience outlets) may have exceeded the rating for your wall breaker.
There is a modest limit on how much extra current-drawing equipment can hang onto the back of this unit. It's probably printed near the outlet(s). Probably 100 watts max.
In general, nothing heavy duty like heaters, amps, vacuum cleaners, TV's should not be plugged into the receiver.
Jun 09, 2010 | Denon AVR-2500 Receiver
Mitsubishi tv vs 60707 fuse keeps blowing everytime i plug it it
1. unplug from the wall
2. cut off the end of the power cord
3. splice the plug from an extension cord
4. tape it up real good
5. try again
Feb 04, 2010 | Mitsubishi VS-60707 60" Rear Projection...
12v outlet fuses keep blowing.
Faulty reciever ,,, Worth checking the plug assy for internal damage . Check that the sat receiver is within the power capabilities of the vehicles acessory plugs < 10amp .
Dec 23, 2009 | 2004 Ford Ranger
Every time it is turned on it blows a fuse
The fuse blows for protection because you have a blown audio amp or something in hte power supply
Nov 28, 2009 | Denon AVR-882 5.1 Channels Receiver
353 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
