Question about Compaq Presario s4020wm (DK214AR#ABA) PC Desktop
Dvd-cd rw drive
When you put a disk into the cd drive the green light flashes and you can it start to spin then it quits. The light goes out, the cd stops and nothing more happens.
  • 153 Answers
This means that your CD-rom drive does not read the CD, it could be that the CD is a different format (DVD, for example) or the lens is dirty or Your drive is faulty. see if your drive is compact or dvd and try the right formats. Try clean your CD-drive lens. If all this does not fix the problem, your drive is faulty. And needs repair.
Posted on Nov 18, 2008
Hl-dt-st dvd+-rw gwa4164b will not read CD
check the cd for dist... lint... hair... fingerprints... ect. and clean the disk if you see these. take a can of air... use the straw... and blow the drive out... if these don't work... replace the drive.
Mar 31, 2010 | Dell Computers & Internet
Laptop Optiarc DVD RW AD 7530 B is not reading CD or DVD media. 1.DVD icon displayed in My Computer. 2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off...
2.When I insert DVD or Cd in the drive,Green light flashes and tries to read the nedia and goes off within few seconds.
3.DVD drive in My Computer when clicked shows empty folder
4.Uninstalled DVD drivers in Device Manager and let windows find it on reboot
5.Issue still persists.
6.Right now external DVD RW works perfect.
Please help
Oct 29, 2009 | Sony NEC Optiarc AD-7530B 8x DVD?±RW DL...
DVD-RW drive does not read disks
the DVD-RW is faulty, take it in and get another one to replace it. the clicking noise may be coming from the rack gear inside the device and causing a malfunction.
Sep 13, 2009 | Toshiba (WMD070AC) Magneto-Optical Disk...
PIONEER DVD-RW DVR-106D will burn but won't read
i have the same problem ,but when i restart my pc ,i put the disk it can read without a doult .The problem is your disk drive can't read disk when it on windows mode ,using dos and it just fine,some kind of trouble appear cause i burn too much disk in a time and it can't read next time i open computer .May be your windows problem just restart wins then put the disk in ,if it appear the green light it mean it's reading then the green light off it's mean it had identify the disk and does read it
Jun 26, 2009 | QPS Que! CD-Rewriter CD-RW Burner
Dvd drive WILL NOT read burnt dvd's or CD's
The problem occurs mostly when your drive is dying. I had the same problem with my laptop writer recently after which it completely stopped writing discs. Contact your support. Sometimes they would ask you to remove the upper and lower filters of an entry in the registry which would sometimes resolve the problem.
Jun 20, 2009 | Teac DW 28E CD-RW/DVD-ROM Burner
Dvd burner not burning
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD RW drive unit.
Mar 28, 2009 | EZ Dupe EZD880 DVD RW Burner
Cd not reading
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
Try first using a CD/DVD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD RW drive unit.
Feb 24, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
TDK player reads CD disk but quits and does not play
your cd drive lens may be damage and lens preset will be not currect position so if you want to repair you cd drive then you have to turn your cd drive lens preset to currect position.
Dec 22, 2008 | TDK (ai-4800drombx-b) CD-RW/DVD-ROM...
Drive won't open
u can see a pin hole on the drive just above the open button or the green light...press the button once n poke the hole with a pin ,,,,it ll hit a soft end...continue pressing it with some force....the tray will open...
Jan 02, 2008 | LG Super-Multi GSA-4163B 16x8x16x DVD+R/RW...
Compaq Presario s4020wm (DK214AR#ABA) PC Desktop Logo
81 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
